![]() Join Date: Sep 2018
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 15
(Thread Starter) | Not Ranked : 0 score The AFR on my accessport V3 is stuck at 14.85. I noticed the problem when it would intermittently peg at 14.85 but then work normally. I know the car isn't actually running lean and in fact is running rich for many reasons; the exhaust smells like fuel, the spark plugs are carbon fouled, my fuel consumption is really high and my LTFT are pegged at 20. This is because the 14.85 AFR is being read and trying to be corrected. Im getting the codes: P2187 - lean at idle P2177 - lean at off idle and the code for o2 sensor low voltage which I forgot the code for I've replaced the o2 sensor already and need more ideas on what to look for. Is it possible I bought a dud o2? Is the problem with my harness? |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,745
| There are two O2 sensors. If your AFR is pegged at 14.85, then it is probably your primary O2 sensor that has failed. If you only replaced the secondary, then that wouldn't have addressed the issue with the primary sensor. Also, did you buy a new O2 sensor, or was it used? If it was the latter, there's every chance that the sensor was already fouled by the time you got it.
| The Following User Says Thank You to Witness For This Useful Post: | Vansquish (12-03-2019) |
![]() Join Date: Nov 2019 Location: Tucson, AZ
Rep Power: 9 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8
| Not Ranked : 0 score Have you captured logs of and/or monitored O2 voltage? I think it should be like a waveform going up and down on the primary if i recall... If your AFR is static I would assume the signal would be as well coming from the O2 sensor. Also, what intake are you running? I had crazy high LTFTs (15-20) w/ the MSCAI, adding the air straightener brought it down to 5 in less than 5 min idling. My exhaust wreaked of gas too, super rich. Last edited by C-love; 12-03-2019 at 07:07 PM. Reason: MSF Database - Automerged Doublepost |
And I think my LTFTs are so high because for some reason my ecu is reading an AFR of 14.85. If the problem was with the AP for example, the car would run normally because the o2 sensor is actually working, but the AP is not. | |
| The AP is not the problem, though your tune could be an issue. Could you please post a full list of your modifications? That may help us assist you in diagnosing your issues. In fact, if you could put your full mod list in your signature, that would streamline future diagnoses.
__________________ 2007 MS3 Stock Turbo - Wiseco Pistons - Manley H-Beam connecting rods - Autotech high pressure fuel pump internals - ARP cap bolts - ARP main studs Balance shaft delete - JBR EGR delete - COBB intake - COBB front mount intercooler - COBB rear motormount - COBB electronic boost controller - COBB access port V3 - COBB blow off valve - Catless downpipe | |
| The Following User Says Thank You to Witness For This Useful Post: | Vansquish (12-04-2019) |
| OK, and if I recall correctly, you're running a Cobb OTS stage 3 93 tune. That tune is, at least theoretically, reasonably appropriate for the modifications on your car. So... That brings us back to electrical issues (i.e. sensor/wiring harness/harness connections/etc.). You might want to check out this thread: AFR stuck at 14.85 There are a couple of possible solutions in there, ranging from replacing a bad fuse or changing spark plugs, to having to replace the ECU. As a place to start, you might want to try checking the ENGINE BAR fuse.
| The Following User Says Thank You to Vansquish For This Useful Post: | C-love (12-04-2019) |
| Not Ranked : 0 score Where do we get our AFR data, is that not from the 02 sensor? |
Is there a thread that explains how to test if the female connectors on the wiring harness are good or bad? I'm guessing testing for continuity or something?
(Thread Starter) | Not Ranked : 0 score Is it possible the person at autozone sold me the wrong o2 sensor? Could someone tell me what the part number is for the primary o2 sensor for a gen 1 ms3?
![]() Join Date: Sep 2017 Location: Western Mass
Rep Power: 43 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score you might want to return that, drop more coin and get an oem sensor.
__________________ 06 Speed6 White/Black interior Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts To think... this is suppose to be my winter car... because, '72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far '12 1/2 Triumph Daytona 675R stock some how '79 AMC Spirit AMX, 4.6L stroker I6 |
(Thread Starter) | Not Ranked : 0 score cant return it because I've installed it already and drove with it on. So that was $200 that could've gone towards a tune. Anyone know which one I should get from rock auto? They have many options.
| Not Ranked : 0 score I feel like you might be jumping the gun here, have you made any efforts to see if there is valid sensor output yet? Beyond the AP or a BT adapter you can probably back-probe a connector. |
| Not Ranked : 0 score So correct me if I'm wrong but isn't there a bunch of threads stating to stay away from aftermarket O2 sensors? Maybe it's just me and I'm full of shit but keep wasting time and money on a different aftermarket ones or just buy an oem one and be done if that is indeed your problem. I get it they are expensive and it'd be nice to put that money on towards a tune.
| The Following User Says Thank You to LenSpeed6 For This Useful Post: | MSMS3 (12-11-2019) |
I might be jumping the gun, but I have no idea how to back-probe the connector to check for valid sensor output.
__________________ 2007 MS3 Stock Turbo - Wiseco Pistons - Manley H-Beam connecting rods - Autotech high pressure fuel pump internals - ARP cap bolts - ARP main studs Balance shaft delete - JBR EGR delete - COBB intake - COBB front mount intercooler - COBB rear motormount - COBB electronic boost controller - COBB access port V3 - COBB blow off valve - Catless downpipe Last edited by Witness; 12-05-2019 at 12:07 PM. Reason: MSF Database - Automerged Doublepost | |
| The Following User Says Thank You to Witness For This Useful Post: | Vansquish (12-05-2019) |
![]() Join Date: Oct 2011 Location: San Leandro, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 460
Groans: 87
| Not Ranked : 0 score NGK/NTK and Denso are fine.
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT |
| The Following User Says Thank You to tegxsi For This Useful Post: | Vansquish (12-05-2019) |
(Thread Starter) | Not Ranked : 0 score so this means either I bought a dud or the problem is with the harness or ECU (?)
| Could you post a couple of datalogs including some at idle, and at least one WOT log from ~3000rpm to at ~6000rpm?
| The Following User Says Thank You to Vansquish For This Useful Post: | MSMS3 (12-05-2019) |
https://cobbtuning.atlassian.net/wik...talog+Monitors And to log: https://cobbtuning.atlassian.net/wik...How+To+Datalog | |
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,503
| Not Ranked : 0 score Gen 1 OEM primary O2 sensor: https://edgeautosport.com/mazda-oem-...d-6-2006-2007/ Be sure you get the Gen 1, as Gen 2 is different.
| The Following User Says Thank You to MSMS3 For This Useful Post: | Witness (12-06-2019) |
Groans: 87
Maybe check for corrosion or damaged wires in the o2 sensor and ECU plugs.
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT | |
![]() | | #24 | ![]() |
Is there a diagram that shows what each pin in the ECU plug is for? That would help alot. I could post a log at idle after work, I dont know how comfortable I feel doing a WOT pull because when I do, the car hesitates almost as if I stepped off the throttle and then stumbles alot almost like rapid fire boost/fuel cut. I'll try and log that so you guys see what I'm talking about
__________________ 2007 MS3 Stock Turbo - Wiseco Pistons - Manley H-Beam connecting rods - Autotech high pressure fuel pump internals - ARP cap bolts - ARP main studs Balance shaft delete - JBR EGR delete - COBB intake - COBB front mount intercooler - COBB rear motormount - COBB electronic boost controller - COBB access port V3 - COBB blow off valve - Catless downpipe Last edited by Witness; 12-06-2019 at 10:15 AM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #25 | ![]() |
| There are a couple of wiring diagrams (including pinouts for various components) for the MS3 and MS6 in the VIP section. I think there's only one for the GenPu MS3 though most things should still be the same in the engine compartment. If you're getting strange behavior at WOT, then if you can capture a log that shows what's going on, that will help a lot. Please make sure that you're datalogging at least the following parameters: Accel. Pedal Pos. Actual AFR Boost Boosted Air Temp Calculated Load Coolant Temp Engine Speed (RPM) HPFP Actual Pressure Injector Duty Cycle Intake Temp Intake Valve Adv. Knock Retard Long Term FT (LTFT) MAF Voltage Mass Airflow Short Term Fuel Trims (STFT) Spark Advance Throttle Position Vehicle Speed Wastegate Duty Cycle
| The Following User Says Thank You to Vansquish For This Useful Post: | Witness (12-06-2019) |
![]() | | #26 | ![]() |
![]() Join Date: Jan 2017 Location: Buffalo NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 100
| Not Ranked : 0 score Sorry, I may be wrong but I thought cobb ots did not have a tune for a catless dp.
__________________ 2007 speed3 GT. cobb rmm, JbR pmm, Corksport adjustable shifter, twm solid shifter bushings, Sure shift knob, AP3, Autotech, CS turbo, CS occ, HTP 3.5, Depo catless dp, TS Kompact bpv, CS 3port, cpe BlockD, GA V3, DO DVC-30, Cx racing piping, tr1035.. Freektuned 2011 mazda 6 |
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score No, not a catless downpipe.
![]() | | #28 | ![]() |
![]() Join Date: Dec 2017 Location: Chico CA for school. Originally From the Bay Area
Rep Power: 27 ![]() Thanks: 17
| Not Ranked : 0 score |
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score Here are some datalogs; a cold start log, and idle log after it's warmed up, a third gear pull from 3k to 5k and a fourth gear pull from 3k to 5k respectively
![]() | | #30 | ![]() |
| Yep...that definitely looks like a bad O2 sensor reading to me. Are you sure the connectors are fully engaged for the O2 sensor pigtails? Are the pins in the connectors in good shape?
![]() | | #31 | ![]() |
Got a new code though, P0140 - Bank 1 sensor 2; no activity No other new codes.
![]() | | #32 | ![]() |
| Sounds like you should probably check/replace your secondary O2 sensor! Also, you might want to read this thread: P0137, P0139 and P0140 It's possible that you have some debris in your exhaust system.
![]() | | #33 | ![]() |
![]() | | #34 | ![]() |
| Yeah, metal debris from your turbo could've fouled the sensor, just as excessive oil, fuel, or even chunks of catalyst (though you're cat-less, if memory serves) could damage the sensor.
![]() | | #35 | ![]() |
My turbo blew a long time ago. Disassembled all piping and there wasn't much metal in the piping or intercooler, nor in the oil pan magnet.
![]() | | #36 | ![]() |
| I'm not sure about that, but it may have to do with the number of drive cycles that the ECU needs to go through after each ECU flash before it can determine that there is a fault with the secondary O2 sensor.
| The Following User Says Thank You to Vansquish For This Useful Post: | Witness (12-09-2019) |
![]() | | #37 | ![]() |
| Not Ranked : 0 score Sorry if i missed this info above, but: what happened to your original OEM O2 sensor? Was that a casualty of the blown turbo? Or oil leakage leading up to the blown turbo? |
![]() | | #38 | ![]() |
(Thread Starter) | Not Ranked : 0 score I couldn't tell you. Possibly. When the turbo blew, the O2 sensor still worked for a few weeks. After that, the sensor worked intermittently where it would peg at 14.85 but work normally sporadically.
![]() | | #39 | ![]() |
Possibly a wiring harness rubbed through on an engine component. I might start looking near hose clamps next to the ECM harnesses as this seems like a common failure point. | |
![]() | | #40 | ![]() |
| The Following User Says NO Thank You to Witness For This Un-useful Post: | MSMS3 (12-15-2019) |
| AFR STUCK! | mariosalguero | Mazdaspeed3/6 General Discussion | 6 | 06-25-2016 10:28 PM |
| AFR stuck at 14.85 | maisonvi | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 29 | 03-06-2016 06:19 PM |
| HU stuck | sega_rt | MazdaSpeed 3/6 - Car Audio & Electronics | 0 | 06-14-2013 11:32 AM |
