 Old 01-15-2020, 09:59 PM   #1
Kasprzap's Avatar
Posts: 37   (View Stats)
Kasprzap has much to be proud ofKasprzap has much to be proud ofKasprzap has much to be proud ofKasprzap has much to be proud ofKasprzap has much to be proud ofKasprzap has much to be proud ofKasprzap has much to be proud ofKasprzap has much to be proud ofKasprzap has much to be proud ofKasprzap has much to be proud of
Default P2177 and hesitation on accel
I have a P2177 lean off idle trouble code. Only noticeable effect is that car jerks / pauses during heavier acceleration.
Recently replaced:
pre cat o2 (I believe it was bad following the FSM directions)
EGR valve (removed my P2187 code)
Used carb clean to look for vacuum leaks but didn't find any
Cleaned my MAF with maf cleaner
Added Seafoam in the gas tank (and engine oil)
I need to perform a boost leak test (my tester is leaking & I need to remake).
I viewed the following on my AP (don't have cable to connect it to computer):
at idle / rev'ed to 2k rpms
LTFT 11 / 19
STFT 5 / 5 .. rechecked and got 1 / 5
MAF airflow 3 / 6 g/s
HPFP Actt. Press 435 / 425 ...spiked to 1400+ under hard revving
MAF Voltage 1.2 / 1.5
AFR 14.6 / 14.7
I believe my turbo is toast. Lots of in and out shaft play and white smoke at idle. I don't think this would cause lean off idle tho?
Any suggestions? Does this look more like an air leak problem, fuel delivery problem, or something else?
06 Speed6: SRI, TP, AP Stage1, SURE Engine and rear diff mounts.
Kasprzap is offline   Reply With Quote
 Old 01-16-2020, 12:08 PM   #2
Posts: 2,233   (View Stats)
most of the time is a leak or bad maf cal. vs intake installed
I don't know the behaviors of dirty injectors, it isn't impossible that it can reduce the fuel amount but i would check for leaks first...
 Old 01-16-2020, 12:16 PM   #3
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
It seems like you may have a leak. The fuel trims are on the high side.
Has the MAF sensor been replaced?
2018 Audi RS3
2007 Acura TSX 6MT
The Following 2 Users Say Thank You to tegxsi For This Useful Post:
MSMS3 (01-24-2020), Vansquish (01-16-2020)
 Old 01-23-2020, 06:55 PM   #4
Kasprzap's Avatar
Alright so I performed a boost leak test and didn't find anything substantial.
I replaced my MAF and the jerky acceleration and P2177 code is gone!!!!
HOWEVER, now I'm getting P2188 "too rich at idle" Did some searching and tried the easy stuff. Took my air filter off to see if that was too dirty and restrictive, but didn't see my AFR change. I put compressed air on my MAF connector in case some dirt was in there as well.
I wanted to post a log, but my accessport will not connect. (Sounds like it needed to be updated on Windows 8 before it will work on Windows 10 and I have no access to a Windows 8 computer.)
Any ideas? Any band-aid ideas to just pass emissions for the short term fix?
 Old 01-24-2020, 01:19 PM   #5
Posts: 2,826   (View Stats)
There are many, many threads here about P2177/2188 codes and many potential causes. Have you read any of them? Might contain what you are looking for. Without logs we are stabbing in the dark with multiple possible causes still to sort through.
Does the oil on your dipstick smell like gasoline?
Did you use a genuine Mazda brand MAF sensor specific for the DISI turbo engine? These engines can use many substitute aftermarket products with no problem, but sensors, particularly MAF, MAP, and primary 02 sensors seem to cause problems if not OEM parts.
You may also need to redo your MAF cal.
Solenoid tick when accel/decel ???? GUCCISUPREME 2010 MS3 - Engine, Transmission & Driveline 0 10-27-2018 02:58 PM
Pulsing accel 2k-3k RPM. MAF Sensor? jmettee MazdaSpeed 6 - Engine, Transmission & Driveline 49 02-16-2017 04:57 AM
Sputter/Hesitation U2064 P2177 P2187 P2097 KFL989 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 24 03-26-2014 07:35 PM
mystery clunk on accel/decel samc Mazdaspeed3/6 General Discussion 9 07-20-2013 07:42 PM
Poor gas mileage, rough idle, hesitation when at high rpm/ heavy accel uwmdiscgolfer MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 09-05-2012 06:03 AM
Page generated in 0.26638 seconds with 23 queries
