![]() Join Date: Aug 2017
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Took my car to a track and 20 minutes in the engine started misfiring and blowing out exhaust smoke. Also, all of my oil was ejected. Took the engine apart to discover the piston is melted and the cylinder wall is damaged (see attached). I'm planning on buying a short block and swapping that in, but I want to make sure this won't happen again. Can anyone identify likely causes/solutions? I'm thinking running lean/detonation, but not exactly sure what's causing it. Faulty O2 sensor? Fuel injectors? Tune? Haven't done too much in terms of diagnostics due to time constraints, so I was hoping ya'll could give me suggestions. Engine mods: - Cobb Stage 3 Tune - Autotech High pressure fuel pump (HPFP) - Corksport short ram intake - CPE top mount intercooler - Synapse synchronic DV diverter valve |
| help....melted cable off of battery | RACER_X | Gen2 MS3 General Discussion | 45 | 08-01-2015 08:56 AM |
| Melted plastic ?? | meicalnissyen | Mazdaspeed3/6 General Discussion | 0 | 01-03-2015 11:35 AM |
| Has your Dashboard Melted? | SpencerC | Mazdaspeed3/6 General Discussion | 25 | 11-23-2014 06:39 AM |
| Melted Bushing | HiFiSpeed | Gen2 MS3 General Discussion | 1 | 10-27-2014 12:43 PM |
