 Old 07-03-2012, 02:45 PM   #1
j.ferger's Avatar
Posts: 11   (View Stats)
j.ferger is on a distinguished road
Default Help Car Won't Start
Please help, Car would not start several days ago after it was running for two hours, jumped by AAA, they said battery tested bad, but altenator fine, drove home, replaced old battery with new, next daydriving and starting fine all day,next day no start, returned battery and battery tested fine still no starting after replacement of battery.
When trying to start slight engine cranking then whining, seems to be no firing happening, re tested battery, voltage @ 12.5, store tested cca @ 700
Any suggestions would be helpful.
j.ferger
j.ferger is offline   Reply With Quote
The Following User Says NO Thank You to j.ferger For This Un-useful Post:
jomc111 (07-03-2012)
 Old 07-03-2012, 05:59 PM   #2
DamagedGoods's Avatar
Posts: 304   (View Stats)
DamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the world
Some more details may be necessary.
12.5 volts sounds about right, probably isn't the battery.
Have you attempted to start the car again while being boosted?
What do you mean by whining? Like the Bendix in the starter is whining?
2007 Mazdaspeed 6 - Bolted, Methed, Tuned
DamagedGoods is offline   Reply With Quote
 Old 07-04-2012, 06:10 AM   #3
j.ferger's Avatar
Thanks for the response from Damaged Goods.
Retested battery showed 12.26 v,whining or whiring sound maybe one turn of engine then nothing. Rechecked all connections near battery, main grounds have continuity, trying to check connections at starter but difficult to see and reach. Why are all the electrial connections wrapped with electric tape? Thanks
 Old 07-04-2012, 06:31 AM   #4
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
clean the battery terminals?
07 MS3
The original Genpoo Hater
 Old 07-04-2012, 07:04 AM   #5
bigriver's Avatar
Posts: 1,123   (View Stats)
Maybe check "ENG BAR" fuse.
I used this slot when I tapped it to power my Guardian Angel. After I removed the GA, I didnt put the fuse back and the engine wouldnt turn over. It just made the whirring noise. When i put the fuse back in it started right up.
bigriver is offline   Reply With Quote
The Following User Says Thank You to bigriver For This Useful Post:
tddvrrn (07-04-2012)
 Old 07-04-2012, 07:06 AM   #6
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
Bang/tap on the starter when trying to turn it over.
With someone around of course
 Old 07-04-2012, 09:21 AM   #7
j.ferger's Avatar
Thanks Chimmike, bigriver, pzr2874,
Update: tested battery during start attempt no load @ 12.16 load test voltage droppped to 7.56v, tried tapping starter during cranking, checked Engine fuse and all other fuses, no joy, no start. Should a new battery drop that much in voltage with load,or is this an indication of a bad cell or two in the battery?
Thanks
 Old 07-04-2012, 09:46 AM   #8
pzr2874's Avatar
Groans: 146
Ask autozone to borrow a new battery while you switch em out outside.... voila... issue solved. And a $110 lighter LOL
 Old 07-04-2012, 11:16 AM   #9
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
have you checked for spark yet? if it's turning over it's probably not the starter. i'd try the battery swap at the place you bought the battery. is your ground clean and tight?
 Old 07-04-2012, 06:35 PM   #10
j.ferger's Avatar
Hi again, Replaced battery, replaced spark plugs, streched coil springs, cleaned battery terminals and cable connections, engine turns over better after battery change but no fire or spark so no joy on starting, what else LOL could have I screwed up or has failed?
Thanks everyone
 Old 07-04-2012, 07:10 PM   #11
pzr2874's Avatar
Groans: 146
What kinda fuel pressure you getting?
 Old 07-05-2012, 10:17 AM   #12
tddvrrn's Avatar
Groans: 103
did you check for spark? take out the plugs and lay them on the block. have a friend turn it over and see if there is an arc between the plugs and the block.. just because there are new plugs in it doesn't mean they're getting a current..
checking FP would be a good idea as well..
have you checked all your fuses? maybe a fuel pump fuse has blown?
no CELs?
The Following User Says Thank You to tddvrrn For This Useful Post:
ak_spray (07-29-2012)
 Old 07-05-2012, 12:18 PM   #13
bigriver's Avatar
OP - have you done any mods recently?
 Old 07-05-2012, 03:38 PM   #14
j.ferger's Avatar
Thanks for all the posts, will check spark on new plugs, no knowledge or tools on how to check fuel pressure, but mazda put in new fuel pump a little over a year ago, car is stock. All fuses test and look ok.
thanks
j.ferger
 Old 07-05-2012, 03:42 PM   #15
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
thanks
j.ferger
Do you have a Cobb AP? If so Check HPFP Destination FP. Should be above 400 before starting.
Pickles Tune in progress
 Old 07-06-2012, 08:27 AM   #16
bigriver's Avatar
Did you gap the new plugs properly?
Which plugs did you get?
 Old 07-07-2012, 10:26 AM   #17
j.ferger's Avatar
Pulled plugs, I have spark in all plugs, plugs gapped @ .030, starter turns engine over, still no starting
 Old 07-07-2012, 10:38 AM   #18
pzr2874's Avatar
Groans: 146
Check fuel. Borrow an AP.
 Old 07-29-2012, 09:22 PM   #19
ak_spray's Avatar
Posts: 552   (View Stats)
ak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the world
Did you get this figured out I'm having a similar issue.
07 MS3 Sport
CPe: Stage2 RMM, XcelNANO Short Ram, Nviscid TIP, HPFP
SURE: AGS ATOM Shift Knob, ShortCut, CounterShift, TB/IM TIG, Injector Halos (Coming Soon)
JBR: RSB
Cobb: Accessport
Corksport: TMIC
CNT: Catted Downpipe
ak_spray is offline   Reply With Quote
 Old 07-30-2012, 05:14 AM   #20
j.ferger's Avatar
Thanks for help. Had car towed to shop, compression test showed no compression, looks like timing chain slipped or failed, looking at new valves, vvt, chain and tensioner.
Not happy news.
The Following User Says Thank You to j.ferger For This Useful Post:
ak_spray (07-30-2012)
 Old 07-30-2012, 06:23 AM   #21
ak_spray's Avatar
Yeah that's not good, hope all the best for ya man.
07 MS3 Sport
JBR: RSB
Cobb: Accessport
Corksport: TMIC
 Old 07-30-2012, 06:37 AM   #22
Will fuck up ur day
Chimmike's Avatar
Groans: 433
chains don't just slip or fail without giving you some sort of sign ahead of time...............any odd rattling on startup before? any strange noises?
Wonder if your VVT failed, then you just kept driving it and it failed catastrophically....
07 MS3
« P2119 | Odd Rattle »
Please Help - Car Won't Start! Rampage MazdaSpeed 6 - Engine, Transmission & Driveline 5 06-24-2012 07:56 PM
Car will not start Mikey MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 09-08-2011 04:54 AM
KTM X-Bow will start at $88,500 in the U.S. Haltech Automotive News 0 03-04-2011 09:10 AM
If you could start over Whiteboy Mazdaspeed3/6 General Discussion 28 02-14-2011 06:29 PM
Where to start on the MS3 Guati91 Mazdaspeed3/6 General Discussion 8 02-09-2011 06:51 PM
Page generated in 0.39575 seconds with 27 queries
