![]() Join Date: Nov 2009 Location: Westchester NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 566
(Thread Starter) | Not Ranked : 0 score also, there has been a burning smell lately, and the car has been smoking if im stopped for a short amount of time, it has always smoked a lil but only after bing stopped for a longgg time, like 5-10 minutes, so is the cat in the down pipe shot? i also have the p0401 code which looks to be like the egr is stuck open? can any one in the know chime in on this, it would be greatly appreciated. mods are in my sig..
__________________ 2007 Mazdaspeed 6 - Ptp SST, Cobb AP, SSP 3.5" Intake, SURE Sidewinder, Autotech HPFP Internals, PTP 2150 psi HPRV, Cp-e Injector Seals, PTP Injector Studs, Jbarone TIG's, VTCS Delete, ETS 3.25" TMIC, M2 Catless Downpipe, Magnaflow Catback Exhaust, MD OCC, Denso ITV 22, H & R springs, Energy Suspension Rear Sway Bar Bushings, Dashhawk, Hawk HPs Pads, Centric Rotors, Street Unit Rear Motor Mount, TWM Stage II Shifter with Solid Bushings and Weighted Shift Knob, Autometer Mechanical Boost Gauge Last edited by speedms6; 02-04-2011 at 02:55 PM. |
(Thread Starter) | Not Ranked : 0 score bump
__________________ 2007 Mazdaspeed 6 - Ptp SST, Cobb AP, SSP 3.5" Intake, SURE Sidewinder, Autotech HPFP Internals, PTP 2150 psi HPRV, Cp-e Injector Seals, PTP Injector Studs, Jbarone TIG's, VTCS Delete, ETS 3.25" TMIC, M2 Catless Downpipe, Magnaflow Catback Exhaust, MD OCC, Denso ITV 22, H & R springs, Energy Suspension Rear Sway Bar Bushings, Dashhawk, Hawk HPs Pads, Centric Rotors, Street Unit Rear Motor Mount, TWM Stage II Shifter with Solid Bushings and Weighted Shift Knob, Autometer Mechanical Boost Gauge |
![]() Join Date: Jan 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 102
| Not Ranked : 0 score Can you elaborate as to why you think this has something to do with your EGR? I'm not sure I follow that... From my experience the P0421 is most commonly, if not always attributable to a bad primary catalyst. |
(Thread Starter) | Not Ranked : 0 score yeah i know that, but i have both trouble codes and the p0401 is usually q clogged egr tube from what i read on here, i think i pretty much found my answer by searching that i have to either clean the egr tube or block it off, im hoping i dont need a new cat though. just was looking for peoples past experiences.
![]() Join Date: Jan 2011 Location: Princeton wv/Trenton NJ
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 36
| Not Ranked : 0 score I threw the same code today after i gutted my dp and 2nd cat lol..cleared it with the hypertech. Car runs dumb hard now btw
__________________ True red 2008 MS3 GT-Mazdaspeed CBE- Mazdaspeed CAI- Mazdaspeed lowering springs- Nator(gutted) downpipe- testpipe-Autotech Internals- Hypertech tuned- HKS SSQV- CPE gauge pod- Prosport boost-oil temp- Innovate AFR Wideband- Broadway mirror- 20% tint- Grayco car seat |
![]() Join Date: Jun 2009 Location: Red Deer Ab
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24
Groaned at 5 Times in 1 Post
| Not Ranked : 0 score had that code, did a search, and did the egr cleaning procedure. really it's part of normal maintenance. |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f293/p0421-71489/ | ||||
| Probleme und Diagnostik - [ALLE] Fehler P0421 | This thread | Refback | 11-29-2013 08:41 AM | |
| [ALLE] Fehler P0421 - Probleme und Diagnostik - mazda-mps.de | This thread | Refback | 10-23-2012 07:32 AM | |
| P0421 CEL | RichB | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 5 | 12-30-2009 07:51 AM |
| Does secondary o2 (P0421) cause misfire (P0300)? | SonnyBonahoe | MazdaSpeed 3 - Engine, Transmission & Driveline | 18 | 11-24-2009 08:46 AM |
| P0421 on my CP-E Catted downpipe | steven88 | MazdaSpeed 3/6 - Turbo Induction | 11 | 07-11-2009 09:43 PM |
| Help! CEL P0421!! | Decepticon | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 8 | 05-04-2009 06:28 AM |
| How to get rid of a P0421 CEL...? | AutoXRacer | MazdaSpeed 3/6 - ECU Computer Tuning | 10 | 04-15-2008 05:45 AM |
