 Old 02-12-2020, 12:55 PM   #1
Barra's Avatar
Posts: 3   (View Stats)
Barra will become famous soon enough
Default Cranks, doesn't start after carpet removal
I'm not sure what I did here. A few weeks back I had a insulated mug roll off the front passenger seat, popped open , and emptied an entire coffee on the passenger carpet. After a week of smelling like rotten milk I pulled up the carpet to find it has flowed all the way to the back and soak into the thick underfoam of the carpet. I pulled the seats, center console, and the entire carpet out to clean them off and wiped down the entire floor pan both driver and passenger side. I was realized halfway through wiping it down that the battery was still connected but I was only spraying 409 on the floor pans and didn't spray any electrical connectors.
I let everything dry out for 4 days then reinstalled everything. The car powers on fine, all dash electronics work fine. Car turns over but does not start. Fuel pump fuse is intact. CEL after a few seconds of powering on blinks, so it seems like a misfire and I can smell fuel at the tailpipe. I'm at a loss however as to anything I could have done under the carpet that would cause the car not to fire. Any ideas?
Barra is offline   Reply With Quote
« KR super high | - »
Ms6 cranks but no start eroler1 Mazdaspeed3/6 General Discussion 2 11-08-2018 11:50 AM
07 Mazdaspeed 6-cranks but doesn't start Ctown2Ctown MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 11-11-2017 03:24 PM
MS6 Cranks but won't start HELP!!! KingJames MazdaSpeed 6 - Engine, Transmission & Driveline 16 03-23-2015 06:38 AM
Car cranks, won't start 15driley15 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 04-23-2014 04:51 PM
Car cranks but doesn't start after valve clean InfamousSpeed6 Mazdaspeed3/6 General Discussion 11 11-29-2012 06:17 PM
Page generated in 0.27495 seconds with 25 queries
