![]() Join Date: Jan 2012 Location: San Diego, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 124
(Thread Starter) | Not Ranked : 0 score I was driving in to work today and I got on it. after I slowed down at a light almost at my work locatin, I started hearing a faint knocking sound, like a diesel tractor. it got louder. It modulated with my pedal. FUCK, that sound is me. I drove into work about a 1/4 mile while staying out of boost Now I'm at work and I don't know what to do. I'm 18 miles from home. It's about 40F, I'm running exactly what my signature says (but my last fill-up was with BP 93 octane) and my monthly pull logs from just a week or so ago show 1600-1700 PSI on the stock pump. I've never had a car that did this, but it sounds like a dead cylinder. I've attached a wav-file recorded from my phone while my coworker stood over the open engine while it idled. I moved the R's to about 2K RPM so the knocking is more noticeable (you can hear that around 15 seconds in the recording). the car starts OK (I stopped and restarted), though very slightly slower than usual. I don't know that to think yet and I don't know what to do? current thoughts are: best-case, maybe a plug wire came lose or a plug went bad somehow and I'm not firing on one cylinder? worst-case, I blew a gasket or something interfered or got destroyed by detonation. maybe the cause was a stock HPFP that failed in the past 2 weeks since my last log or maybe the 40F temp just wasn't well characterized in the Cobb 93octane maps or maybe just some fucker at BP decided to pump me some shitty gas. well, I'm probably only going to be able to blaime myself for not dialing the car back to 91octane, but I've been logging a lot all summer and fall and haven't seen any KR above 0.35 to 0.7, so oh well. I'm afraid to run it more. should I tow it home? should I tow it to the dealership? I've got 53K miles and the mods shown in my sig, so if I show up at the dealership, should I first unmod the intake and return the maps to stock with the AP? I think they saw the intake the last time I was in for oil/rotation, but they've always been pretty cool and even told me the mod was fine (before I did it) and safe. should I start it up and try to get some kind of useful log data from my AP? advice would be appreciated.
__________________ Forget coffee...I get my morning boost in 4th at 5K! 2008 Black Mica MS3 Mazda RX-8 50mm ET 18"x8" Dupli-color Graphite/Clear with 245/40/18 Continental DWS No-season Tires CS SRI | CS TIP | TMIC | HPFP CP-E RMM JBR SSP (30%) | JBR SSB | JBR RSB Koni Yellows on stock springs |
![]() Join Date: Sep 2011 Location: Croatia (Europe)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 265
| Not Ranked : 0 score Clutch pedal vibrating? Sorry man but it sounds like a bent rod...
__________________ 06 MS6, Versatuner, Stratified Tuned BNR Stage 3 turbo, Eagle con. rods, HTP Full 3" intake + AEM DryFlow filter Autotech HPFP internals, Forge V1 BPV Custom 3" cat-back with stock mufflers, M2 3" catless Downpipe Grimmspeed EBCS + Stratified Boost Dial, 3BAR BOSCH MAP NGK Iridium IX one step colder plugs, CPE SafeSeals & studs Custom FMIC with 2.5" piping and Treadstone TR8 IC SnowPerfomance WMI, Stratified Guardian Angel Eibach pro kit lowering springs |
| The Following User Says Thank You to kish89 For This Useful Post: | rednofive (11-02-2012) |
![]() Join Date: Apr 2011 Location: Weston, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,511
Groans: 39
| Not Ranked : 0 score You really just take a gamble with these motors Sent from my balls via my penis
__________________ 2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold 2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs |
| The Following User Says NO Thank You to G26 For This Un-useful Post: | tddvrrn (11-02-2012) |
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
Modding ANY engine is a gamble.
__________________ | |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 168
| Not Ranked : 0 score Damn, that's rough... I would not run it, that just sounds like trouble. Demod, flash the stock tune, and tow it. @phate @kabobulate @dbrier do you guys have any better suggestions?
__________________ __________________ 2011 MazdaSpeed 3 RichTuned | Cobb SRI | Cobb TIH | SU TMIC | CS Racepipe | CS Downpipe | CS TMM Insert | KMD 2.1 | CPE Stage 2 RMM | ITV 22's | Sent using VTEC |
| The Following User Says Thank You to vtekken For This Useful Post: | rednofive (11-02-2012) |
Groans: 39
| Not Ranked : 0 score Lol, I'd say it being turbo increases the odds of something happening. Sent from my balls via my penis
| Not Ranked : 0 score That doesn't sound healthy, sounds like something in the bottom end :/ Does it run roughly, and can you feel any vibration in the clutch pedal?
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. |
No codes of any kind from the ECU (I just checked). Runs smoothly. I mean that it starts great and idles fine, but I think I recall from my short limp to work that it doesn't accelerate very well (I was keeping the car between 10-20" vacuum, so no boost at all). sounds exactly like this video, but not quite as loud: https://www.youtube.com/watch?v=_0CBQcccLDM
__________________ Forget coffee...I get my morning boost in 4th at 5K! 2008 Black Mica MS3 Mazda RX-8 50mm ET 18"x8" Dupli-color Graphite/Clear with 245/40/18 Continental DWS No-season Tires CS SRI | CS TIP | TMIC | HPFP CP-E RMM JBR SSP (30%) | JBR SSB | JBR RSB Koni Yellows on stock springs | |
| Not Ranked : 0 score I see in your sig that you are running an ots map with 25% e85. Have you noticed your afr's when running that mix? |
Last night I was watching AFR's and boost for fun. I was hitting 11.3-11.4 under WOT or at least very high WOT. boost was 15 to 17PSI, exactly like Cobb says it should be for my car/mods/map. I think I got too close to red-line in third gear and cold-air + and stock fuel-pump bit me. un-believable.
| Not Ranked : 0 score +1 about feeling vibes in the clutch pedal bent rod will (usually) translate to the crank & through the clutch. It's a pretty distinct feeling.
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | rednofive (11-02-2012) |
![]() Join Date: Aug 2009 Location: Trevose, PA
Rep Power: 7488 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,940
Groans: 224
| Not Ranked : 0 score That's a bent rod amigo. Ive driven over an hour on two different engines with bent rods. I won't say you can make the trip because it's running on borrowed time
__________________ MS3 has been retired to daily duty Project 1G; 1991 Eagle Talon TSi. 63MM Borg Warner Powered, Corn-Fed, 2.4L Long Rod Monster Under Construction Stock Turbo-Stock Engine Grand Champion of the World! 501WHP & 569WTQ (PERM Tuned, 93 OCTANE PUMP GAS K04 W/N2O!!) NATOR PA |
| Not Ranked : 0 score Pete, if you decide to tow it home and do some diag, I'll drive over to help out. My first thought was spun bearing
wow, you are truly a generous soul. I don't want you to have to do that, but I appreciate any coaching you can give. I will likely tow it home and swap out the intake, just in case, then restore the ECU to full-stock. I believe this car has a 60K mile warranty on the drivetrain and I've done almost nothing to it and Mike at Tom roush is pretty cool. I'm at 53K miles. Think my odds are decent it'll be covered? I can imagine no reason it wouldn't be.
| Not Ranked : 0 score There's no harm in trying to get it covered.
![]() Join Date: Apr 2010 Location: Des Plaines, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 234
Groaned at 53 Times in 17 Posts
| Not Ranked : 0 score https://www.youtube.com/watch?v=NsCb...eature=related Most likely that is your issue. If that car feels to be running ok but have the knock, sounds like a rod knock. Edit: It looks like @phate is right, as usual |
| The Following User Says Thank You to dead-zone For This Useful Post: | rfinkle2 (11-02-2012) |
![]() Join Date: Mar 2010 Location: Indy
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 612
| Not Ranked : 0 score My weekend is somewhat open. I'll PM you my number and come out to help with whatever you need. I would tow it and demod since you are under 60k. Don't give them an excuse to screw you. Not even a motor mount.
__________________ 2012 CWP MS3: Tuned by Phate - 50/50 E85 | Cobb AP | SURE Intake, TIP | Corksport Racepipe, TMM Inserts | ITV22's | AT Intl's | ACT Sprung 6Puck & Prolite Flywheel | CP-E Stg2 RMM | JBR SSB, EGR Plate 2008 Silver MS3: Sold |
| The Following User Says Thank You to kabobulate For This Useful Post: | rednofive (11-02-2012) |
Groans: 136
| Not Ranked : 0 score If the only engine mods you have are intake/TIP and AP, stock out and take it to a dealer. I wouldn't run that engine any more personally; have it towed. I agree with Clint, a noise that loud and muffled sounds like something deep down in the engine, and something big.
![]() Join Date: Mar 2012 Location: Franklin IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 466
| Not Ranked : 0 score If you need another set of hands this weekend I'm free to come up.
__________________ 2012 Black Mica - AP, JBR SRI, JBR TIP, JBR RMM, JBR EGR Delete, Res Delete, AutoTechs, UR TP - Red Rally Armors, CS CF Hood Scoop |
| The Following User Says Thank You to bwagers For This Useful Post: | rednofive (11-02-2012) |
![]() Join Date: Jun 2012 Location: Indianapolis, IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
| Not Ranked : 0 score I am not good at diagnosing issues but I have the garage open if you need some shelter.
__________________ 2008 Silver MS3: Cobb AP - Corksport SRI & TIP - AT Internals -JBR 88 RMM -JBR SSP & Solid Bushings-JBR Rear Sway Bay -TurboXS Downpipe & Racepipe -ITV22's [SIGPIC][/SIGPIC] |
| The Following 4 Users Say Thank You to BBartley For This Useful Post: |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,488
Groans: 35
| Not Ranked : 0 score That sucks man. I don't have any additional input, these other guys are all way more knowledgable than me, but stocking out and towing it in sounds like the best plan.
__________________ 2008.5 Black Mica MS3 Cobb AP and 30% E85 Dizzy Tune - Cobb SRI - CP-e RMM - JBR SSP & Solid Shifter Bushings - E4 heavy shift knob - Denso ITV22 plugs - 6000K HID lows - 3500k HID fogs - Ford XT-M5-QS Tranny fluid - RX8's (PC'd Anthracite) - Rubber hatch tray It's not my fault I'm this way, I was homeschooled. |
| Knocking sound on driver's side | DylanFYHN | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 40 | 10-03-2012 11:48 AM |
| Knocking/ clicking sound from under car/ driver side | Zbrit00x | Gen2 MS3 General Discussion | 8 | 08-23-2012 09:16 AM |
| full motor mount install.... now have knocking sound | peter_parker8740 | 2010 MS3 - Engine, Transmission & Driveline | 2 | 06-20-2012 06:21 PM |
| Knocking sound w/ video... | RiceBurn2.3T | CX-7 > Issues & Troubleshooting | 54 | 08-03-2011 07:27 PM |
| knocking sound on acceleration, not ABS | bzwyatt | CX-7 > Issues & Troubleshooting | 5 | 12-15-2010 07:05 AM |
