  • 1 Post By Dano
  • 1 Post By Dano
 Old 07-23-2013, 10:56 PM   #1
ciezczak1's Avatar
Posts: 416   (View Stats)
ciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the world
Default High knock super rich afr
i did a wot log got 4.64 degrees of knock and have been getting 8.8 afr i wanna say its the injector seals or something
Second opinions?
GT3076/ catless dp/ FMIC/ 3.5" CP-E Intake/ 3" Exhaust/autotech internals/ built block/ 3-port/denso itv22/ 6th-port
ciezczak1 is offline   Reply With Quote
 Old 07-24-2013, 12:49 AM   #2
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Second opinions?
Umm maybe post the log so we can look? The afr of 8.8 is probably due to the knock detected and the ecu shit more fuel in.
Pickles Tune in progress
 Old 07-24-2013, 09:59 AM   #3
ciezczak1's Avatar
Alright will post one soon
 Old 07-24-2013, 10:01 AM   #4
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
yes logs or it didn't happen...just lick pics
Rokusek (07-24-2013)
 Old 07-24-2013, 10:14 AM   #5
ciezczak1's Avatar
here is a log i just did and i also forgot to mention that i also have a rich idle and part throttle is becomes rich as well. and random over boost. ill post up another one.
datalog1.csv
 Old 07-24-2013, 10:19 AM   #6
I am assuming this car is tuned from the mod list? 8.8 sounds very rich for any tune even under KR. Post a log.
 Old 07-24-2013, 10:19 AM   #7
Trail of Fail
Dano's Avatar
with that speed I am going to immediately assume you are losing traction and rich AFR would be normal with DSC active.
even without DSC active SWAS will detect slight steering wheel movement and richen up afr to cut power.
do a 4th gear log.
edit: and yes even idle you are at 13AFR which is rich. LTFT is ~zero so I might assume this was a fresh flash on the ECU with STFT maxed at the amount of fuel it can pull.
your maf cal is waaaay off.
 Old 07-24-2013, 10:20 AM   #8
here is a log i just did and i also forgot to mention that i also have a rich idle and part throttle is becomes rich as well. and random over boost. ill post up another one.Attachment 119193
I think you should post all your mods. The boost and MAF levels don't have much sense.
EDIT: On top of this your HPFP pressure is dropping under boost (due to the excessive boost down low) and it looks like you are getting a cut as well.
I would not do any more logs before this is sorted out because on a stock block this is a clear recipe for venting it.
Cheeto (07-24-2013), Dano (07-24-2013), Mike@Stratified (07-24-2013), Rokusek (07-24-2013)
 Old 07-24-2013, 10:20 AM   #9
ciezczak1's Avatar
do a 4th gear log.
speed6 bro and ill go do a 4th gear log
 Old 07-24-2013, 10:23 AM   #10
Trail of Fail
Dano's Avatar
ok "bro" see my other post.
your maf cal is way off. ecu is pulling 25% fuel at idle.
and lex is right you are about to vent your block with 30psi @ 3500RPM
Rokusek likes this.
 Old 07-24-2013, 10:25 AM   #11
Read what I said before it blows.
Cheeto (07-24-2013), Rokusek (07-24-2013)
 Old 07-24-2013, 10:29 AM   #12
Trail of Fail
Dano's Avatar
in before OPs next post is this.
this would explain the uber rich AFR due to bad maf cal.
Last edited by Dano; 07-24-2013 at 10:29 AM. Reason: MSF Database - Automerged Doublepost
 Old 07-24-2013, 10:36 AM   #13
ciezczak1's Avatar
alright need to update sig but mods are 3.5in intake, built block, stock turbo, 3 in catless exhaust, grimmspeed 3port boost controller, fmic, denso v24 spark plugs fp internals think thats all
 Old 07-24-2013, 10:42 AM   #14
Trail of Fail
Dano's Avatar
whatever you do, do not go WOT again until your boost is under control...even on a built block.
from your logs you need a complete tune and I would get back to spring pressure only until the issues are resolved.
Rokusek likes this.
ciezczak1 (07-24-2013), Lex (07-24-2013), Rokusek (07-24-2013)
 Old 07-24-2013, 10:45 AM   #15
ciezczak1's Avatar
alright thanks ill see if i do more maf cal it was the same map as before the built block and no problems and ill see if that will change anything.
 Old 07-24-2013, 10:45 AM   #16
Dano's correct, your boost control is probably setup incorrectly. The car needs a tune badly.
 Old 07-24-2013, 10:52 AM   #17
Trail of Fail
Dano's Avatar
same intake on the old map? If I were to make a guess it looks like an incorrect multiplier was applied to a 2.75 maf curve to create the 3.5 and it was over scaled.
IIRC lex has a ton of multipliers posted for various intakes that you could start with or maybe it was just maps with starter maf cals.
I think (don't quote me) but for me going from OEM to 3.5 was a 1.65 multiplier for pump gas which got me real close.
Edit: you can quote me it was 1.67 with some tweaking at WOT
 Old 07-24-2013, 10:56 AM   #18
ciezczak1's Avatar
it was the same intake didnt do any tweaks before and after the build
 Old 07-24-2013, 11:06 AM   #19
Mike@Stratified's Avatar
Posts: 1,119   (View Stats)
Did you have the 3-port before the build? Is it currently in 3-port mode? Was it before the build?
The Following User Says Thank You to Mike@Stratified For This Useful Post:
 Old 07-24-2013, 11:15 AM   #20
ciezczak1's Avatar
Yeah I did have it before the build and it is set in 2 port and the third as the bleeder
 Old 07-24-2013, 11:25 AM   #21
Trail of Fail
Dano's Avatar
pull the power lead to your EBCS and carefully test by giving it some gas and monitoring boost. if its plumbed correctly you will hit around 10psi max IIRC on a K04 and you will know you are good to start tuning AFR and won't blow the motor up. if boost still skyrockets then you have a line off to the WGA or other plumbing issue.
if you are catless it might creep up at WOT as RPMs rise but shouldn't get out of control but its something to watch.
KR Spike/Super rich at WOT sidekick MazdaSpeed 3/6 - ECU Computer Tuning 30 07-26-2012 05:43 PM
Rich KnocK? kahunab14 MazdaSpeed 3/6 - ECU Computer Tuning 7 04-16-2011 08:36 AM
rich knock? Wenis Prinkle
Cobb ATR Support
41 09-01-2009 06:19 PM
Super rich may avoid super expensive cars because of bad image Haltech Automotive News 0 10-02-2008 06:10 PM
Page generated in 0.40525 seconds with 25 queries
