 Old 11-19-2018, 10:13 AM   #1
njdurkin's Avatar
Posts: 68   (View Stats)
njdurkin is an unknown quantity at this point
Default High voltage now struggling under heavy throttle
I had an alternator fail on my speed6. It let voltage get up to 17v. Fried my battery and burnt my headlights out. I have new alternator, battery, and headlight bulbs. Everything seemed okay except now it is stuttering when trying to accelerate heavily. It feels like it is missfiring or just losing power for just a half second then good for a second then another burp etc. I have attached my datalog. Can't figure out what the problem is. With the high voltage I am thinking I might have burnt up a sensor but I don't know which one.
Be careful when looking at the datalog because I did not do a typical pull. I was on and off the accelerator a couple of times.
njdurkin is offline   Reply With Quote
 Old 11-19-2018, 11:01 AM   #2
Posts: 2,826   (View Stats)
Try to get us a clean log with WOT from 3,000 up through and past the cut/recovery situation and edit the log to remove everything except that 3K to and past the cut.
Question: Have you done anything with your spark plugs recently? What brand, type, mileage and how are they gapped? Has anything else changed recently beside what you have described?
 Old 11-19-2018, 11:07 AM   #3
njdurkin's Avatar
I will upload 3rd gear wot from 3krpm later. No nothing has been done to spark plugs or anything. Only what o have described above.
 Old 11-20-2018, 09:02 AM   #4
njdurkin's Avatar
Okay I uploaded a 3rd gear pull from 3k rpm up close to 6k. It was stuttering and sputtering the whole time once I got to wot so it actually took a while to get up to speed.
 Old 11-20-2018, 11:35 AM   #5
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Other than low boost nothing jumps out in that log. I'd replace the plugs just because they're cheap and see if anyhing changes. Any pending MILs.
 Old 11-20-2018, 11:39 AM   #6
njdurkin's Avatar
Yes the low boost has been an issue for a while. Still cant figure that one out. I dont see anything either. I'm at a loss. I guess I just have to start throwing parts at it. Idk what else to do.
 Old 11-20-2018, 11:47 AM   #7
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Yes, throw parts at it.
Or even better, perform a boost leak test. Not just "I checked everything to ensure it was tight". That wont cut it. Not even close.
Check your EBCS to ensure the nipple on the line didn't break off.
It can feel overwhelming when you don't know what's wrong. Take your time and check one thing at a time to methodically eliminate possible causes of your issue.
Search this site and you will find many posts related to your problems.
 Old 11-24-2018, 11:26 AM   #8
njdurkin's Avatar
After changing spark plugs I no longer have lost of power under heavy throttle as described above after my alternator failed. I still have low boost numbers that I've had that for quite a while and is probably do to boost leaks. I have yet to buy an air compressor and other necessary items to perform boost leak test.
 Old 11-24-2018, 11:39 AM   #9
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
just a note.. super low ECTs, you prolly wanna see 185+ before your oil is even close to temp.
94 M
MS6
IS350
Fuel rail high pressure sensor low voltage ccspeed3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 10-24-2014 05:24 PM
Honda China struggling with high-end Accord because Chinese covet German cars, too Haltech Automotive News 0 07-06-2014 07:20 AM
07 Speed6 falls on face around 5000 rpm as well with heavy throttle. Please help. Ecamp2009 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 04-03-2013 09:08 PM
High LTFT at throttle . pinggoy MazdaSpeed 3/6 - ECU Computer Tuning 6 09-29-2012 09:13 PM
Frankfurt 2009: Smart + Tesla + Brabus = High Voltage Haltech Automotive News 0 09-21-2009 06:10 PM
Page generated in 0.28094 seconds with 25 queries
