![]() Join Date: Apr 2013 Location: Moreno Valley
Rep Power: 0 ![]() ![]() ![]() Thanks: 14
(Thread Starter) | Not Ranked : 0 score MODS: -cobb SRI -cobb TIH -cobb FMIC -corksport Downpipe -highflow cat -ptp Fuel pump internals -3" stright pipe exhaust -hks ssqv -xs power manifold -devils own meth injection -Cobb AP Stage 2 OTS map with slight modifications from previous owner i know i am new, but ive looked this up and people say it might be the OTS map? but ive changed the maps to different ones with no change. Anything helps guys. thanks in advance SIDENOTE: Both data logs are from 2nd-4th gear pulls. First one was november 2013, the second was today, 4-22-2014 |
![]() Join Date: Mar 2014
Rep Power: 0 ![]() Thanks: 2
| Not Ranked : 0 score Im having this same problem after installing bnr s3.. After install was running fine for about a week while trying to tune it was making 20psi. Then yesterday it just felt like it wasnt making any power, checked for leaks havent found any. Replaced line from turbo to wastegate and no difference. Dont know what to do |
![]() Join Date: Nov 2010 Location: Columbus, GA
Rep Power: 4253 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,493
Groans: 307
reference this http://www.mazdaspeedforum.org/forum/foru...ml#post2553770 might be relevant
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() | |
![]() Join Date: Sep 2013 Location: Valrico FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 475
Groans: 51
| Not Ranked : 0 score Most people are honestly going to want you to get a straight 4th gear pull. Start at around 3000rpm and put your foot to the floor till redline. Edit: Did not see the WGDC, damn.
__________________ 2006 TITANIUM GREY METALLIC MS6 SPORT Cobb AP v3 \\ Turbosmart Dual Port \\ Mazda Spin-On Conversion \\ Autotech HPFP \\ CP-E RDM \\ Turbine Tech FDM \\ CX Racing IC Piping \\ Treadstone TR8 Core \\ M2 Downpipe \\ JBR Power Path stage 2 \\ Denso ITV22 \\ JBR 80a Trilogy \\ JBR OCC \\ JBR TIGs \\ JBR EGR Delete \\ Corksport Springs |
| The Following User Says Thank You to Hargarbl For This Useful Post: | mgramata (04-22-2014) |
Groans: 307
| Not Ranked : 0 score IMO, you might want to look into getting one of the tuners on MSF to hook you up. They will do a far better job than any "protuner" at a shop. just my 2 cents
| The Following User Says Thank You to ms6mil For This Useful Post: | mgramata (04-22-2014) |
What could be causing the duty cycle to be so high? Is it something that just needs to be tuned or an actual problem with the engine? I'm trying to find a few local guys to help me out with it. Can you recommend anyone on the forums who can create/ tune a map? Thanks for the input guys
Thanks I'll get on that ASAP Last edited by mgramata; 04-22-2014 at 07:32 PM. Reason: MSF Database - Automerged Doublepost | ||
Groans: 307
from what I am hearing the WG might require more preload than what it's coming with. this is coming from Nishan:
I would just keep your ear to the ground in regards to the BNR S3, subscribe to this thread if you haven't already... I will tag ya when we are install ours on Sat. for progress.
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() | ||
| The Following User Says Thank You to ms6mil For This Useful Post: | Agent_Orange (04-22-2014) |
| Not Ranked : 0 score I had just started getting ready to work on my tune and it just started lagging on me. Cant really see it having anything to do with the tune or the different turbo because it was running fine.. Checked the stock bpv and it was fine also. So I dont know what to do |
Groans: 307
post logs when able
| Not hitting target boost | btrend | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 34 | 04-14-2013 09:28 PM |
| boost tuning, not hitting easy boost targets? | Caldazar | MazdaSpeed 3/6 - ECU Computer Tuning | 11 | 05-18-2012 06:09 PM |
| Not hitting Stage 2 boost targets (boost leak?) | Bubba Ho-Tep | 2010 MS3 - ECU Computer Tuning | 15 | 04-26-2012 08:25 PM |
| Not Hitting Boost? | KrishyC | Gen2 MS3 General Discussion | 8 | 03-28-2012 09:06 PM |
| AP stage 2 not hitting target psi and stuttering in 4th | balkanbase | MazdaSpeed 3/6 - ECU Computer Tuning | 7 | 12-06-2010 01:50 PM |
