![]() Join Date: Apr 2019 Location: North Carolina
Rep Power: 0 ![]() Thanks: 0
Groans: 60
| Not Ranked : 0 score It's location is shown in the picture you posted. It's just a small black plastic square with a bolt holding it in place.
(Thread Starter) | Not Ranked : 0 score Thanks, but i was looking more for where its located, ie. "A bolt holding it in place" on the block, head, firewall, intake, transmission, or any other metal surface on that side of the engine bay. |
| Not Ranked : 0 score it's on the top plate just above the egr. the connector is the same as the EBCS but with just 1 wire.
(Thread Starter) | Not Ranked : 0 score Fixed it. The issue had nothing to do with the coils. The common ground underneath the air filter was corroded and the ground spot was rusted. going to run a dedicated ground to it. So if anybody's ms6 (and probably any first gen 6) died out and keeps blowing fuses, check the ground point under the air filter (ps. bring a good set of vice grips to get the stupid rubber head bolt out.) |
| ECM Fuse keeps blowing? | Tru3 | 2010 MS3 - Troubleshoot/Diagnostics | 1 | 08-05-2018 07:58 AM |
| 2013 keeps blowing fuse | ltoddiv | 2010 MS3 - Troubleshoot/Diagnostics | 6 | 08-17-2017 11:35 AM |
| Engine IG Fuse keeps blowing | dawgincustoms | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 2 | 05-15-2017 04:01 PM |
| Eng Bar fuse keeps blowing after water splashed into engine bay | Dawey1 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 14 | 03-28-2011 01:19 PM |
| Need your help! Fuel Injector Fuse keeps blowing | flz33 | MazdaSpeed 3 - Engine, Transmission & Driveline | 7 | 12-23-2008 09:09 AM |
