![]() | | #161 | ![]() |
![]() Join Date: Feb 2015
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score ![]() ![]() Sent from my LG-D851 using Tapatalk |
![]() | | #162 | ![]() |
![]() Join Date: Jun 2014 Location: Chatsworth, CA
Rep Power: 122 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 33
Sent from my SPH-L720 using Tapatalk | |
![]() | | #163 | ![]() |
| Not Ranked : 0 score |
![]() | | #164 | ![]() |
![]() Join Date: Feb 2011
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score Hi, Did you ever post that video? I'm wondering if I have the same issue. My A/C compressor stopped working, I hear the noise of metal scraping on metal and sometimes a burnt smell. I'm wondering whether the bearing is bad or whether it's something else and, god forbid, I have to change the whole compressor. |
![]() | | #165 | ![]() |
![]() Join Date: Apr 2016
Rep Power: 0 ![]() Thanks: 3
I don't think trying to pry it out with a screwdriver would actually work. Any other way to get it out without grinding those tabs off, or trying to find a place with a hydraulic press that could press it out for me and put the new one in? I've attached pics of what it looks like after I had a go at it. If I try to grind the tabs off (not even sure how I'd do that), would the new bearing still stay in the pulley? Last edited by Pyronaut; 08-07-2016 at 01:57 PM. | |
![]() | | #166 | ![]() |
![]() Join Date: Feb 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 139
Sent from my STV100-1 using Tapatalk | |
![]() | | #167 | ![]() |
As for the socket method you suggested, if half the weight of my car resting on it didn't get it out, I don't think a hammer/socker combo would do it now matter how hard I try to hit it | |
![]() | | #168 | ![]() |
![]() Join Date: Jul 2010
Groaned at 28 Times in 6 Posts
Sent from my SM-N920V using Tapatalk | |
![]() | | #169 | ![]() |
In rpaniagua's photos it looks like he might have cut or ground them off, but I'm not sure. So you managed to get it out piece by piece then? I wonder if I can get the inner ring out first, perhaps I could bend the outer part to be able to remove it, and then maybe hack away at the tabs until they're all gone so I get can the new pulley back in. | |
![]() | | #170 | ![]() |
| Not Ranked : 0 score I kissed the tabs with the dremel as well. Good luck trying to get it out. The new bearing went in nice with a couple taps around it with a hammer, and slid right onto my compressor like a glove Sent from my SM-N920V using Tapatalk |
| The Following User Says Thank You to johnnybochamp For This Useful Post: | Pyronaut (08-09-2016) |
![]() | | #171 | ![]() |
![]() Join Date: Jul 2016
| Not Ranked : 0 score I would like to say a huge thanks to Trebor379 for starting this thread. I did my daughters AC clutch motor a few weeks ago and its so cold it makes me turn it down and we live in the Memphis area. NO FEAR of doing anything after studying and doing this myself. Shop quoted me $750.00 for the compressor I told him its not bad. I posted a few pictures along the way hope they help someone else out that might have any question. Thanks again Trebor379 for the start thread. |
![]() | | #172 | ![]() |
![]() Join Date: Jan 2010 Location: Portland, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 48
https://www.youtube.com/watch?v=j7yflp1WFrU
__________________ 09 CWP MS3 - Corksport SRI/Turbo Inlet,RMM Inserts, TMIC, LED Fogs and Interior - Cobb AP (91+ SRI Tune) -RallyArmor UR Flaps - Stealthbox and 600Watt MTX Amp - JBarone Short Shift Plate - Forge V2 BPV - Blue Calipers via G2 | |
| The Following User Says Thank You to jmustang68 For This Useful Post: | Design (08-29-2016) |
![]() | | #173 | ![]() |
![]() Join Date: Nov 2010 Location: Austin, TX
| Not Ranked : 0 score I know this thread is old, but I'm doing the bearing replacement today. I've got an '07 MS3. I cannot, for the life of me, get this pulley off by hand. I saw that the OP used a gear puller, but I can't imagine it would be easy to fit one in there. Has anyone else successfully used a gear or pulley puller without removing the entire compressor?...and can you share a model number with me.
Any help is greatly appreciated. | |
![]() | | #174 | ![]() |
| Not Ranked : 0 score I used a puller from Oriely autoparts free rental with a deposit Sent from my SPH-L720 using Tapatalk |
| The Following User Says Thank You to ryguy 3 For This Useful Post: | stewart stewart (08-26-2016) |
![]() | | #175 | ![]() |
![]() Join Date: Oct 2009
Rep Power: 0 ![]() ![]() ![]() Thanks: 8
| Not Ranked : 0 score Thanks for the thread on this, mine went from silent to screws in a can in two days. However when I opened up my hood I found this ground wire not connected at all, Could this ground wire not being connected cause damage to the compressor or the clutch? |
![]() | | #176 | ![]() |
![]() Join Date: Oct 2016
| Not Ranked : 0 score Hoping some had the same issue as I am. When I removed the clutch, there was one shim. After replacing the bearing and putting it back together, the clutch doesnt spin freely by hand. Did anyone else have this issue? Are more shims needed? Thanks! |
![]() | | #177 | ![]() |
![]() Join Date: Apr 2013 Location: Atlanta, Georgia
Rep Power: 1578 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,584
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() | |
![]() | | #178 | ![]() |
![]() Join Date: Feb 2009 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 503
| Not Ranked : 0 score Found the source of the funny in and out noise yesterday, sadly, it was not the 10mm bolt working loose. happily, using the catman's search widget, quickly found the apprpriate post, and have a AC pulley bearing ordered up from Azone. at least I proly caught this one in time to repair, without cracking the system open. time to search for my snap ring pliers
__________________ A democracy, in its purest form, is well represented by a group consisting of 2 wolves and 1 rabbit. Voting on what to have for lunch |
![]() | | #179 | ![]() |
| Not Ranked : 0 score Oh, Great, Just read Gro Getr's How To apparently, on the 6, Mazda put a full roll cage around the compressor......
![]() | | #180 | ![]() |
![]() Join Date: Sep 2012
Rep Power: 0 ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score So I'm now facing this problem. For a few days, the car would make this noise, like a grinding noise but really low. My daughter described it as an "airplane noise". The smell of burnt plastic was very strong as well. Anyway I took it to the shop and the guy said it was the ac compressor clutch. I found the assembly on Amazon for $80. Unfortunately I won't be here for a few days. My question is can I still drive with the clutch being in the state that it's in? I could turn off the ac and leave the windows down, but I just want to make sure I don't do any extra damage to where I would have to replace the whole compressor. |
![]() | | #181 | ![]() |
![]() Join Date: Nov 2015 Location: Rochester Hills, MI
| Not Ranked : 0 score the longer you drive it the bigger pita it will be to get the bearing off. Freewheeling it(a/c off including no defrost) will have the best odds, but once you start getting a consistent noise you are playing with fate. Based on the noise, which is definitely a bearings are gone noise. The two things you risk are 1. welding the bearing to the shaft, which makes it infinitely more difficult to get off on a 3, and borderline impossible on the 6 without removing the whole thing from the car(which then adds $ having to have it vaced and recharged) 2. the bearing seizes/lets go and you throw the belt doing who knows what damage.
__________________ "Sarcasm and shit talking are two different things. MSF offers the best advice, just delivered by sarcastic pricks, with your best interest in mind." -ThePedigree13 Silver 06 MS6 - DD stealth build - no show, all go.... '12 Abarth Challenge Car - very loud, very fast, very inconvenient to drive on the street... |
![]() | | #182 | ![]() |
![]() Join Date: May 2017
| Not Ranked : 0 score Hey Trebor, i don't know if you still get in these forums seeing that this was posted in 2013, but did this fix you did also fix the coldness of the a/c? Because that's my problem my a/c blows fine and everything, I've tried recharging it, nothing happened. So this is my last resort. Sent from my iPhone using Tapatalk |
![]() | | #183 | ![]() |
| Not Ranked : 0 score nax are you saying the air blows warm? First step is verifying the compressor is engaging. easiest way to do this is to stand near the compressor and have someone in the car turn the a/c on to full. You should hear the compressor click on/activate. If NO: then next step is to verify you have enough pressure to activate the pressure switch. You can do this with a cheap recharge kit from the parts store, the included gauge will tell you if you have the correct pressure. If its low then as you add 134 it will eventually click on when the min pressure is obtained in the system(filled). If Yes: Look at the outside 3 circle plate and see if it is spinning. It should be spinning at the same speed as the pulley. If it is going slowly, not moving at all, or randomly stops and starts spinning again(glitch) then the clutch isn't fully engaging and needs to be replaced. The coldness of the air is really a set degree value influenced by the outside air it is cooling down. The hotter it is outside the harder it is to cool the air down. The really isn't a way to make the system blow colder if it is already working properly. If you stick a thermometer in the center vents it should show around 60 degree F.
![]() | | #184 | ![]() |
| Not Ranked : 0 score I put some 134 in it and it started spinning the same speed but after a while it started to glitch so I guess new compressor Sent from my iPhone using Tapatalk |
![]() | | #185 | ![]() |
| Not Ranked : 0 score did you not even bother to read the title of this thread?
![]() | | #186 | ![]() |
| Not Ranked : 0 score I did and I tried the cheap way and it didn't work? Sent from my iPhone using Tapatalk |
![]() | | #187 | ![]() |
| Not Ranked : 0 score so you replaced the clutch? in your first post it make it sound like you were debating doing it and then instead just added 134. If you replaced the clutch hopefully you paid attention to the notes about incorrect shims in the aftermarket kits. Start a new thread and people will chime in, lets not clog up the clutch specific thread with diagnosing an a/c concern. they are fairly simply systems so depending on your symptoms there are usually only a few things to check/replace.
![]() | | #188 | ![]() |
| Not Ranked : 0 score Hello everyone - I ended up purchasing the same shims from Mazda (B25F-61-L1Y) came with 4 shims of varying thickness. When I install one of the shims with the one previously installed, the ac clutch spins, stutters, spins, etc. With only one shim the clutch is always spinning whether or not the AC is on or off (which isn't good). Combination of other shims results in similar results (AC clutch not spinning completely. Curious if anyone can offer some knowledge. Any help is greatly appreciated! |
![]() | | #189 | ![]() |
![]() Join Date: Dec 2015
NEW 2007 08 Mazdaspeed 3 & 6 TURBO ONLY AC Compressor CLUTCH KIT 124MM 6 Groove | eBay This came with everything I needed, clutch, pulley, coil, and even hardware including shims for $40. Everything went on and fit well, but when I started the car the clutch was spinning all the time. I then loosened the retaining bolt, and I could get it to not spin if I loosened it to a point, but I'm concerned that it's too loose and will fall off. So I'm assuming my spacing with the shims is not correct. That being said, this kit for $40 is a really good deal for anyone needing replacements. | |
![]() | | #190 | ![]() |
| Not Ranked : 0 score it ends up being trial and error on the shim spacing. You want it to just spin freely by hand. Some people are able to just reuse their originals, some have to go a tad thicker on the spacing. Each mfg will have a slight variance in their clutch friction surface material, but aftermarket will generally be the same or slightly thicker friction surface than oem. I ended up using the factory originals plus the thinnest one that came in my kit after just the originals caused constant engagement.
| The Following User Says Thank You to GroceryGtr For This Useful Post: | ericrlove88 (07-03-2017) |
![]() | | #191 | ![]() |
![]() | | #192 | ![]() |
![]() Join Date: Dec 2014 Location: VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 22
![]() | | #193 | ![]() |
| Not Ranked : 0 score rattling when the comp engages is a sign they bearing/clutch is on its last leg.
![]() | | #194 | ![]() |
| Not Ranked : 0 score Yup. Worked great and was the cheapest kit I could find. I bought the shins separately and did have to use some trial and error to get it right. But now it works great. Mine started as an occasional rattle but quickly grew to something that needed fixed immediately, so jump on it quick before you can’t drive it anymore. |
![]() | | #195 | ![]() |
https://m.autozone.com/cooling-heati...kit/946226_0_0 | |
![]() | | #196 | ![]() |
![]() Join Date: Jun 2018
| Not Ranked : 0 score Can u guys tell me the exact measures of the central screw in the clutch? I rly need it ![]() |
![]() | | #197 | ![]() |
![]() Join Date: Jul 2011 Location: NC
| Not Ranked : 0 score How did you wire up the stator? My compressor is still mounted, and I can't seem to figure out how to get to the wiring harness of the stator. I removed the 3 screws, but not sure how to get to the connections. |
![]() | | #198 | ![]() |
![]() Join Date: Feb 2012 Location: Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 250
Groaned at 7 Times in 3 Posts
| Not Ranked : 0 score Hi all Can anyone please post an original part number for a replacement AC pulley for the speed 3. The outer diameter is 129mm, 6 groove. My AC pulley was warped in the press as the bearing was completely seized. I'm trying to find a suitable replacement pulley in Australia. Most of the links in this thread are dead, and the ones I can find available on ebay won't ship to Australia. Thanks
__________________ - 2008 Gen1 MS3 Cobb AP ~ Autotech HPFP Internals ~ HTP 3" Intake ~ Custom Testpipe ~ Cobb RSB ~ Sticky Tires. Self tuned on E85 |
![]() | | #199 | ![]() |
![]() Join Date: May 2009 Location: Orange County, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 806
Groaned at 9 Times in 5 Posts
| Not Ranked : 0 score Here are a few to try: https://edgeautosport.com/mazda-oem-...d-6-2006-2007/ https://www.amazon.com/2007-2008-Maz...omotive&sr=1-1 I used the kit that's similar to the one on Ebay and had good results with it. But most of the aftermarket options don't make them resilient enough to handle the MS3's power output. |
| The Following User Says Thank You to Design For This Useful Post: | Spectrix (10-08-2019) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f293/c-compressor-clutch-finally-cheap-fix-153663/ | ||||
| Design's Long Term Ownership/Build Thread - Page 8 - Mazda3 Forums : The #1 Mazda 3 Forum | This thread | Refback | 09-19-2015 06:50 PM | |
| signs of bad ac clutch - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 09-19-2015 05:12 PM | |
| Bearing de poulie pour la clutch de l'air climatisé - Mazda 3 Quebec | This thread | Refback | 09-02-2015 08:59 PM | |
| Peladero del único y verdadero Mazda Team 2015 :shocky: :SonoraDinamitaStyle: - Página 11 - VelocidadMaxima.com | This thread | Refback | 06-19-2015 09:50 AM | |
| 08 Mazdaspeed 3 clattering noise : mazda | This thread | Refback | 07-02-2014 08:40 PM | |
| a/c compressor clutch tried to sneak away | TiGraySpeed6 | Mazdaspeed3/6 General Discussion | 28 | 09-03-2014 06:21 AM |
| Ac Compressor Clutch Fail | bc2292 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 8 | 05-07-2014 09:55 AM |
