  • 1 Post By Vader
 Old 08-26-2015, 09:22 PM   #1
GR4YF0X's Avatar
Posts: 4   (View Stats)
GR4YF0X is an unknown quantity at this point
Default Car won't start and dealership claims starter and CPE hpfp are the cause
I have had CPE hpfp for approximately 6 months. Only other mod is SRI. The story: got in to drive it to work, turned the key, and it was silent for approximately 3 seconds before turning over. (Normally it turns over instantly) On the way to work it was on empty. (The empty light turned on a couple miles from my house the night before) Got to a gas station, put in 4 gallons of 92 because I didn't think it could make it to a gas station that had 93. Tried to turn it back on and it wouldn't do anything. No sounds. Dash and everything light up, doesn't attempt to turn over. Took the battery to autozone, it tested good. Put it back in, car started but was idling weird without ac on. Drove it to Firestone, they tested the battery again, starter, and alternator. According to them, they were all good and it turned on fine for them every single time. Left the shop and it ran like normal for a day. Then it wouldn't start again. Hitting the starter, it will turn over but won't catch. Got it towed to a Mazda dealership and they're telling me my starter and hpfp are bad. They did not know what a CPE hpfp was. They want $1,200 parts and labor. I live in Richmond, VA and any help would be greatly appreciated. Thoughts?
GR4YF0X is offline   Reply With Quote
 Old 08-27-2015, 07:18 AM   #2
Vader's Avatar
Posts: 1,651   (View Stats)
Vader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the world
Groans: 45
First of all, don't let those fucks take your HPFP.
Sounds like you may have a faulty ground wire.
kritz likes this.
Originally Posted by mikelevi View Post
...When you have 600 lbs of faggot in your car, you are much slower than someone with 10 lbs of dick.
Vader is offline   Reply With Quote
The Following 7 Users Say Thank You to Vader For This Useful Post:
chaser27 (08-27-2015), Code Monkey (08-27-2015), cyclist20 (08-27-2015), daafisch (08-27-2015), littleloogy (08-27-2015), MS3Shadow (08-27-2015), snailD (08-27-2015)
 Old 08-27-2015, 08:22 AM   #3
dan7225's Avatar
Posts: 511   (View Stats)
jump starts fine?
probably just starter
 Old 08-27-2015, 08:55 AM   #4
Tap starter wires with hammer, it will start up. Common.
snailD (08-27-2015)
 Old 08-27-2015, 09:12 AM   #5
littleloogy's Avatar
Posts: 4,005   (View Stats)
stealership just wants to steal that bad ass CPE pump from your car. Fuck those guys,
Sent from my iPhone 6
 Old 08-27-2015, 11:23 AM   #6
GR4YF0X's Avatar
Originally Posted by dan7225 View Post
jump starts fine?
Does not jump start.
It starter goes, but does not turn on.
Last edited by GR4YF0X; 08-27-2015 at 11:23 AM. Reason: MSF Database - Automerged Doublepost
 Old 08-27-2015, 11:25 AM   #7
What is the PSI Key On Engine Off?
(using an AP)
 Old 08-27-2015, 11:26 AM   #8
GR4YF0X's Avatar
Ground wire looks fine and I used a terminal brush to make sure contacts were good.
(using an AP)
I don't have an accessport. Anything else I can use to read that?
Last edited by GR4YF0X; 08-27-2015 at 11:26 AM. Reason: MSF Database - Automerged Doublepost
 Old 08-27-2015, 11:28 AM   #9
OBDII Bluetooth adapter and the Torque app on a phone or tablet.
 Old 08-27-2015, 11:33 AM   #10
Doubt CPE FP and starter went out at the same time.
You have:
1) slow to turn over then start
2) no turn over
3) turns over and starts
4) turns over and does not start
Sounds like the little ground wire on the hpfp deal is loose, or ground is corroded up and bad overall.
Vader (08-27-2015)
 Old 08-27-2015, 11:35 AM   #11
patABQ's Avatar
Posts: 164   (View Stats)
patABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond repute
Check the whole length of wire to the starter. Sometimes the wire can corrode inside the insulation and the starter will check fine but the wire will not carry enough current to fully engage the solenoid and starter. However, the "no sounds" is indicative of no current to the solenoid. You should at least hear some clicking of the solenoid.
Get it away from the dealer.
Silver 2012 MS3 , 2007 Corvette Z06 , 2008 Hayabusa
MS3 Mods
Sure PMM, DMM, REM (all TORQ S3 Street in Stealth Black), Sure Sway Bar, JBR Sort Shifter
Cobb - AP V3 SRI, TIH, 3-port Boost Controller, SS 3” DP
Corksport TMIC
CP-E full HPFP with warranty
All Freektuned with two tunes, one for 15psi and another at 20psi
patABQ is offline   Reply With Quote
 Old 08-27-2015, 11:41 AM   #12
It is super common for the connectors to have corrosion. The fix, as I first posted, was to tap em.
kritz (08-27-2015)
 Old 08-27-2015, 11:52 AM   #13
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
Check the ground that connects to the HPFP, that little wire fucks with a lot of people. While you're at it check the other chassis grounds too.
The Following User Says Thank You to daafisch For This Useful Post:
Raider (08-27-2015)
 Old 08-27-2015, 11:54 AM   #14
Vader's Avatar
Groans: 45
There are like 3 ground wires, FYI, not just the battery GND.
There is one on the HPFP.
A weird little sense one, on the starter itself.
And a few others I can't remember.
Your issue, is almost assuredly a faulty connection of some kind. All the info you have provided, points to a faulty connection.
The Following User Says Thank You to Vader For This Useful Post:
Raider (08-27-2015)
 Old 08-27-2015, 11:55 AM   #15
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Double tap. Get some electrical contact cleaner spray as well, but best practice is to replace the connectors and or wire.
Nator is what it does.
Raider (08-27-2015)
Starter problem? mrjoshyman MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 03-27-2015 08:15 PM
GM gets 75 more ignition-switch claims; 4 more death claims approved Haltech Automotive News 0 02-19-2015 03:00 PM
Starter issues plak424 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 02-25-2013 06:40 PM
Installed HPFP and now car won't start buckeyepost Mazdaspeed3/6 General Discussion 19 08-31-2011 07:53 AM
Auto Starter? Birdie MazdaSpeed 3 - Engine, Transmission & Driveline 2 06-07-2010 10:37 AM
Page generated in 0.34919 seconds with 28 queries
