 Old 01-20-2010, 01:30 PM   #1
felt's Avatar
Posts: 1,504   (View Stats)
felt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the world
Groans: 1,364
Groaned at 589 Times in 386 Posts
Default P0137, P0139 and P0140
Location: Banning, CA (average temperature) 45F - Massive Amounts of RAIN.
I normally get P0140 I believe which is my rear 02 sensor (I'm running a CP-E TBE), since that is normal because I don't have any catalytic converters.
It's been getting cold and alot of rain here lately and recently noticed 2 other codes, all related to rear 02 sensor.
P0137
A code P0137 may mean that one or more of the following has happened:
* Faulty o2 sensor Exhaust leak near the rear sensor
* Plugged catalyst
* Short to voltage on O2 signal circuit
* High resistance or open on O2 signal circuit
P0139
A code P0139 may mean that one or more of the following has happened:
* The oxygen sensor is faulty
* The wiring to the sensor is broken / frayed
* There is an exhaust leak
P0140
The causes for a P0140 code are fairly few. They could be any of the following:
* Shorted heater circuit in O2 sensor. (Usually requires replacement of heater circuit fuse in fuse block also)
* Shorted signal circuit in O2 sensor
* Melting of harness connector or wiring due to contact with exhaust system
* Water intrusion in harness connector or PCM connector
* Bad PCM
With 1 active code, P0140 and 2 triggered codes P0137, P0139, the car has been running perfectly fine. My STFT and LTFT have been spot on, AFR's at WOT are perfect, car idles perfectly, fuel economy is perfect, vacuum is spot on, fuel pressure is 1650 @ WOT, car spikes to 17PSI @ WOT and settles down to 15PSI @ 5600rpms, boost is fine, car hauls ass.
Is my rear o2 sensor bad (needs to be replaced due to having no cats for the past 20K miles), or is it just weather related/rain...?
Last edited by felt; 01-20-2010 at 08:22 PM. Reason: MSF Database - Automerged Doublepost
felt is offline   Reply With Quote
The Following 3 Users Say NO Thank You to felt For This Un-useful Post:
 Old 02-01-2010, 12:40 AM   #2
kagerou's Avatar
Posts: 6   (View Stats)
kagerou is an unknown quantity at this point
i would check the connector that goes from the ecu to the o2 sensor connector (located approximately where the front wheels are and on the drivers side)
i had a p0140 code and thought that the o2 sensor was damaged, but it was reading 20mv on the dashhawk
looked under the car, and the white wire from the ecu (o2 sensor heater wire) had come loose from the plastic connector, so i just pushed it back into the plastic connector and glued it in place so it doesnt come loose again
i think this happens because the cable is really tight and just reaches the rear o2 sensor location on the cp-e downpipe
not too sure on the other error codes, but maybe water has gotten into the wiring and triggered the other codes, and or damaged the o2 sensor
hope this helps
kagerou is offline   Reply With Quote
 Old 02-01-2010, 12:47 AM   #3
OMGWTFHAX's Avatar
Posts: 445   (View Stats)
OMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the world
Groaned at 26 Times in 25 Posts
P0137 means a bad secondary 02 sensor
P0139 means basically the same thing. They kind of go hand-in-hand
P0140 Means your secondary 02 sensor is definitely fucked.
Donate to the forums or stop being an idiot and Ill give you an answer.
Flickr
Originally Posted by Andrew85 View Post
Wow kid... how about LOL @ you for being a piece of garbage without a purpose in life. For one thing, im not really bragging, just sharing an experience. Another thing is that you like men and your opinions dont count cause you take it up the poop shute.
OMGWTFHAX is offline   Reply With Quote
The Following 3 Users Say Thank You to OMGWTFHAX For This Useful Post:
felt (02-02-2010), redboat (11-24-2019), SpeedSixxx (02-01-2010)
 Old 03-07-2010, 12:45 PM   #4
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
felt I deleted your post to save your pride and good name.
Carry on citizens....
10.7 @ 133 auto 1G DSM
 Old 08-30-2011, 02:38 PM   #5
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
Getting P0140 myself... along with p1... shit i forgot but its the lean at idle code. You guys think if i remove the o2 sensor and clear the code with atr the p0140 should go away? I just plan on plugging it. Plug is cheaper than an o2 sensor, lol.
Aslso... the car is running great.
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
 Old 08-31-2011, 05:42 PM   #6
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
do the spark plug nonfouler trick and you should be set with your codes
 Old 08-31-2011, 09:00 PM   #7
Already had those on. I pulled the sensor and drove for 30 minutes. No cel at all... Weird.
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 09-01-2011, 07:33 PM   #8
TWOptSL0W's Avatar
Groans: 125
you sure you have it on the 2nd sensor and there are 2 nonfoulers? it should be pushed out all the way from the exhaust stream
 Old 09-01-2011, 08:07 PM   #9
100% sure. I threw them both away cause they were starting to rust.
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 12-20-2011, 04:36 PM   #10
DarkPasseng3r's Avatar
Posts: 165   (View Stats)
DarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond repute
I know this is an older thread but I am having a similar issue. P0137 and P0139. So have you been running without a secondary sensor since then without a cell?
In your quoted text, you said you pulled the sensor and no cell - did you already toggle the P0137 and p0139 in ATR?
2010 Speed 3
JBR RMM|Shifter Bushings//CS SRI|TIP|Skidplate//Cobb AP//UR DP|TP//Autotech Internals//Falken RT-5//C-Clamp
321HP/436TQ 3gal E85 (Self-tune in progress)
DarkPasseng3r is offline   Reply With Quote
 Old 12-20-2011, 04:40 PM   #11
atvfreek's Avatar
Posts: 7,787   (View Stats)
If you have a genpu you cannot run any defoulers, and some downpipes have them built into the secondary bung. The secondary o2 needs to be directly in the exhaust stream. I had a bung welded in next to the second o2 and no issues.
Tappin
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
 Old 12-20-2011, 04:53 PM   #12
Tappin
Ah, thanks Justin. I have a genpu so I guess I'll be taking off my defoulers. I just wasnt quite sure if ATR turns off the sensor or just disables the code. Any info on that? I don't wanna run rich or lean due to the ECU getting an incorrect read from the 02 sensor, so I figure if I can just turn the sensor off altogether, then why not.
2010 Speed 3
 Old 12-20-2011, 06:29 PM   #13
atvfreek's Avatar
The pcm uses the 2nd o2 as feedback to verify the primary o2 is doing it's job. So you cannot completely turn it off and there is just too many codes that o2 can set. How the PCM tests to see if the sensor is working is it sends a calibrated rich mixture and monitors the o2 to see if it goes rich briefly. If it doesn't it will keep adding more and more fuel to try and get it to read rich. If it cannot do that, it sets all those codes that you got.
Without the defouler you may get a cat efficiency code, but that is easily deleted with atr and won't make your car run rich/like shit.
Hope that helps!
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 2 Users Say Thank You to atvfreek For This Useful Post:
chintastic (01-07-2012), DarkPasseng3r (12-20-2011)
 Old 12-20-2011, 07:46 PM   #14
Understood @atvfreek
So although I may recieve a Cat efficiency code by fully exposing the sensor to the uncatted stream, the sensor will be able to take accurate readings and provide correct feedback to the PCM.
Awesome! I'll try that soon.
2010 Speed 3
 Old 12-20-2011, 08:08 PM   #15
atvfreek's Avatar
Yup, exactly. Then just delete the p0421 code and your car will be happy. I had a bung welded in mine for 30 bucks at an exhaust shop and they did it from under the car. I will try and find the thread I had made with the picture.
*edit, just saw that you have defoulers and its not part of the dp like mine was. So no new bung is needed. Just remove the defoulers and you will be good to go.
Tappin
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 12-20-2011, 08:17 PM   #16
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Ugh I thought felty had come back and made a new thread
NATOR PA
atvfreek (12-20-2011)
 Old 01-07-2012, 04:07 AM   #17
chintastic's Avatar
Posts: 299   (View Stats)
chintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the world
is there a how to on clearing the cel with atr?
2013 CWP Mazdaspeed 3 : COBB TIH, COBB Intake, COBB AP, GFB BPV, SURE Shortcut, counterweight, and shifter bushings, Rally Armour mud flaps,
chintastic is offline   Reply With Quote
 Old 01-07-2012, 08:42 AM   #18
bmylez's Avatar
Posts: 3,197   (View Stats)
In ATR, go to Edit -> Advanced Parameters. It allows you to toggle DTCs. It will take effect on your next ECU flash.
2007 CTS-V - Trying to sell
 Old 01-18-2012, 07:18 AM   #19
JTMS3's Avatar
Posts: 2,306   (View Stats)
so I threw a P0139 code this morning on a 10* cold start. I guess I will check the wiring but I did change the TMM this weekend.
 Old 07-12-2012, 05:02 PM   #20
Sig_Nasty's Avatar
Posts: 272   (View Stats)
Sig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the world
Groaned at 4 Times in 1 Post
throwing all 3 of these codes...due to not running a rear o2 sensor. brand new one is going in tomorrow, should hopefully clear all these up.
Sig_Nasty is offline   Reply With Quote
 Old 07-12-2012, 09:01 PM   #21
My issue turned out to be a bad purge valve btw
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 01-06-2014, 10:37 AM   #22
HOCKEYNUBE's Avatar
Posts: 144   (View Stats)
HOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the world
I know this is suuuuper old but instead of starting a new thread ill try replying to this one first, I read what atvfreak wrote and that's what I was going to try.
I have a catless ebay DP and im throwing the p0137 and p0139... now I made a new bung at work yesterday that is an inch long and the tip of the sensor sticks in about a half inch... also made one that is 5/8 of an inch long and the entire tip of the sensor sticks in... basically what im getting at is where should it go? ive read put it at 90 degrees of the stream, put it at an angle... and so on. And also which one would you guys suggest?
once again sorry for putting the paddles on the thread but id rather replay
thanks guys!!
HOCKEYNUBE is offline   Reply With Quote
 Old 04-17-2017, 06:48 AM   #23
Reedy's Avatar
Posts: 391   (View Stats)
Reedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the world
Having P0137 and P0140 codes come up myself.
I had an exhaust leak that melted my O2 wiring harness recently, but we repaired that and replaced the wideband O2 sensor. I am starting to wonder if the repair has failed, or if I need to replace the second O2 sensor as well.
Does anyone know which code refers to which sensor? The codes are kinda intermittent for me and the car still runs just fine. I am just not sure if the codes are referring to one O2 sensor specifically, or both......
Reedy is offline   Reply With Quote
The Following User Says NO Thank You to Reedy For This Un-useful Post:
g00s3y (04-17-2017)
 Old 04-17-2017, 09:30 AM   #24
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
And when you typed in "mazdaspeed p0137" & "mazdaspeed p0140" into google, or actually looked in the first post, what did you learn about which sensor those codes refer to?
 Old 04-17-2017, 03:41 PM   #25
Reedy's Avatar
Whoops silly me, that's what happens when you read & post when you're half asleep.
Evidence here would suggest the rear one but I don't know how the 2 sensors might interact with each other. OP didn't post his solution either so I am not sure what the end result was.
My AFR readings occasionally latch which I thought meant the front sensor still has issues, since that's the one that had the wiring harness melt.
Codes I am getting suggest rear but I have a feeling my gremlin might run slightly deeper thanks to recent history.
I've also datalogged O2 sensor voltages and they don't totally correlate with it being entirely rear sensor related either. I need to do a bit more reading to properly interpret that data tho.
 Old 04-20-2017, 02:25 AM   #26
Reedy's Avatar
Ok well time for an update.
I looked at the datalogs and O2 sensor voltages on both sensors were flicking between 0V and 0.05V, basically no activity at all and kinda randomly too.
So I got a new rear sensor from Mazda and installed it this afternoon. The first confirmation that something wasn't right was the old sensor looks like it's been partly squashed by something. Maybe my CAT shat out a chunk that hit the sensor at high speed? I really don't know.
So the new sensor went in, and voltages on both sensors are looking a lot happier, between 0-1V and showing some variability in between. The busted sensor had no variability and just jumped between insignificant signal levels.
Dead sensor (The voltage level on sensor 2 only goes up to 0.05V, the graph doesn't label its axis properly)
Happy Sensor
Problem now is that my AFR's are sitting around 12.1 at WOT so it looks like I need to get the car re-tuned asap, which sucks since I only had it dyno tuned a couple of months ago.
On the whole a good result. I was a bit confused as to why both sensors were showing such bad readings but it makes sense if the rear one is used to calibrate the front one.
 Old 04-20-2017, 08:04 PM   #27
sheston's Avatar
Posts: 1,847   (View Stats)
Is this a Genwon? GenPu's have the ability to correct some at WOT. If the rear one was going bad while you were getting tuned, that probably pulled the readings off
Man, that O2 sensor looks like it really decided to quit.
 Old 04-21-2017, 01:11 AM   #28
Reedy's Avatar
It's a gen2. And the sensor was definitely starting to quit when it was tuned, I was getting sporadic p137 codes already at that point but by last week would get one every time I drove the car, and the p140 codes were starting to appear as well.
Going WOT right now gives a lot of knock retard and stutter so the ability to compensate doesn't seem to be enough. It's booked in for a re tune next week.
I've also been getting P0139 codes for years and years and just assumed that was a common thing since a lot of other people also get them. Wondering if I will still get them after this.
 Old 04-21-2017, 05:59 PM   #29
sheston's Avatar
If it ran very long this way, you may need to replace the plugs, etc.
I assume the next logs you do for the tuner will be MAF cal logs?
 Old 04-21-2017, 07:06 PM   #30
Reedy's Avatar
Good idea, i'll take a look at the plugs. I have a spare set in the garage so might just swap them anyway....
I have my car dyno tuned. That's for them to take care of.
 Old 05-03-2017, 05:10 AM   #31
Reedy's Avatar
Back to normal. New spark plugs and retune. Car was definitely running dangerously lean.
 Old 07-18-2017, 05:39 AM   #32
Reedy's Avatar
So my CEL codes started coming back again. This time it started with a P0037 code (O2 sensor heater circuit) and also produced P0038, P0134, P0137, P0138, and P0140. All over the place.
Voltage logs of the sensor show the voltage wandering all over the place while running, especially during cold starts but also during normal running. This was different to last time where there was simply no signal.
Workshop manual troubleshooting says this is a prompt to replace the sensor, but this sensor is only 4 months old! At this point I am starting to think my CAT might be busted.
So I carry on doing continuity checks on the wiring harness. Everything seems to be fine....
Down to the resistance check on the heater circuit in the sensor. Reading 1Mohm. It should be 2-50ohm. Ok, maybe it is the sensor after all?
Pull the thing out... and start getting deja vu. Did I put the old sensor back in last time? Cause this looks exactly the same as the last one did.
Now this cannot be a coincidence, so I poked my finger into the hole it came out of to feel around for debris and it's not just debris that's in there, the entire core from my CAT has come loose and is just flopping around inside the DP. Looks like the O2 sensor was the only thing stopping it from rolling the whole way down to the muffler!
This is a CP-e DP that I bought back in 2010 and the same thing happened to me a few years ago where the CAT came loose inside the DP, we cut it out and welded a new cat in at the time but the same thing has happened again, only this time it trashed 2 O2 sensors before I found it!
I threw a p0139 speed_3 MazdaSpeed 3/6 - ECU Computer Tuning 6 10-01-2008 03:22 PM
P0139.....again Death-From-A-Mile
Cobb Access Port/Maps
10 05-31-2008 01:31 AM
Page generated in 0.49313 seconds with 36 queries
