Like Tree37Likes
 Old 12-03-2014, 05:53 PM   #81
jasperwill's Avatar
Posts: 3   (View Stats)
jasperwill is an unknown quantity at this point
Thanks for the quick response. if no one knows the correct bearing part number i guess ill have to do the same research OP did. pull out my bearing, take it to a couple auto parts stores and source a replacement.
I appreciate all the work that went into this thread it has given me the incentive to get this issue fixed for a reasonable price instead of the minimum 150$ cost of the full pulley.
BTW my model is a 2012 non-skyactive F VIN sedan.
jasperwill is offline   Reply With Quote
 Old 06-04-2015, 06:57 AM   #82
LuRoc's Avatar
Posts: 2   (View Stats)
LuRoc is an unknown quantity at this point
BUMPING this old thread again! I need some help with this bearing part # as well.
2012 Mazda 3 i Sport 2.0L Automatic ( 5 -speed) Non-SkyActive (vin: "F")
Correct Bearing # please?
Thanks LuRoc
LuRoc is offline   Reply With Quote
 Old 06-04-2015, 06:59 AM   #83
btstarcher's Avatar
Posts: 4,852   (View Stats)
You have a different compressor. So this information doesn't pertain to you. Do some research. Tear into it and take some measurements.
SnailTune in progress
LuRoc (06-04-2015)
 Old 06-04-2015, 07:05 AM   #84
LuRoc's Avatar
It's my only vehicle on the road at the moment. Maybe I should first purchase both size bearings (MT2021 & MT2023) just incase before taking off my tire?
Thanks Man!
 Old 06-04-2015, 07:19 AM   #85
jasperwill's Avatar
If you do this before I do please post the information you ended up finding. I'm in a similar situation as you as far as vehicles so I will probably have to take vacation from work in order to do it.
 Old 06-04-2015, 07:24 AM   #86
btstarcher's Avatar
If it's your only vehicle I'd replace the compressor, then take apart the old compressor to get the bearing measurements. It's possible that neither of those bearings will work. You have a different vehicle. You might find more information in a forum that caters to the Mazda 3; maybe someone there has already done the legwork.
 Old 06-05-2015, 08:25 AM   #87
TedShred's Avatar
Posts: 1   (View Stats)
TedShred is an unknown quantity at this point
I recently picked up a Mazda 3 and now the AC is not working (was fine when the purchase went down).
The condenser fan is powering on but the AC clutch is not engaging (maybe a blown fuse for this???). The belt and pulley are spinning just fine when the car is running. When the car is turned off, I can't turn the pulley/clutch on the compressor by hand. Not sure if this bearing replacement procedure will fix this or if the compressor is locked up.
Any suggestions from you experts??? Thanks!
TedShred is offline   Reply With Quote
 Old 06-05-2015, 10:00 AM   #88
BlaZenem's Avatar
Posts: 6   (View Stats)
BlaZenem is an unknown quantity at this point
If its anything like the speed 6 look in the engine fuse panel for a fuse labeled "mag"...i paid $50 for a shop to diagnose that lol. Also check all connections.
Sent from my SM-N910T using Tapatalk
BlaZenem is offline   Reply With Quote
 Old 06-15-2015, 07:34 PM   #89
grw
grw's Avatar
Posts: 5   (View Stats)
grw is just really nicegrw is just really nicegrw is just really nicegrw is just really nice
Neutral  +1 score
This is a great tutorial! The bearing in my '08 speed 3 was toast. Sadly I bent the pulley when replacing the bearing. I emailed North America A/C Distribution through amazon and within 30 minutes they had the correct clutch kit uploaded to Amazon for sale ($80) and shipped one out to me the next morning. Hopefully this is helpful to someone:
124mm 6 groove pulley
Brand: CoolTech
Manufacturer Part Number: 476CKturbo
The kit does not come with bolts, shims, or C-clip. The kit includes the pressure plate (2), A/C compressor pulley (5), and stator and thermal protector (9) - numbers reference exploded parts diagram Nel Mazdaspeed posted.
Thanks again for the original tutorial and all the additions people have added over the years.
divinestriker likes this.
grw is offline   Reply With Quote
The Following 3 Users Say Thank You to grw For This Useful Post:
Ebdiggity (08-07-2015), Rich990 (01-05-2016), Vansquish (09-03-2017)
 Old 06-15-2015, 11:08 PM   #90
BlaZenem's Avatar
Im gonna look that up i need a new one...trying to avoid a whole new compressor
 Old 06-26-2015, 11:29 AM   #91
redneck4Christ's Avatar
Posts: 1,803   (View Stats)
redneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the world
Edit, Gen1 shop manual. page 07-40-20 or page 2262 of 2910 in pdf format.
Thanks @Trebor379 and all who have contributed. My A/C is acting up and this may be one of my problems, but I suspect something else as well.
The A/C has blown cool, but not cold for quite a while now. A couple of times recently, it has shut off after running a while.
It starts quiet (no noise I notice anyway). Then after running as cold as I can get it for a while, it starts getting noisy. Kind of a growling noise. Then after a little while, it shuts off and the compressor will not engage or only briefly engages. If I shut the system off for a while it will go back to working and repeat the process. I added an 18oz can of Freon last night, but it seems to have had no effect.
I'll add this to the list of problems to work out once I get the backup vehicle running in a couple of weeks.
Nitro, Is that only when starting with an empty system or is this applicable for topping off the system as well. Before reading this thread, I tried adding Freon last night only to the low side, while running, and it seemed to take the whole can just fine.
Originally Posted by Nitr0EngiE View Post
I posted a issue previously about never being able to charge the Ac correctly the car simply would not take the freon from the cans it took a tiny bit then no more.
I found the trick is you are supposed to charge about 8 ounces into the HIGH side with the car OFF first and then put the rest in low side with the car on
WARNING if you try to charge the high side with the AC and car running the can will blow up and you will have a shitty couple of weeks recovering.
i did this and now my ac blows cold and good and i did not have to pay Mazda either like the last 2-3 times i had to have a shop do it because it would never take the freon. When i asked about it on the fourms noone could tell me why the car would not take the freon then a youtube video exposed to me that the service manual directs you to charge high side first.
2007 Cosmic Blue MS3, Stage 0.75, baby hauler.
Sorry I couldn't make it out, I ran out of makeup so I didn't leave the house.
redneck4Christ is offline   Reply With Quote
 Old 07-04-2015, 03:02 AM   #92
pedroyoda's Avatar
pedroyoda is an unknown quantity at this point
Does anyone have an info on the actual shims for the clutch plate? Mine fell off awhile ago. Found a replacement but it doesn't have the shims.
pedroyoda is offline   Reply With Quote
 Old 07-23-2015, 05:39 PM   #93
USMC_RYAN's Avatar
USMC_RYAN is an unknown quantity at this point
Would this also be the same for a 2008 Mazda 3i 2.0l?
USMC_RYAN is offline   Reply With Quote
 Old 07-23-2015, 07:15 PM   #94
No
 Old 07-25-2015, 03:39 PM   #95
tmiller252's Avatar
tmiller252 will become famous soon enough
After much reading, diagnosed it as a bad clutch. However looking at the clutch assembly mine does not have a 10 mm bolt holding it. Looks to me as an Allen wrench bolt holding on clutch assembly. Any one have suggestions with this one. Looks rusted and probably hard to remove.
tmiller252 is offline   Reply With Quote
The Following User Says Thank You to tmiller252 For This Useful Post:
907speed6 (08-03-2015)
 Old 07-25-2015, 03:42 PM   #96
I would say an Allen wrench. Probably left hand thread.
 Old 08-03-2015, 08:14 PM   #97
meowser's Avatar
meowser will become famous soon enoughmeowser will become famous soon enough
This was an awesome post. I pulled the clutch and the pulley without much difficulty. Hardest part was getting the stretch fit belt off in one piece. Found the bearing on eBay for $13 shipped, and it was in the pulley and back on my Mazda 5 in an hour. my kids are thrilled to have the AC back in the family hauler. the pre-fix sound was truly frightening. sounded like a box of wrenches rattling around in a death cough type noise at idle with the AC clutch disengaged. nice and quiet now.
tmiller252 - mine was a 5mm allen wrench. right hand thread. came out super easy. i eased it off the spindle by lightly prying it with a screwdriver as I rotated the clutch. pulley came off in the same fashion.
Last edited by meowser; 08-03-2015 at 08:14 PM. Reason: MSF Database - Automerged Doublepost
meowser is offline   Reply With Quote
The Following User Says Thank You to meowser For This Useful Post:
 Old 08-04-2015, 04:00 AM   #98
Can you post the bearing details for the next mazda 5 guy? Want to make sure they can get one.
 Old 08-04-2015, 06:49 AM   #99
rollingworm's Avatar
Posts: 137   (View Stats)
rollingworm has a brilliant futurerollingworm has a brilliant futurerollingworm has a brilliant futurerollingworm has a brilliant futurerollingworm has a brilliant futurerollingworm has a brilliant futurerollingworm has a brilliant futurerollingworm has a brilliant futurerollingworm has a brilliant futurerollingworm has a brilliant futurerollingworm has a brilliant future
After reading through this I haven't been able to find the same situation as my problem. Maybe you guys can help. Hooked up gauge to high side and it read good pressure, turn the AC on and it sounds like the compressor is running but it just blows hot air. Do you think it could be the compressor is bad, or is it just the clutch not engaging?
rollingworm is offline   Reply With Quote
 Old 08-04-2015, 09:02 AM   #100
meowser's Avatar
Default Mazda 5 owners
My 2006 Mazda5 used the following size bearing: 32mm x 47mm x 18mm There are a couple of manufacturers, Japanese and Chinese. At this point in your car's life, I doubt the source will matter.
Raider (08-05-2015)
 Old 08-09-2015, 03:36 PM   #101
jpiekarz's Avatar
Posts: 8   (View Stats)
jpiekarz is an unknown quantity at this point
Also finding this thread useful, had my Speed3's AC Clutch grenade on a trip back from Maine yesterday.
Got it all apart and had so many parts literally fall off the compressor as I was doing it that I lost one of the shims. Found the part number that appears correct though - B25F61L1Y. Hope that helps others here.
Also having an issue with getting the bearing out. The old one is literally in pieces and only the outer retainer is sitting in the pulley still, but despite my best efforts I couldn't pound the old piece out. Going to see if I can find a Machine Shop that can help. Anyone have any ideas?
Vehicles:
2008 Mazdaspeed 3 Sport, Bone stock
2007 Triumph Daytona 675
jpiekarz is offline   Reply With Quote
 Old 08-09-2015, 04:45 PM   #102
meicalnissyen's Avatar
Posts: 1,158   (View Stats)
discountacparts.com
if its that bad the stator is proly shot
 Old 08-09-2015, 04:58 PM   #103
btstarcher's Avatar
Mine rattles extremely loudly and rapidly at idle, and doesn't really blow cold air; after about 2k RPM the noise goes away and it works fine. The sound is kinda like the noise from putting baseball cards in the spokes of a bicycle wheel. I'm guessing it's the clutch, but I've never heard anything quite like it.
 Old 08-11-2015, 04:43 PM   #104
jpiekarz's Avatar
Yeah, I won't lie, the stator looks beat up. The A/C was working before I pulled this thing apart though...
I really don't want to have to replace the entire compressor (discharge the system, change the drier, flush it, recharge, etc). Is there any place you can just buy the compressor clutch and get it quick and relatively cheaper than the whole compressor?
Weighing whether to just put it back together as is and hope for the best with the clutch. Right now total repair costs with paying the machine shop to put the bearing in is $50.00. And the car is immobile right now with the belt off.
Vehicles:
 Old 08-11-2015, 04:47 PM   #105
ryguy 3's Avatar
Posts: 353   (View Stats)
I'm pretty sure you can drive your car with the ac belt off as long as you serpentine belt on your good, just no air conditioning.
 Old 08-16-2015, 11:13 PM   #106
btstarcher's Avatar
How do you manage that, since we only have 1 belt? Where is this magical A/C belt you speak of?
I'll be replacing my shit soon, but I'm having trouble finding the clutch by itself. Any ideas?
 Old 08-17-2015, 08:47 AM   #107
ryguy 3's Avatar
My mistake i was assuming the set up was similar to the regular 3 but it's not, we just have 1 belt. Fucking magical a/c belt lol
The Following User Says Thank You to ryguy 3 For This Useful Post:
btstarcher (08-17-2015)
 Old 08-17-2015, 09:21 AM   #108
ryguy 3's Avatar
heres one on ebay: Brand New 2007 08 mazdaspeed 3 6 AC Compressor Clutch Kit 124mm 6 Groove | eBay
 Old 08-17-2015, 05:10 PM   #109
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
With the high level of cost and effort involved with an ac compressor swap, i'd advise against the cheapest possible option
it's fun to do bad things
 Old 08-17-2015, 05:12 PM   #110
btstarcher's Avatar
I'm not swapping the A/C compressor. I'm only replacing the clutch and bearing. The compressor itself seems to be working fine.
jack_hammer (08-18-2015)
 Old 08-17-2015, 07:26 PM   #111
btstarcher's Avatar
Asking for a friend: if the bearing seizes, can he just replace the clutch assembly? Or does he need to replace the compressor/flush the system?
 Old 08-18-2015, 11:33 AM   #112
Groans: 549
maybe if i actually opened the link...i would have seen that...
The Following User Says Thank You to jack_hammer For This Useful Post:
btstarcher (08-18-2015)
 Old 08-18-2015, 01:15 PM   #113
ryguy 3's Avatar
If your talking about the bearing on the clutch assembly you can just replace the clutch assembly (no need to open the refrigerant side), but if you wait too long the vibration from the failing clutch bearing could cause damage to the thrust bearing on the compressor shaft which would be a bigger problem (it could cause seals to leak due to vibration and heat generated from the bad bearing). Also if the clutch bearing seizes your probably gonna burn your serpentine belt.
If hes talking about the compressor bearing then no you have to replace the compressor and open the system.
 Old 08-18-2015, 01:18 PM   #114
btstarcher's Avatar
The clutch bearing is seized for sure. Also he will need to replace the belt. I think we'll just do those and take our chances; if the compressor fails down the road, we'll address it at that time.
 Old 08-18-2015, 03:27 PM   #115
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
We got a new compressor from Ebay for my buddy for $180 shipped.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
The Following User Says Thank You to mrmonk7663 For This Useful Post:
 Old 08-18-2015, 03:29 PM   #116
btstarcher's Avatar
Yeah they've come down in price. Still a lot more than just replacing the bearing or the clutch. Especially because you'll have to flush/refill the system.
 Old 08-19-2015, 10:26 PM   #117
localnj's Avatar
localnj will become famous soon enough
I just did the bearing replacement (Mt2021) purchased from autozone because I couldn't afford to wait for shipment of a$13 one from eBay. My bearings were loose inside when I pulled the pulley. It was wobbly and smoking during my last drive and I kept having to stop to allow it to cool down. However, when I pulled it the coil pack in the magnet was exposed and looked pretty fried. Like others on here mentioned, I could not get the outside bearing race out of the damn pulley for the life of me (no press). Ended up sawing it out with a dremel. Tough work, but I didn't think a nick or two in the bearing housing would affect the new bearing from seating and being completely stuck in there the way the old one was.
Whole thing was a major pain in the ass all night ordeal (didn't help that I decided it was a good time to replace front sway bar bushings at 1 am, cuz I had the car jacked and the wheel liner out! ), but got my car drivable again for dirt cheap... but... The clutch is apparently shot. It won't engage, which I suspected might be the case when I saw the condition of the coil magnet.
Has anyone confirmed we (2009, sorry) have the same diameter clutch and pulley as the 2007 & 2008s? According to all the sites I can find, the cool tech part ck476turbo states that it is for the 07, 08 ms3 and ms6 only. It lists this as a 6 groove (which I know is correct) 124mm diameter pulley. I didn't measure mine when I had it out. This part is $80 on Amazon, so I'm really hoping it's the correct one (and that I don't actually need the whole compressor at this point! ) anyone know for sure? Thanks
localnj is offline   Reply With Quote
 Old 08-20-2015, 06:35 PM   #118
Fozzy's Avatar
Posts: 193   (View Stats)
Fozzy has a reputation beyond reputeFozzy has a reputation beyond reputeFozzy has a reputation beyond reputeFozzy has a reputation beyond reputeFozzy has a reputation beyond reputeFozzy has a reputation beyond reputeFozzy has a reputation beyond reputeFozzy has a reputation beyond reputeFozzy has a reputation beyond reputeFozzy has a reputation beyond reputeFozzy has a reputation beyond repute
Started to work on mine, and when I pulled the pulley off, the bearing completely fell apart. Anyone got any tips on how to remove the outer sleeve of the bearing from the pulley?
Fozzy is offline   Reply With Quote
 Old 08-21-2015, 10:17 AM   #119
localnj's Avatar
See my issue above, I ended up having to cut the outer race out with a dremel tool. Had to cut it on both sides so that it came apart. Just use caution so you don't go too deep, but I barely ended up with any damage to the actual bearing housing. A few rasps near the edge that I needed to file/sand before seating the new bearing. It's not the ideal method, but in my case that bearing ring just wasn't budging and I would have probably done significantly more damage to the pulley trying to pound that thing out.
To reiterate my question above - does anyone know if that ck476 turbo clutch assembly also fits the 09 ms3? States 124mm outside pulley measurement, but I didn't see any other dimensions or specs listed.
 Old 08-24-2015, 11:02 AM   #120
btstarcher's Avatar
Can anyone verify that this looks like the correct clutch assembly? It looks right to me but I haven't taken mine apart, and don't want to if I'm not sure that this will work.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f293/c-compressor-clutch-finally-cheap-fix-153663/
Design's Long Term Ownership/Build Thread - Page 8 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-19-2015 06:50 PM
signs of bad ac clutch - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 09-19-2015 05:12 PM
Bearing de poulie pour la clutch de l'air climatisé - Mazda 3 Quebec This thread Refback 09-02-2015 08:59 PM
Peladero del único y verdadero Mazda Team 2015 :shocky: :SonoraDinamitaStyle: - Página 11 - VelocidadMaxima.com This thread Refback 06-19-2015 09:50 AM
08 Mazdaspeed 3 clattering noise : mazda This thread Refback 07-02-2014 08:40 PM
a/c compressor clutch tried to sneak away TiGraySpeed6 Mazdaspeed3/6 General Discussion 28 09-03-2014 06:21 AM
Ac Compressor Clutch Fail bc2292 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 05-07-2014 09:55 AM
Page generated in 0.57162 seconds with 40 queries
