![]() Join Date: Jan 2019 Location: Straya
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
(Thread Starter) | Not Ranked : 0 score Hi all, So after my epic journey with this car, I have another issue. So the lack of power and running rich (-25% STFT) has led my to do another compression test and leak down test. My compression test came back good, Cyl 1 - 170PSI, Cyl 2 - 180PSI, Cyl 3 - 170PSI, Cyl 4 -175PSI. I did a leak down test (used the one with 2 gauges - SPTools Leak Down Tester - https://transquip.com.au/products/sp...k-stopper.html. and for cyl 1, 3 and 4 got 25% (which is normal/good), but cylinder 2 I got 40%. I checked dipstick for air leak, exhaust for air leak and the intake manifold butterfly, all had no air. So I am stuck as to where the leak could be coming from. Any thoughts are appreciated.
__________________ Mods slowly coming along!!!! Autotech HPFP, CircuitWerks Down/Testpipe, Cobb Accessport V2 and a CPE Turbo Inlet Pipe (Waiting to put it on) |
![]() Join Date: Sep 2017
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Before you panic, do your tests again, make sure you are on TDC. Rotate crank again to the next TDC and do the test. |
| MSF's Punishing Member ![]() Join Date: Apr 2011
Rep Power: 2794 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,165
Groans: 546
| Not Ranked : 0 score i'm sure he appreciates the relief you gave him, he's prolly been in a panic for 16 straight weeks
__________________ 94 M MS6 IS350 |
| The Following 2 Users Say Thank You to Pu Manchu For This Useful Post: | Db09ms3 (12-30-2019), monkey.bones.007 (12-30-2019) |
| Boost leak test caused an oil to leak from dipstick | shazy | MazdaSpeed 3/6 - Turbo Induction | 14 | 08-22-2019 06:53 PM |
| How to do a leak down test? | SharkDiver | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 2 | 11-23-2015 10:48 PM |
| OEM BPV How to Test for Leak? | zer010gic | MazdaSpeed 3/6 - Turbo Induction | 1 | 02-22-2011 12:13 PM |
| Boost leak test | Laloosh | Mazdaspeed3/6 General Discussion | 17 | 07-06-2008 08:48 AM |
