  • 1 Post By The Great NY
  • 1 Post By Dawey1
 Old 03-06-2011, 05:23 PM   #1
countrymanjeff's Avatar
Posts: 10   (View Stats)
countrymanjeff will become famous soon enough
Groaned at 5 Times in 1 Post
Default traction control light on....
i had some issues with my pcm getting wet awhile back, i got the car fixed and when i got it back the traction control light was on. i asked them why and the mechanic told me it was because i had over boost. any thoughts on this? i dont understand why the traction control system would be affected by this there are no CELs just the traction light.
help me.
countrymanjeff is offline   Reply With Quote
 Old 03-06-2011, 05:27 PM   #2
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
i'd try a different, non-retarded mechanic.
The Following 5 Users Say Thank You to karl-hungus For This Useful Post:
jtspells (06-12-2011), justint5387 (03-07-2011), kgb (03-19-2011), phillyb (03-06-2011), thehead (03-06-2011)
 Old 03-07-2011, 04:53 PM   #3
i figured that. i was just wondering if anyone would know maby whats going on.
 Old 03-07-2011, 04:56 PM   #4
patrick failman
Groans: 74
yeah, go to another dealer.
 Old 03-07-2011, 08:32 PM   #5
i will when i get time to do so...
 Old 03-18-2011, 10:35 AM   #6
Dawey1's Avatar
Dawey1 is an unknown quantity at this point
Any progress?
I kinda have a similar situation.
Dawey1 is offline   Reply With Quote
 Old 03-18-2011, 11:21 AM   #7
The Great NY's Avatar
Posts: 360   (View Stats)
I would check the ABS wheel speed sensor connections. Maybe one jarred loose. Or was pulled off somehow during the work they did. Your ecu is in the engine bay so if it was getting wet I wonder if they removed the splash guard or something and maybe caught the plug and pulled it out a bit.
Also...a shot in the dark but very possible. Check your switches on the brake pedal. Make sure the plugs and wires are secure and not damaged. And check to make sure you have all your brake lights working. And check the plugs for those lights and wires.
Don't ask why but it has to do with system failsafes how they are kinda tied into each other. I haven't looked at the circuit on your car but its probably setup similar to every other car.
Sent from my HTC Vision using Tapatalk
The Following User Says Thank You to The Great NY For This Useful Post:
FORZDA 1 (03-18-2011)
 Old 03-18-2011, 12:41 PM   #8
Dawey1's Avatar
Where exactly is the ecu in the engine bay?
I'm going to check the connectors on:
-ECU
-Wheel speed sensor
-Brake lights
Thank you for the info.
 Old 03-18-2011, 12:42 PM   #9
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
low brake fluid and very low brake pads can cause this issue aswell
Carry on citizens....
10.7 @ 133 auto 1G DSM
 Old 03-18-2011, 12:46 PM   #10
MazdaASM's Avatar
Posts: 491   (View Stats)
MazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the world
Groaned at 9 Times in 7 Posts
i dont know if this happens on our cars as well but... i know on the miatas and rx8's when the batter is unhooked for extended periods you have to "reset" the traction control system, try turning the wheel from lock to lock then centered again, all with the ignition on but vehicle off.... then start the car
MazdaASM is offline   Reply With Quote
The Following User Says Thank You to MazdaASM For This Useful Post:
Dawey1 (03-18-2011)
 Old 03-18-2011, 12:54 PM   #11
Neutral  +1 score
-ECU
-Wheel speed sensor
-Brake lights
Don't qoute me and someone correct me if I'm wrong. But I believe the speeds have the ecu near the driverside strut tower.
Dawey1 likes this.
Dawey1 (03-18-2011)
 Old 03-18-2011, 03:51 PM   #12
ZipprSuitdSungod's Avatar
Posts: 497   (View Stats)
ZipprSuitdSungod is the leader of the worldZipprSuitdSungod is the leader of the worldZipprSuitdSungod is the leader of the worldZipprSuitdSungod is the leader of the worldZipprSuitdSungod is the leader of the worldZipprSuitdSungod is the leader of the worldZipprSuitdSungod is the leader of the worldZipprSuitdSungod is the leader of the worldZipprSuitdSungod is the leader of the worldZipprSuitdSungod is the leader of the worldZipprSuitdSungod is the leader of the world
Groans: 68
Neutral  -1 score
Did someone say "batter"???
In before pancakes/waffles.
2011 MS3. Tech Package. Ventureshield Clear Bra. Rally Armor urethane mud flaps. WeatherTech FloorLiners. Valentine 1. DashDaq XL.
Mods to follow after the enhanced PIDs are released.
ZipprSuitdSungod is offline   Reply With Quote
 Old 03-18-2011, 10:46 PM   #13
Dawey1's Avatar
Default Pulled the ECU
Disconnected the ECU and re-tested the system... the fuse did not blow!
I've removed the ECU and cleaned all the connectors with electrical contact cleaner.
It's drying right now. I'll be putting it back together soon.
I'm going to connect one sensor at a time and re-test along the way.
Hopefully this solves the blown fuse problem.
Thanks again for the assistance guys.
Will post with results.
hung380 likes this.
 Old 05-28-2011, 06:55 AM   #14
DasPirate's Avatar
Posts: 3   (View Stats)
DasPirate is an unknown quantity at this point
Any updates with this? I've been having a similar problem cropping up with my speed 6 and the connectors seem fine.
DasPirate is offline   Reply With Quote
 Old 06-04-2011, 02:58 AM   #15
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
remove the bulb
 Old 06-11-2011, 08:53 PM   #16
get_boosted's Avatar
Posts: 2   (View Stats)
get_boosted is an unknown quantity at this point
i had this same issue with my normal 3 and i took it to the mazda dealer and they told me my traction control module was bad and they cost about $1000 to replace.
get_boosted is offline   Reply With Quote
 Old 04-01-2016, 06:47 PM   #17
Lex2007's Avatar
Posts: 574   (View Stats)
If the brake fluid is low the brake light indicator in the dash comes on. Why would traction control light come on?
 Old 04-01-2016, 07:08 PM   #18
sh4d0w's Avatar
Posts: 565   (View Stats)
sh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the world
Groans: 45
Groaned at 7 Times in 4 Posts
LOL ... Responds to post from 2011.
2010 Black MS3
Cobb AP // Cobb EBCS // Cobb Downpipe // Cobb RMM // JBR Tru 3.5'' Intake // JBR TMM // JBR PMM // JBR RSB // CP-E Cat Back // NGK One step colder plugs // GT 3071r // Azenis 615k // Bilstein PSS B14 Coilovers // Treadstone TR8 FMIC // Bully Stage 4 Clutch // Damon EGR Delete // Autotech HPFP // AEM V1 Meth Kit 50/50 // Freektuned 94 Oct
sh4d0w is offline   Reply With Quote
Traction control & brake light coming on dutchbuffalo MazdaSpeed 6 - Engine, Transmission & Driveline 21 01-21-2011 07:14 AM
HELP! Traction control light and Weird idle after motor mount install? xcoldricex MazdaSpeed 3 - Engine, Transmission & Driveline 15 05-20-2010 04:16 AM
Customizing Traction Control with LC Trader
Cobb ATR Support
6 08-19-2009 10:10 PM
Traction control light tuners MazdaSpeed 3/6 - Suspension & Brakes 1 07-20-2009 06:14 PM
Traction Control (MS3 specific) SLS MS3
Cobb ATR Support
15 06-08-2009 01:08 PM
Page generated in 0.36189 seconds with 31 queries
