 Old 02-04-2020, 11:44 PM   #1
T Lash's Avatar
Posts: 3   (View Stats)
T Lash is an unknown quantity at this point
Default Speed 6 electrical manual
I am in need of the Speed 6 electrical manual. I am searching for the color codes for the engine harness. I have two connectors that are the same. One is for the VTCS the other one is for the Knock sensor. The O am getting codes for both. The VTCS is shows stuck closed or stuck open depending on which connector I use. I may have screwed both sensors up by switching the connectors.
I am also getting a code for the EGR but I am not worried about it since I removed it and installed a EGR block off.
Thanks for any help.
T Lash is offline   Reply With Quote
 Old 02-05-2020, 07:51 AM   #2
Posts: 2,233   (View Stats)
you may look at engine harness pictures, unless you removed all the tape, each follow a pattern to be plugged at the right place. I played with that quite few times and if you have to remove tape or squeeze them, it is because there is something wrong...
Speed 6 Workshop Manual 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 26 04-16-2018 10:48 AM
Chevy Camaro to get Corvette's seven-speed manual? Haltech Automotive News 0 01-22-2018 08:20 AM
Report: Next Corvette will sport seven-speed manual, too Haltech Automotive News 0 09-26-2011 09:50 AM
Mazda CX-5 to get 2.2-liter turbodiesel, six-speed manual Haltech Automotive News 0 06-15-2011 03:10 PM
Report: Next-gen Porsche 911 to get seven-speed manual transmission? Haltech Automotive News 2 06-01-2011 07:41 AM
Page generated in 0.23066 seconds with 21 queries
