> Car Detailing
Car Detailing Wanna show off your hard work? Need help with swirl removal, scratches or general detailing questions? Come on in!
Like Tree5Likes
 Old 01-26-2015, 12:14 PM   #81
Tyhackman15's Avatar
Posts: 1,742   (View Stats)
Can anyone comment on how the LPS3 holds up to a touchless car wash that has a high pressure undercarriage spray?
I've only gone through those twice or so, but so far it's holding up just fine. It literally turns to something the consistency of beeswax, I'd imagine it'll take some serious psi to mess with it. Can't say for sure though, who knows what chemicals are in those washes.
Here's a good test/review I stumbled upon.
Test of Corrosion Inhibitor Sprays - The Hull Truth - Boating and Fishing Forum
Last edited by Tyhackman15; 01-26-2015 at 12:14 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to Tyhackman15 For This Useful Post:
802MS3 (01-26-2015)
 Old 03-19-2015, 06:49 AM   #82
Vex
Vex's Avatar
Posts: 30   (View Stats)
Vex has a little shameless behaviour in the past
any alternatives if i dont have access to a sand blaster? Will using a wire brush and rust converter then a rust inhibitor work? i have surface rust under the frame and sub frame as well as some bolts and what not. the sub frame is getting surface rust on the rear...
08.5 Mazdaspeed3 TrueRed // JBR intake // COBB Short Throw Shifter // AutoTech HPFP Internals //
Vex is offline   Reply With Quote
 Old 09-09-2015, 09:10 AM   #83
aviator79's Avatar
Posts: 3,934   (View Stats)
Put my car up on jackstands in the driveway Friday and took wheels, wheel wells and pumpers off. Then used my 90* tip on my pressure washer to clean the dirt off everything. All went well except with I tried to hook up my zip tie to hold the trigger on and lost my grip and the want spun 360* around and nailed my rear quarter panel so now I have a big dent I need to get repaired.
Also note the rear wheel well covers are carpet and absorb road salt and every time the get wet the salt is reactivated and is likely what has caused so many MS6/M6 rear quarter panels to rust out. So I left mine off.
Another issue is where the rear bumper rubs on the rear quarter panel. I have tried to repair this before when I saw the paint rubbed off but seems it is just going to keep happening.
 Old 09-09-2015, 09:21 AM   #84
aviator79's Avatar
Here are pics of rust before pressure washing.
Sorry for so many pics but as you can see I had some bad rust.
PS rear door forming rust in the door jam. I will have to pull panels as it looks like it is forming from the inside.
I had some rust in rear quarter panels from the wheel well covers and from rolling the fenders. I sprayed the shit out of the wheel wells.
Sprayed everything.
Sprayed underside of hood.
Sprayed in hood using the hose on the can thru the holes. Then using no hose but catching the bottom lip of the spray tip on the sheet metal and spraying all up in there.
Did around weather strip in trunk where there was rust on bottom where the sheet metal was joined under the weather strip. My trunk lid has some rust due to spray foam I put in there that over expanded and cracked welds at front/top PS side.
Hard to get up under rear subframe. Wish I had done this 80k ago or at least a few years ago when car was still fairly clean. One winter of 100mi round trip commuting in CT on highways where they use the liquid magnesium chloride or some other chloride ice melt.
Rear crash bar was a mess of rust as it has no protection on the inside so I just sprayed as much as I could in there.
Front exhaust heat shield is also a mess. Really need to remove these and get behind them. But in the end then you might was well strip car and do it all...so much work.
I have no after shots cause I just needed to get car back together. Used 5-6 cans.
So get under your car and rust proof. Next time I will just pay the $350 to have a local place do fluid film. Doing this job was a sticky mess.
Artist uses rust as brush to paint cars Haltech Automotive News 0 01-27-2012 06:40 AM
Preventing fraud is key concern as cash-for-guzzlers takes shape Haltech Automotive News 0 06-22-2009 03:40 PM
Page generated in 0.27314 seconds with 23 queries
