 Old 02-09-2009, 10:19 PM   #1
Phantom's Avatar
Posts: 313   (View Stats)
Phantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud of
Default CPE PNP Issue
I have a CPE PNP harness and the other day I was getting a IAT high voltage output CEL and my traction control freaked out. (Turned on and off and on and off making the car jerk then the light stayed on).
I checked out the ECU and noticed some moisture/water in it. (In the connector with the pins) Cleaned it out and disconnected the PNP. I had a look at the PNP and noticed that the back of the connector that goes into the ECU is totally open to the engine environment. Thus any water/moisture can get into the connector and ECU harness.
Is this normal? Is there something I can do to protect the back of the connector?
I am thinking of just keeping the PNP and SB removed during the winter months. I really don't need it until the spring/summer/fall months anyways.
Any thoughts?
Phantom is offline   Reply With Quote
 Old 02-20-2009, 02:29 PM   #2
btkrausen's Avatar
Posts: 48   (View Stats)
btkrausen is just really nicebtkrausen is just really nicebtkrausen is just really nicebtkrausen is just really nice
http://www.mazdaspeedforum.org/forum/foru...p-harness.html
-bryan
CP-E CAI | CP-E FMIC | CP-E Standback v2 | CP-E PnP | CP-E Flash | CP-E SSQV BOV Kit | Cobb STS | Cobb Shifter Weight | SU MM | SU Test Pipe | Boost Gauge | Black out Side Markers | SU Bushings | DashHawk
To Be Installed: DNP Turbo Manifold
btkrausen is offline   Reply With Quote
 Old 02-20-2009, 03:01 PM   #3
stevessvt's Avatar
Posts: 163   (View Stats)
stevessvt has a reputation beyond reputestevessvt has a reputation beyond reputestevessvt has a reputation beyond reputestevessvt has a reputation beyond reputestevessvt has a reputation beyond reputestevessvt has a reputation beyond reputestevessvt has a reputation beyond reputestevessvt has a reputation beyond reputestevessvt has a reputation beyond reputestevessvt has a reputation beyond reputestevessvt has a reputation beyond repute
edit
stevessvt is offline   Reply With Quote
Issue #1 At Press! Haltech Automotive News 0 11-06-2008 06:43 PM
Overboosting issue BoostedBlack6 MazdaSpeed 6 - Engine, Transmission & Driveline 3 10-27-2008 02:19 PM
WOT BOX Issue riccitelli MazdaSpeed 3/6 - ECU Computer Tuning 9 08-16-2008 10:07 AM
Quality issue w/ the SRI? Victor MazdaSpeed 3/6 - ECU Computer Tuning 54 07-11-2008 09:55 AM
cp-e DP Issue Speedy3 MazdaSpeed 3/6 - Turbo Induction 11 05-29-2008 11:49 PM
Page generated in 0.24838 seconds with 22 queries
