 Old 12-21-2009, 03:58 PM   #1
RichB's Avatar
Posts: 510   (View Stats)
RichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the world
Default P0421 CEL
I have been recently getting a P0421 code and am looking for idea what it could possibly be? I have the stock DP with a Race pipe so i'm confused. It did start getting cold around here so can that cause this CEL? I doubt it is my Cat or the O2 sensor but let me know what you think.
Opinions are appreciated. Thanks.
2007 Cosmic Blue Mazdaspeed 3 GT
RichB is offline   Reply With Quote
 Old 12-23-2009, 06:20 AM   #2
armarine04's Avatar
Posts: 294   (View Stats)
armarine04 is the leader of the worldarmarine04 is the leader of the worldarmarine04 is the leader of the worldarmarine04 is the leader of the worldarmarine04 is the leader of the worldarmarine04 is the leader of the worldarmarine04 is the leader of the worldarmarine04 is the leader of the worldarmarine04 is the leader of the worldarmarine04 is the leader of the worldarmarine04 is the leader of the world
Groaned at 20 Times in 5 Posts
I have been getting the same Code for the past week or so I've reset everything twice (dissconnected the bat) but still coming back... after a quick google search I've found it could be O2, Cat, or possible a fouled spark plug??? not sure where to go from here any help is appreciated
Boooosh!
][ 2007 MS3 GT ][MAZDASPEED cai ][ MAZDASPEED cat-back ][ CP-e dp ][ Turbosmart Dual Port ][ SU rear motor mount ][ ITV-22 ][ RallyArmor mud flaps ][ MS6 wheels ][
armarine04 is offline   Reply With Quote
 Old 12-27-2009, 08:28 AM   #3
RichB's Avatar
After a little more research I think this code is a combination of the cold weather and having racepipe. The racepipe makes the temperature distribution during CAT warm-up between the two O2 sensors closer to each other than the allowed stock threshhold, therefore popping this code. The ECU likes the sensors to have completely different readings which shows it that the CAT is working. I never had an issue during the summer.
 Old 12-28-2009, 08:21 AM   #4
armarine04's Avatar
Well that kinda makes sence to me... not stressing it thats for sure. I put my car up on a lift couple of days ago and It seemed that the slight jaring of the car from driving it up onto the lift ramps wiggled moved shifted idk but as soon as I drove it on the lift the CEL went off and 250 miles later hasnt came back on..... wierd car
Boooosh!
 Old 12-28-2009, 08:46 AM   #5
RichB's Avatar
Driving it up on a lift isn't what did it. If the fault tht caused the code isn't present for a while it resets it self. Pretty cool coincidence though.
The Following User Says Thank You to RichB For This Useful Post:
armarine04 (12-30-2009)
 Old 12-30-2009, 07:51 AM   #6
armarine04's Avatar
Or maybe the garage has special healing powers.
Thanks for the input RichB.
Boooosh!
Does secondary o2 (P0421) cause misfire (P0300)? SonnyBonahoe MazdaSpeed 3 - Engine, Transmission & Driveline 18 11-24-2009 08:46 AM
P0421 on my CP-E Catted downpipe steven88 MazdaSpeed 3/6 - Turbo Induction 11 07-11-2009 09:43 PM
Help! CEL P0421!! Decepticon MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 05-04-2009 06:28 AM
How to get rid of a P0421 CEL...? AutoXRacer MazdaSpeed 3/6 - ECU Computer Tuning 10 04-15-2008 05:45 AM
Page generated in 0.28985 seconds with 21 queries
