 Old 03-06-2013, 10:27 PM   #1
kizad's Avatar
Posts: 25   (View Stats)
kizad will become famous soon enough
Default ABS and Traction Control Light's always on and the system's are not functioning.
After getting my 2007 Mazdaspeed stuck in the snow in my driveway again I noticed my ABS and Traction control light were on and would stayed on. I've driving it at least an hour already and they are still on. The abs and traction control are both not functioning now also.
I have tried pushing the DSC button and it dosen't do anything. I have even unpluged the battery. I have no clue what to do and google can't find anything. I don't want to have to take it to the dealership again because that is getting real expensive.
Please help if you have any idea how to fix this.
Thanks.
kizad is offline   Reply With Quote
 Old 03-07-2013, 12:05 AM   #2
keymaster's Avatar
Posts: 397   (View Stats)
keymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the worldkeymaster is the leader of the world
Mazdaspeed 3 or 6? It's possible that a wire to one of the wheel speed sensors or ABS plugs was damaged or came loose. Check behind each wheel for any loose or damaged wires/plugs. You may want to unplug and clean the plugs out, it may just be that a bunch of crap got into one of the plugs and it's sending a bad signal. Check the fuses too (and first), it's always possible that one of them blew.
2007 Mazdaspeed 6 GT
keymaster is offline   Reply With Quote
The Following User Says Thank You to keymaster For This Useful Post:
chuckms6 (03-07-2013)
 Old 03-07-2013, 12:49 AM   #3
kizad's Avatar
It's a mazdaspeed 3. So there are sensors in the wheel wells or something? There was a lot of snow lodged in there.
 Old 03-07-2013, 12:15 PM   #4
keymaster's Avatar
There are. Start with the fuses though, it's possible that one of the wires shorted or got wet and that blew a fuse. If the fuses are good, then you get to take the wheels off and check out the wiring to see if there is any damage. If you're lucky, cleaning things up will fix it, if not it's a trip to the dealership for a new sensor and calibration. It's hard to say what it might be until you start looking though, good luck.
 Old 03-07-2013, 01:51 PM   #5
kizad's Avatar
Thanks! Any chance there are diagrams or pictures of where or what these sensors look like?
 Old 03-07-2013, 11:34 PM   #6
keymaster's Avatar
Probably in the workshop manual. I don't know if it is posted around here somewhere, you'll have to search. Or just look for the wires, the only wires that should be in the wheel well or on the axel should go to the sensors.
And Lex is right, the warning lights should be generating codes that you can pull and look up...you'll need something to do that with. I think a ODBII scanner will read those as well, but don't quote me on that...that would include stuff like a Dashhawk or AP, anything that can pull codes. Auto parts stores used to read those codes for free, I recently heard some aren't doing it anymore. Check for a local meet, someone probably can help you out with that.
 Old 03-07-2013, 08:12 AM   #7
SparkySparks's Avatar
Posts: 1,314   (View Stats)
When you got stuck in the snow, did you hit anything? Check the fuses first followed by the connection to the sensor like @keymaster; said. Other then that you may have damaged the sensor it self. When I hit a curb they had to replace the sensor, hub bearing and then reset the sensor in the computer.
On Order:
Coming Soon:
DIY Projects:
 Old 03-07-2013, 02:31 PM   #8
Check the fault codes. Those modules generate faults.
 Old 10-10-2019, 03:16 PM   #9
DadliMS3's Avatar
Posts: 13   (View Stats)
DadliMS3 will become famous soon enoughDadliMS3 will become famous soon enough
What was the reason?
DadliMS3 is offline   Reply With Quote
The Following User Says NO Thank You to DadliMS3 For This Un-useful Post:
MSMS3 (10-10-2019)
 Old 10-10-2019, 07:41 PM   #10
Posts: 2,825   (View Stats)
Neutral  :  -1 score
You do know that post was six, I repeat, six years ago, right? Do you really expect him to be following the thread now? Maybe PM him, if he is even still here and still owns his car.
Db09ms3 (10-11-2019)
 Old 10-11-2019, 11:13 AM   #11
Db09ms3's Avatar
Posts: 536   (View Stats)
Groans: 105
Jeez no need to be a dick.
Stockish
 Old 10-12-2019, 06:24 AM   #12
He should just think before posting. Really. All of us. Not that hard to look at post dates. Keymaster’s last post of any kind was in May, 2014. If he is even here, it’s just about zero percent that he’d still be following the thread. I suggested a PM might actually reach him if he is still involved here. That was constructive.
Db09ms3 (10-12-2019)
traction control light on.... countrymanjeff MazdaSpeed 3/6 - Troubleshoot/Diagnostics 17 04-01-2016 07:08 PM
ebrake light & traction control light come on and stay on CTSpd6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 09-14-2012 05:44 AM
Traction Control light coming on banzairx7 MazdaSpeed 6 - Engine, Transmission & Driveline 5 03-28-2011 12:18 PM
Traction control & brake light coming on dutchbuffalo MazdaSpeed 6 - Engine, Transmission & Driveline 21 01-21-2011 07:14 AM
Traction control light tuners MazdaSpeed 3/6 - Suspension & Brakes 1 07-20-2009 06:14 PM
Page generated in 0.31608 seconds with 26 queries
