![]() Join Date: Jul 2010 Location: Las Vegas, NV
Rep Power: 523 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,061
(Thread Starter) | Not Ranked : 0 score First Revision: No corrections to MAF, Targeting 11.8 on E25 only Second Revision: Up boost, dial in CL/OL Maf, BPV set to 50/50, Switched to Full Time CL Third Revision: Dialed back OL Cal to Rev.1, smoothed out boost curve, BPV back to Full Recirc NGK Still gapped to .025 No boost leaks No vacuum Leaks Still targeting 11.8 No exhaust leaks LTFT are at +-3 Clean MAF Fuel from same place E25 Primary O2 and MAF were replaced new in September I have a new map ready to go with a new OL MAF curve and transitioning CL->OL again Does anyone have a suggestion on what else to try before a flash the new map? Could this be mechanical or tune issue? Thanks, Ivan
__________________ 2007 MS3: BNRs3 PPT Tuned 350hp/360tq Stocked out and SOLD 2016 CX-5 GT AWD Last edited by LatinKraze; 12-31-2013 at 05:55 PM. |
![]() Join Date: Sep 2012 Location: Elizabeth, NJ
Rep Power: 3180 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,265
Groans: 665
| Not Ranked : 0 score A boost leak will make you run rich, not lean. Look for leaks pre-turbo, re-circ tube, TIP fully seated and tight etc. Vdyno sheets do next to nothing for troubleshooting. Post logs. |
(Thread Starter) | Not Ranked : 0 score Uploaded logs to OP. I checked for leaks originally from hot pipe. I checked again just now, from intake, and found a very small leak here: Took it apart, reassembled and no more leaks. That's post turbo though (Running Rich)
__________________ 2007 MS3: BNRs3 PPT Tuned 350hp/360tq Stocked out and SOLD 2016 CX-5 GT AWD Last edited by LatinKraze; 12-31-2013 at 05:05 PM. |
(Thread Starter) | Not Ranked : 0 score Would it have something to do with load? Looks like it didn't start until I reached 2.08-2.1. I'm going to cut a new map from scratch and keep researching what seems to be a load cap Calling out some top dogs @atvfreek @Dano @phate @rfinkle2 @djuosnteisn @ms3blackmica @superskaterxes @
__________________ 2007 MS3: BNRs3 PPT Tuned 350hp/360tq Stocked out and SOLD 2016 CX-5 GT AWD |
(Thread Starter) | Not Ranked : 0 score I used a v231 map as my base and worked in my current values and most of my load tables were off. None below 2.4 load so I don't know how the new map with a target of 3.0 load and max load of 5.0 will help. Pure boost tune so I made sure my speed will not try to achieve targets. Looks like everyone is busy with New Years, so I'm just thinking out loud. lol HAPPY NEW YEARS
__________________ 2007 MS3: BNRs3 PPT Tuned 350hp/360tq Stocked out and SOLD 2016 CX-5 GT AWD Last edited by LatinKraze; 12-31-2013 at 07:32 PM. |
| Not Ranked : 0 score Looks like this is related to you switching to CL full time. Revert back and test doing an A-B-A test. Make sure your AFR targets match in all tables.
| The Following 2 Users Say Thank You to Lex For This Useful Post: | atvfreek (12-31-2013), LatinKraze (12-31-2013) |
![]() Join Date: Nov 2010 Location: Manchester, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,797
What is your fuel scalar and specific gravity set to?
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
| The Following User Says Thank You to atvfreek For This Useful Post: | LatinKraze (12-31-2013) |
Thanks, 1.08 and .7490 respectively. Same it's always been on E25.
__________________ 2007 MS3: BNRs3 PPT Tuned 350hp/360tq Stocked out and SOLD 2016 CX-5 GT AWD Last edited by LatinKraze; 12-31-2013 at 09:24 PM. | |
| Not Ranked : 0 score Set your specific gravity table to OTS which is .74 I've been seeing some cars act in a similar way when that table is changed.
I'll give it a shot. I ran .7490 in June without issues too. Here's a log of that. Don't mind the KR, my TMM failed and I tore the WGA hose in that run. I have done many revisions since then. The biggest was an attempt at a hybrid tune according to this guide.
__________________ 2007 MS3: BNRs3 PPT Tuned 350hp/360tq Stocked out and SOLD 2016 CX-5 GT AWD | |
(Thread Starter) | Not Ranked : 0 score It may take about a week for my trims to settle so I can take a log. I appreciate the help guys, especially being New Years Eve yesterday
![]() Join Date: Nov 2010 Location: Columbus, GA
Rep Power: 4253 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,493
Groans: 307
| Not Ranked : 0 score @LatinKraze; any updates? Been following your thread, I've been having a similar issue.
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() |
| Not Ranked : 0 score The car stopped trimming @ around 1.2 load. I have zero experience running FTCL, but if it was in fact FTCL, I'd expect to see some stft activity and the ecu adding fuel... |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | LatinKraze (01-10-2014) |
| why am i so lean. | massiespeed3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 13 | 06-26-2010 02:53 PM |
| Dealers got lean; many plan to stay lean | Haltech | Automotive News | 0 | 05-30-2010 10:10 PM |
| Still lean at WOT... | AFcadet | Cobb ATR Support | 32 | 11-25-2009 02:11 PM |
| Lean at tip in... | Jarods7920 | Cobb ATR Support | 11 | 09-01-2009 01:19 PM |
| to lean?? | wisniaPl | MazdaSpeed 3/6 - ECU Computer Tuning | 12 | 04-04-2009 07:27 PM |
