![]() Join Date: Feb 2017 Location: SLC, Utah
Rep Power: 0 ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score Took the serpentine belt off again over the weekend to rebuild the power steering pump. Now, even with help, I can't even get close to enough slack to get the belt back on. Replaced the tensioner pulley and compared old belt to new belt, old belt is a little longer. Old belt was soaked with ATF from power steering pump leak. Am I missing something? |
![]() Join Date: May 2013 Location: Maryland
Rep Power: 84 ![]() ![]() Thanks: 0
| Not Ranked : 0 score I have ran into this on occasion at work. Either 1. The belt isn't on the ribs all the way. 2. the new belt is a hair too short ( but you said you measured that). 3. I put the belt on every pulley and install it on the smooth water pump pulley last to gain the most slack. |
![]() Join Date: Sep 2012 Location: Bryn Mawr, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 158
| Not Ranked : 0 score When I put a new belt on my MS3 I really had to crank the tensioner all the way loose and then struggle to get it on. Wedged the wrench on the tensioner against my shoulder so I could use 1 hand to turn the crank and the other to muscle the belt over the last pulley.
__________________ Corksport: SRI & TIP, Strut Tower Brace, Coilovers CP-e: RMM JBR: Rear Sway Bar (with Moog End Links) TWM: Full Replacement Shifter Cobb: AP AutoTech: HPFP Internals Ebay: Test Pipe |
| Not Ranked : 0 score My tensioner was bottomed out to get the belt slid over the final SMOOTH pulley. As mentioned above, save a smooth pulley for last. It makes a world of difference.
![]() Join Date: Dec 2013 Location: Plainfield, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,712
| Not Ranked : 0 score super easy like this.
__________________ 2010 black mica speed3 The go: Depo racing: downpipe (100 cell count), custom: FMIC. HTP: 3.5" intake, under route piping. JBR: shortshifter, RSB. Autotech: HPFP internals. Go fast bits: hybrid BPV, VMR: 18x8.5 V710s, Bridgestone: potenza re760 245/40/18, KW: v3 coilovers,SPC: camber arms, freektuned, Damond Motorsports: dual OCC, PMM, PCV plate, RMM, TMM, EGR delete, FoSt mani, Corksport: battery box(fuck this thing), injector seals, Cobb: EBCS, AP v3. AEM: methanol. Seibon: carbon fiber hood. UR: catback. Bosch: 3bar. BNR: s4, DNP: EWG manifold, Tial: 38mm mvs EWG. The show: 5% tint all around, 50% tint windshield, rally armor mudflaps, Sony XAV64BT touchscreen headunit, katskin leather interior, CPE relocation plate, Maisonvi weighted shift knob, Corksport hoodscoop, black housing headlights. Soon:built motor |
| Not Ranked : 0 score That's a tad easier on a Speed3 but pretty slick move.
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,503
| Not Ranked : 0 score If above does not work, put the belt in an over on very LOW heat. if you can get it up to about 110-120 degrees, no more, it will stretch temporarily, enough to fit over that last pulley without damaging the belt. Work fast while it is warm. You can also soak it in hot water and do the same thing. This is a tried and true old mechanics trick. If the belt has Kevlar plies in it, some do, some don't, it won't stretch much.
| Not Ranked : 0 score Another trick, zip-tie the belt to the pulleys when you're threading it on. Especially if you're working alone. That way it won't fall off other pulleys while you're working to get it on the last one. Then just snip the ties when you're done.
| The Following User Says Thank You to ChaunceyM For This Useful Post: | MSMS3 (11-02-2019) |
![]() Join Date: Aug 2019 Location: California
Rep Power: 0 ![]() Thanks: 3
| Not Ranked : 0 score Im also having trouble getting the belt back on. Im trying to turn the bolt counter clockwise but it wont budge. Any help could be appreciated |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,745
| The tensioner pulley has to be rotated clockwise, not counter clockwise, to release tension.
| The Following User Says Thank You to Vansquish For This Useful Post: | MSMS3 (11-02-2019) |
| Serpentine Belt | Zeya | MazdaSpeed 3 - Engine, Transmission & Driveline | 8 | 05-24-2016 12:09 PM |
| serpentine belt | Project_dog | CX-7 > Engine, Transmission & Driveline | 3 | 04-24-2014 09:37 AM |
| Changing serpentine belt | HARPER306 | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 05-29-2011 02:19 PM |
| Serpentine belt | 07Speed3007 | MazdaSpeed 3 - How-To's | 19 | 02-12-2011 08:01 PM |
