 Old 05-25-2008, 07:32 PM   #1
ms3-87's Avatar
Posts: 241   (View Stats)
ms3-87 is a splendid one to beholdms3-87 is a splendid one to beholdms3-87 is a splendid one to beholdms3-87 is a splendid one to beholdms3-87 is a splendid one to beholdms3-87 is a splendid one to beholdms3-87 is a splendid one to behold
Default smoke at idle
ok so i let my car sit 10-15 min at idel and it starts to smoke
i've read that this could be a turbo seal or i might need a oil catch can
is their any things i can check that would tell it was a definite turbo seal
current mods
txs tbe
txs fmic
txs cai
hks ssqv recirc
cobb ap
ms3-87 is offline   Reply With Quote
 Old 05-25-2008, 07:54 PM   #2
joeylow's Avatar
Posts: 28   (View Stats)
joeylow will become famous soon enough
did it stop?
mine did that today aswell just after i was beating on the car, stoped at my buddys house for a few left the car running come out and it looked like i had a blown head gasket, put my hand by my exhaust and then smell my hand.....pure fuel just sitting there loading up with fuel give it a coulpe revs to make sure and everything is fine.....ms3 run super rich as we all know
mods.....
aem cai
3'' vibrant exhaust
turbosmart dual port bov
turbo timer
corksport downpipe (not installed)
mods thats have nothing to do with the motor.....
h&r springs
tenzo r type m
ray nuts
INSTALLED
AEM CAI, Turbosmarts BOV, Vibrant Exhaust, H&R Springs, AWR MM, Evo TT, Corksport Downpipe, FMIC, Filter Conversion Kit, Autometer Boost Gauge
HAVE TO INSTALL
N2MB WOT Box/Full Throttle Shift & 2Step Launch Control, Turbosmarts MBC, Track Use--->MT ET Streets
PARTS TO COME
PTP Fuel Pump Kit/Spring, PTP PCV, CP-E Standback v2.0, CP-E PNP Harness, CP-E ProFuel Controller, Snow Meth Kit, DNP Turbo Manifold, GT3076R, CO2 Sprayer, DG Spoiler, Nextmod Front Lip & More
joeylow is offline   Reply With Quote
 Old 05-26-2008, 03:35 PM   #3
ms3-87's Avatar
is their a for sure way to tell like oil somewhere that it wouldent normally be if i have a blown turbo...some are saying oil catch can some are saying blown turbo
 Old 05-26-2008, 03:43 PM   #4
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
its most likely your tbe, i think a "oil catch can" corrects this?
 Old 05-27-2008, 06:08 AM   #5
fdkss03's Avatar
Posts: 89   (View Stats)
fdkss03 will become famous soon enough
i took my car into the dealer for this last week...
waiting to hear back from them, they told my friend that is in there all the time
it could be several weeks before I have my car again.
They have seen upwards of 20 ms3's with turbo problems
cobb sri, cobb springs, dogbone mount, trz short shifter, resonator delete
and awhile back.... cobb ap, cp-e downpipe
fdkss03 is offline   Reply With Quote
 Old 05-27-2008, 12:15 PM   #6
gsrtype1's Avatar
Groans: 102
i wonder if just a midpipe would cuase this?
 Old 05-27-2008, 08:06 PM   #7
winniep's Avatar
Posts: 333   (View Stats)
winniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the world
I have read of a few cases where just the midpipe brought on the smokage.........
The fastest MS3 in the whole garage...
winniep is offline   Reply With Quote
 Old 05-27-2008, 08:15 PM   #8
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
from what i've read, reduced back pressure causes a reduction in the resistance in the PCV allowing oil to flow easier into intake manifold. since the PCV IS only open at idle and light cruising this is why you see smoke at this point because its getting burned up.
ultimately an oil catch can will probably fix this as well as cleaning out the intake manifold.
The Following User Says Thank You to bova For This Useful Post:
gsrtype1 (05-30-2008)
 Old 05-30-2008, 09:36 AM   #9
gsrtype1's Avatar
Groans: 102
so its not the turbo seals cuaseing the smoke??
 Old 05-30-2008, 09:51 AM   #10
bova's Avatar
Groans: 45
picture of my pcv hose, the whole inside of it was gunked with oil when i put my finger in it
 Old 05-30-2008, 12:50 PM   #11
fdkss03's Avatar
what is a good catch can that will work properly?
i know they are hard to come by...
 Old 05-30-2008, 01:02 PM   #12
bova's Avatar
Groans: 45
saikou michi
 Old 05-31-2008, 01:15 PM   #13
TRU-BOOST's Avatar
Posts: 801   (View Stats)
TRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the world
fuel wont make smoke come out. its oil from the pcv. a catch can will fix you up. if you dont see smoke under heavy throttle, it aint the turbo .
TRU-BOOST is offline   Reply With Quote
Ontario introduces bill to protect "children" from secondhand smoke Haltech Automotive News 0 05-02-2008 05:08 AM
Installed the Turbo xs DP and let it smoke! speed3 MazdaSpeed 3/6 - Turbo Induction 38 04-15-2008 06:20 PM
HOLY FRIGGIN SMOKE(S) Death-From-A-Mile MazdaSpeed 3/6 - Turbo Induction 71 04-02-2008 01:41 PM
Page generated in 0.30471 seconds with 26 queries
