These are all the trouble codes for mazdaspeed 3 check engine light Here are all the codes just in case someone needs them. P0011 CMP timing over-advanced ON 2 CCM P0012 CMP timing over-retarded ON 2 CCM P0031 Front HO2S heater circuit low input ON 2 O2 sensor heater P0032 Front HO2S heater circuit high input ON 2 O2 sensor heater P0037 Rear HO2S heater circuit low input ON 2 O2 sensor heater P0038 Rear HO2S heater circuit high input ON 2 O2 sensor heater P0101 MAF sensor inconsistent with TP sensor or engine speed ON 2 CCM P0102 MAF circuit low input ON 1 CCM P0103 MAF circuit high input ON 1 CCM P0106 MAP sensor performance problem ON 2 CCM P0107 MAP sensor circuit low input ON 1 CCM P0108 MAP sensor circuit high input ON 1 CCM P0111 IAT circuit performance problem ON 2 CCM P0112 IAT circuit low input ON 1 CCM P0113 IAT circuit high input ON 1 CCM P0117 ECT circuit low input ON 1 CCM P0118 ECT circuit high input ON 1 CCM P0122 TP sensor No.1 circuit low input ON 1 CCM P0123 TP sensor No.1 circuit high input ON 1 CCM P0125 Excessive time to enter closed loop fuel control ON 2 CCM P0126 Coolant thermostat stuck open ON 2 Thermostat P0128 Coolant thermostat stuck open ON 2 Thermostat P0131 Front HO2S (stuck low) ON 2 CCM P0132 Front HO2S (stuck high) ON 2 CCM P0133 Front HO2S circuit malfunction ON 2 O2 sensor P0134 Front HO2S circuit no activity detected ON 2 CCM P0137 Rear HO2S circuit low input ON 2 CCM P0138 Rear HO2S circuit high input ON 2 CCM P0140 Rear HO2S circuit no activity detected ON 2 CCM P0171 Fuel trim system too lean ON 2 Fuel P0172 Fuel trim system too rich ON 2 Fuel P0222 TP sensor No.2 circuit low input ON 1 CCM P0223 TP sensor No.2 circuit high input ON 1 CCM P0300 Random misfire detected Flash / ON 1 or 2 Misfire P0301 Cylinder No.1 misfire detected Flash / ON 1 or 2 Misfire P0302 Cylinder No.2 misfire detected Flash / ON 1 or 2 Misfire P0303 Cylinder No.3 misfire detected Flash / ON 1 or 2 Misfire P0304 Cylinder No.4 misfire detected Flash / ON 1 or 2 Misfire P0327 Knock sensor circuit low input ON 1 CCM P0328 Knock sensor circuit high input ON 1 CCM P0335 CKP sensor circuit malfunction ON 1 CCM P0340 CMP sensor circuit malfunction ON 1 CCM P0401 EGR flow insufficient detected ON 2 EGR P0402 EGR flow excessive detected ON 2 EGR P0403 EGR valve (stepper motor) circuit malfunction ON 2 CCM P0420 Catalyst system efficiency below threshold ON 2 Catalyst P0441 Evaporative emission control system incorrect purge flow ON 2 Evaporative P0442 Evaporative emission control system leak detected (small leak) ON 2 Evaporative P0443 Evaporative emission system purge control valve circuit malfunction ON 2 CCM P0446 Change over valve (COV) (EVAP system leak pump) stuck close ON 2 Evaporative P0455 Evaporative emission system leak detected (gross leak) ON 2 Evaporative P0456 Evaporative emission system leak detected (very small leak) ON 2 Evaporative P0461 Fuel gauge sender unit circuit range/performance ON 2 CCM P0462 Fuel gauge sender unit circuit low input ON 2 CCM P0463 Fuel gauge sender unit circuit high input ON 2 CCM P0480 Fan relay No.1 control circuit malfunction OFF 2 Other P0481 Fan relay No.2 and No.3 control circuit malfunction OFF 2 Other P0482 Fan relay No.4 control circuit malfunction OFF 2 Other P0500 Vehicle speed sensor (VSS) circuit malfunction ON 2 CCM P0505 Idle control system malfunction OFF P0506 Idle control system RPM lower than expected ON 2 CCM P0507 Idle control system RPM higher than expected ON 2 CCM P0550 PSP switch circuit malfunction ON 2 CCM P0564 Cruise control switch circuit malfunction OFF 1 Other P0571 Brake switch circuit malfunction OFF 1 Other P0601 Internal control module memory check sum error ON 1 CCM P0602 PCM programming error ON 1 CCM P0604 PCM RAM error ON 1 CCM P0606 ECM/PCM processor ON 1 CCM P0607 Control module performance ON 1 CCM P0610 Control module vehicle options error ON 1 CCM P0638 Throttle actuator control range/performance ON 1 CCM P0661 Variable intake-air system control solenoid valve circuit low input OFF 2 Other P0662 Variable intake-air system control solenoid valve circuit high input OFF 2 Other P0703 Brake switch No.1 circuit malfunction ON 2 CCM P0704 Clutch switch circuit malfunction ON 2 CCM P0850 Neutral switch circuit malfunction ON 2 CCM P1410 VAD control system circuit malfunction OFF 2 Other P1562 PCM +BB voltage low ON 1 CCM P2004 Variable tumble control system (VTCS) shutter valve stuck open ON 2 CCM P2006 Variable tumble control system (VTCS) shutter valve stuck closed ON 2 CCM P2009 Variable tumble control solenoid valve circuit low input ON 2 CCM P2010 Variable tumble control solenoid valve circuit high input ON 2 CCM P2088 CMP actuator circuit low ON 2 CCM P2089 CMP actuator circuit high ON 2 CCM P2097 Post Catalyst Fuel Trim System Too Rich P2100 Throttle actuator circuit open ON 1 CCM P2101 Throttle actuator circuit range/performance ON 1 CCM P2102 Throttle actuator circuit low input ON 1 CCM P2103 Throttle actuator control motor circuit high input ON 1 CCM P2107 Throttle actuator control module processor ON 1 CCM P2108 Throttle actuator control module performance ON 1 or 2 CCM P2119 Throttle actuator control throttle body range/performance ON 2 CCM P2122 Accelerator pedal position (APP) sensor No.1 circuit low input ON 1 CCM P2123 Accelerator pedal position (APP) sensor No.1 circuit high input ON 1 CCM P2127 Accelerator pedal position (APP) sensor No.2 circuit low input ON 1 CCM P2128 Accelerator pedal position (APP) sensor No.2 circuit high input ON 1 CCM P2135 Throttle position sensor No.1/No.2 voltage correlation ON 1 CCM P2138 Accelerator pedal position (APP) sensor No.1/No.2 voltage correlation ON 1 CCM P2177 System too lean at idle, bank 1 P2187 System too lean at idle, bank 2 P2228 BARO sensor circuit low input ON 1 CCM P2229 BARO sensor circuit high input ON 1 CCM P2401 Evaporative emission system leak detection pump control circuit low ON 2 Other P2402 Evaporative emission system leak detection pump control circuit high ON 2 Other P2404 Evaporative emission system leak detection pump sense circuit malfunction ON 2 Other P2405 Evaporative emission system leak detection pump sense circuit low input ON 2 Other P2406 Evaporative emission system leak detection pump sense circuit high input ON 2 Other P2407 Evaporative emission system leak detection pump sense circuit intermittent ON - Other P2502 Generator terminal B circuit open OFF 1 Other P2503 Generator output voltage signal no electricity OFF 1 Other P2504 Battery overcharge OFF 1 Other |
Very nice. |
Lol made in 2010 :smashfreakB: |
I was adding it as a sub and intentionally bumping it. It's too bad it's not a sticky in the Diagnostic section.. not sure why it's in here. |
This should be stickied |
I second that for stickie... We need one for our speed6's too though. :/ |
@Raider; make into sticky please. Don't know how this was overlooked |
Complete n00b question.. so the check engine light came on my '09 Speed3. I have scoured the sight to find out HOW to obtain codes and this is what I found... don't listen to these goofs. hold down the trip meter reset button while turning the key to 'on'. you will see the flashing dashes. press it two more times and you'll then be in a diagnostic menu that will tell you the specific component that is failing. make sure you are in neutral, e-brake off, and not pressing any of the pedals (you may have to put a brick under a tire if you are on a grade). if you are pressing any of the pedals while doing this, they will fail the diagnostic check and youll have the CEL on for yet another reason. when i did this on mine, i even had the dome light on and the ECU flagged it. make sure everything is off! If this is right, it went into a "Test" mode. went thru them all and didn't find a Pxxxx code. Closest thing I found was a 0043 with 22 underneath it. Someone school me... |
If you don't have an AP, go to your local auto store to get the code pulled. I have not heard that before but I'm sure someone has |
cutting out. CorkSport short ram intake with turbo inlet hose, OBX catback exhaust, OBX downpipe ,front mount intercooler,blow off valve recirculating,access port v3, tuned to stage 3 ever since I put the OBX downpipe everytime I step on it it cuts out like its losing gas spark or air its also putting out that code p0137 which says Bank 1 sensor 2 circuit low and p0139and this one says the same thing pretty much except it says slow response Can anyone help? |
Make a new thread. Donate. Post a log. |
Quote:
What does "On 2 Fuel" mean? Refer to code P0171 |
Nice, necro on a year old thread. sent from my HTC One M9 |
I have a '12 speed3 and it threw a p0300 and the mechanic drove the car and said it had no loss of power and the cel went away. the cel came back on recently and went away again. has anyone else had this problem? Sent from my SM-G935T using Tapatalk |
Any one have a current list i have a p0579 and a p2006... obviously i can google them but i only find generic information |
Quote:
CEL 2007 speed3 Should i be worried that my check engine light keeps coming on and shutting off for a few days. I recent did spark plugs, oil change, car has 140.000? should i get it in a shop and check head gaskets or anything serious? first speed3 |
| All times are GMT -7. The time now is 06:15 AM. |
