  • 1 Post By Vansquish
 Old 01-15-2020, 07:07 PM   #1
Nery101's Avatar
Posts: 7   (View Stats)
Nery101 is an unknown quantity at this point
Default 5th gear sometime doesn’t wanna go in
So it’s not so of a big issue but I just need to hear y’all opinion about this issue I have sometimes . So whenever I’m racing or accelerating really fast and when I quickly shift into 5th gear above 5600rpm it’s make a small grind noise but it still goes in or if I flat foot shift it won’t go in at all . So I usually just try to quickly shift into 5th before I hit 5500rpm and I have no problem but Why does It grind if I try to go into 5th at higher rpms?I changed the transmission oil already (redline 75-80) and I have a new act 6 punk clutch and flywheel , shifting bushings , cables seems fine , new transmission mount from jbr and rear mount from torque solution and motor mount from jbr . Everything else works great . Does anyone else have this issue ? I have a 2010 gen2 Mazdaspeed and I already replaced the transmission before sometime last year and also my old transmission did the same thing just to mention.
Nery101 is offline   Reply With Quote
 Old 01-16-2020, 09:36 AM   #2
Db09ms3's Avatar
Posts: 536   (View Stats)
Groans: 105
Have you tried adjusting the shifter cables?
Stockish
 Old 01-16-2020, 11:11 AM   #3
Nery101's Avatar
No I haven’t , how would you do that ?
 Old 01-16-2020, 12:14 PM   #4
Police - Grammarhead
Vansquish's Avatar
Carefully.
Db09ms3 likes this.
 Old 01-16-2020, 03:56 PM   #5
Db09ms3's Avatar
Groans: 105
Follow that porn link (jk) Vansquishy spooned you.
Stockish
 Old 01-16-2020, 04:04 PM   #6
Nery101's Avatar
Okay thanks guy it’s seem to fix the problem!! Hopefully it stays like that ha ! Now I can shift at like 6600rpm and no grind. But quick question do any of y’all flat foot shift into 5th gear? And if so does it go in?
 Old 01-16-2020, 04:09 PM   #7
Db09ms3's Avatar
Groans: 105
I granny shift super fast.
Stockish
 Old 01-16-2020, 04:30 PM   #8
Nery101's Avatar
Nice !!!! I flat foot shift 2, 3rd and 4th but I can never flat foot shift into 5th . Maybe it’s just to far apart or something. So I stick to shifting really fast into 5th instead.
 Old 01-16-2020, 04:32 PM   #9
Vansquish's Avatar
Hope you enjoy replacing shift forks/pads and synchros.
 Old 01-16-2020, 04:38 PM   #10
Nery101's Avatar
Oh no lol I only do that while racing ha I don’t drive the car much tho and iv heard our transmission can handle some good power and as long as you don’t miss gear or grind I think it should be okay . Most high horse power Mazdaspeed still use the stock transmission.
 Old 01-16-2020, 08:01 PM   #11
Vansquish's Avatar
I am well aware of this fact, but with your apparently common missed shifts, it's only a matter of time.
ms3 vs wanna be evo morgans22 Street Racing Stories ( Bench Racing ) 6 09-10-2011 03:46 PM
REPORT: BBC says Top Gear doesn't ban gay couples from show audience Haltech Automotive News 0 12-06-2009 12:20 PM
Page generated in 0.30479 seconds with 22 queries
