![]() Join Date: Feb 2012 Location: Murrieta, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,285
(Thread Starter) | Not Ranked : 0 score A little background on the situation: Did a BT swap last weekend and when we started it up my AFRs were stuck at 14.85. Previously before the swap, my AFRs were moving around as they should when the k04 was in the car. Fast forward to today: I just swapped the primary o2 sensor with a new one from rockauto (NGK NTK 24393) and it's still having the same issue; AFRs stuck at 14.85. I've reflashed a few different maps and still the same thing. The wires on the new o2 are not twisted and the clips are plugged in. The secondary o2 is currently not in the DP due to messed up threads, so we plugged the bung; this shouldn't be causing my current issue at least I don't think? Not really sure what else there's left to check. I'm hoping it's something super simple, but who knows what it could be. Any ideas on what might be causing the issue? Needless to say I'm very disappointed in this outcome as I can't even enjoy the hard work my friends and I put into the car. This shit is big time lame... Sent from my iPhone using Tapatalk
__________________ FreekTuned |
| The Following User Says Thank You to msantana101 For This Useful Post: | Little John (06-01-2014) |
![]() Join Date: Sep 2012 Location: Columbus, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 939
Groaned at 25 Times in 15 Posts
| Not Ranked : 0 score That's probably your issue. Not having the second o2 sensor in. If I unplug my second o2 sensor it sticks at 14.85. If I unplug the first one it stays at 29.??. |
![]() Join Date: Aug 2012 Location: State College, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 987
| Not Ranked : 0 score That's not his issue. I've not had a secondary o2 sensor plugged in for a couple months. got it tuned without it and haven't had any issues. Unless the ecu's see the secondary o2 differently between gens.
__________________ 2006 Mazdaspeed 6 (Titanium Gray) : Built, gtx2867r Purple Drank tuned 12.07 @ 116 on 205 snow tires hunting for 11's on 245's |
| The Following 2 Users Say Thank You to DVM17 For This Useful Post: | btstarcher (07-04-2014), LumberJack (06-01-2014) |
![]() Join Date: Sep 2011 Location: Olympia, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 263
| Not Ranked : 0 score I thought the primary sensor was pn 24357?
__________________ 2007 True Red MS3 Koni Yellows || H&R Springs || JBR RSB || JBR Dogbone RMM || Centric Blanks || CS Pads || Goodridge SS Brake Lines || CS SSP || Hella Supertones || 55w 5000k HIDs/35w 3000k fogs || eonon D5151 HU/Nav/PS2 || 17x8 RPF1s || 235/45 DW || CS BPV || CS Intake/TIP || CXRacing/Godspeed FMIC || Ultimate Racing TP || Autotech Internals || AP v3 |
![]() Join Date: Mar 2010 Location: Lewistown, PA (State College)
Rep Power: 1938 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,144
| Not Ranked : 0 score Genpu 2nd o2 sensor has to be plugged in and in the exhaust stream. Different logic between the gens. We figured this out awhile ago when guys with pus were having massive problems with defoulers on the 2nd 02 sensor.
__________________ 2010 MS3 - Sold 2015 CX-5 GT AWD - Current ![]() |
(Thread Starter) | Not Ranked : 0 score Lumberjack is running his world record pu without a secondary o2 but his is a 2013 and mines a 2010. Would that make a difference? EDIT: just realized this was posted in the first gen section. Sorry I wasn't able to see that on tapatalk as it was cutoff. Sent from my iPhone using Tapatalk
![]() Join Date: Jun 2009 Location: Riverside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,560
Groans: 50
__________________ 08 Mazdaspeed 3 Fucking FREEK TUNED and shit |
| The Following 2 Users Say Thank You to Boosted Beluga For This Useful Post: | LumberJack (06-01-2014), msantana101 (06-01-2014) |
| Nishan ![]() Join Date: Apr 2012
Rep Power: 9816 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,290
| Not Ranked : 0 score I was under the impression that the rear O2 sensor was present. Mike, I would really try and get the rear O2 sensor in first before diagnosing any further to see what happens.
__________________ www.tunedbynishan.com |
| The Following User Says Thank You to ms3blackmica For This Useful Post: | msantana101 (06-01-2014) |
Nish, I had the secondary o2 connected but not in the stream due to stripped threads on the o2 so it was just basically hanging out in the open. Wouldn't it still read something even outside the stream, or does it absolutely have to be placed into the stream? Sent from my iPhone using Tapatalk
__________________ FreekTuned | |
![]() Join Date: Aug 2013 Location: Barstow/Rialto, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 194
| Not Ranked : 0 score I got the same problem with my Dp install, it got fixed with a new sensor, you could have gotten a dead sensor, it does happen. If anything try and double check all of the wiring harness connections.
__________________ 2013 White Pearl MS3 JBR SSP/bushings/RMM/EGR delete Corksport 3ID Intake/Radiator Cobb APV3/AT Internals Grimmspeed 3 port EBCS/Matt Damond CC FMIC W/DIY Sprayer CPE DP |
![]() Join Date: Jan 2013 Location: Lake Forest, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,942
Groans: 55
| Not Ranked : 0 score Its not the senor because i am using the one he bought and it is reading fine on my car! I although have my secondary o2 plugged in! |
| The Following 2 Users Say Thank You to Little John For This Useful Post: | LumberJack (06-01-2014), msantana101 (06-01-2014) |
| Not Ranked : 0 score It needs to be in the exhaust stream. Having personally seen your car when I was out in Cali and going over the symptoms/issues with Bryce I will say that you definitely need to get that rear O2 in the exhaust stream and see if you get feedback.
So I had the opportunity to put the rear o2 in today and absolutely nothing changed. AFRs were still stuck at 14.85 and I even did a hard reset on the battery and reflashed my map as well. In all honesty I was kind of expecting this but it's better to know for sure than to wonder. At least this came in the mail today so hopefully this will remedy this issue: ![]() Sent from my iPhone using Tapatalk
| The Following 3 Users Say Thank You to msantana101 For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score Alright sounds good. I'll give it a go and post up my results. Sent from my iPhone using Tapatalk
| The Following 2 Users Say Thank You to msantana101 For This Useful Post: | Boosted Beluga (06-01-2014), ms3blackmica (06-01-2014) |
(Thread Starter) | Not Ranked : 0 score So it came down to being a bent ecu pin that was causing my AFRs to stay stuck. Fucking wow. I'm extremely happy and relieved now but still cannot believe that was the issue and that it was overlooked for so long. Amazing...
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21
| Not Ranked : 0 score Do you have to have a pic of the bent ecu pin? I currently have the same problem. |
| The Following 2 Users Say Thank You to pdc001 For This Useful Post: | Axela_EN (07-04-2014), Boosted Beluga (07-04-2014) |
Groans: 50
(Thread Starter) | Not Ranked : 0 score I don't unfortunately. But it was bent to shit and pushed down. Sent from my iPhone using Tapatalk
![]() Join Date: Apr 2019 Location: st. Johns Newfoundland & labrador
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Sorry too reactivity this thread, But I seem to be having the exact same issue.. Just did a new catless DP install, And I’m new too the page also.. but my afr was stuck at 14.85, secondary o2 was on & snug and so was the primary but I’m getting a CEL P0134 which is the primary o2 sensor.. it all seems fine but is used and could possibly be dead.. cleaning out all connections & trying again but if this doesn’t work, where would I find a bent ecu pin? Before I go buying a new o2 sensor! Thanks in advance fellas all help is much appreciated |
![]() Join Date: Sep 2018
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score I'm also having the same issue. I bought a new NTK o2 sensor and installed it but my AFR's are still pegged at 14.85. Any way I can do a continuity test on the connectors for me to diagnose?
__________________ 2007 MS3 Stock Turbo - Wiseco Pistons - Manley H-Beam connecting rods - Autotech high pressure fuel pump internals - ARP cap bolts - ARP main studs Balance shaft delete - JBR EGR delete - COBB intake - COBB front mount intercooler - COBB rear motormount - COBB electronic boost controller - COBB access port V3 - COBB blow off valve - Catless downpipe |
Rock Auto is notorious for getting our parts wrong, often confusing with regular Mazda 3 or confusing 1st and 2nd gen MS3.
| Not Ranked : 0 score do you know what the part number for the OEM O2 sensor is?
| The Following User Says NO Thank You to Witness For This Un-useful Post: | Db09ms3 (12-06-2019) |
| Not Ranked : 0 score Really? I've been generous with my time and thoughts. Perhaps you might want to take the initiative and do a bit of investigating on your own. You can get the part number from any of the OEM Mazda parts stores. Many Mazda dealers operate on-line parts sales. It is easy to look up. Also, I believe I recently posted a link to the Edge Auto Sports website with the part number. Its right there on your other thread. Gee, at least try, please? Ok? We get tired of spoon feeding people who expect to have others do everything for them. That's not how it should work here. It's not unreasonable to ask someone to try to do a bit of their own homework, and then if they really fail, to seek help.
| Need help, CEL lights P0134 and P0441 | Nogood | MazdaSpeed 3 - Engine, Transmission & Driveline | 1 | 05-05-2014 09:12 PM |
| CEL P0031 and P0134 | matto | MazdaSpeed 3/6 - Turbo Induction | 5 | 01-19-2012 11:56 AM |
| CEL P0134 & P0139 | f-castrillo | 2010 MS3 - Troubleshoot/Diagnostics | 6 | 08-06-2011 02:17 PM |
