Like Tree5Likes
 Old 08-17-2012, 03:41 PM   #1
YokiMazoku's Avatar
Posts: 320   (View Stats)
YokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the world
Default Aquamist HFS-4 quick review more to come
Okay so I got the Aquamist HFS-4 in the mail today. Unit will be getting installed in about 2-3 weeks. I will keep this updated with pics and what I think of the kit. So with that said I do want to send a special thanks to Dustin for helping the guys over at Aquamist get this kit setup properly for our car. By the way Richard also sends his thanks.
Alright so I ordered this kit from Jeff at Howerton Engineering the guy was a lot of help answered all my questions. Great guy to do business with. If you order this kit tell them it is a mazdaspeed they will make adjustment to the controller for our car b/c our ECU is weird. For a more technical explanation maybe Dustin will chime in.
Finally on to the kit itself. Here are some pics of what comes with it. When I looked at all the parts it looks solid. Unit has 4 built in fail safes. And of course the flow gauge to make sure it is working. Im not gonna go over everything this kit can do it would take to long. Few small things to note is the unit doesn’t come with a tank you probably already know. Also the nozzles are smaller than the standard 1/8 but it does come with an adapter to fit the 1/8 size and you don’t get any 90 degree adapter with this kit. If you want to run more than 2 nozzles you need to have some adjustments made to the controller.
Okay so when it comes to tuning I know very little at best. rfinkle I know you were helping me before but life happened and well I was unable to continue. But if you have the time I'd love some help getting this dialed in. I would like to run dual nozzles to see how the car acts. With the HFS-4 unit it can run based off boost or IDC or even a mix of both. So that will be interesting to see.
On that note I know this is not a cheap unit but the benefits are undeniable. And the quality well it speaks for itself. Also after I priced out all the parts for the other kits that would do even close to what this one does I was only paying maybe a hundred or so more.
Okay I got the devils own tank in the mail today. Tank build quality looks good very nice piece. Good job devils own. Here are some pics. Can't wait to get this kit put in!
UPDATE!
Okay its been a few months the kits installed i have a few loose ends to finish up but other than that the kit is awesome. The thing is extremely sensitive to IDC. I tested it on 12% "with the nozzle in the windsheild" and light throttle it was spraying with very fine mist. A few notes for those doing the install later buy some quality taps if your going to be tapping the PCM. I went the posi lock and they work really well. The Aquamist wires are very very small i wanna say there 24 gauge wires.
Here are some things that will help with the install its only for the MAZDASPEED 3 Gen 1.
Also the PCM diagram can be located here: ECU Diagram and Pinouts
On the Gen1 the colors of the wires maybe slightly different but follow the PCM diagram pin numbers they match up to the diagram Aquamist provides.
Also the HSF4 diagram show the 2BB fuel injector coil - as white well on the ms3 gen 1 its actually white/violet.
I will be posting a video of the nozzle spraying and a driving video with it in the windshield at 12% IDC.
**********IMPORTANT********************
I spent a long time trying to figure out why my flow sensor kept picking up readings when i wasnt spraying! Very annoying! So go to autozone buy some heat wrap
and wrap the flow sensor *thats connected to the FAV* this will stop the false flow. Found out magnetic fields can cause this so save yourself some time....Your Welcome
Boobs.....because you can't motorboat a personality.
YokiMazoku is offline   Reply With Quote
The Following 12 Users Say Thank You to YokiMazoku For This Useful Post:
08.5MS3 (08-27-2012), adlpb (01-07-2013), ArcticSpeed3 (08-17-2012), BobtailedSnail (08-17-2012), Boost Addict (08-17-2012), Code Monkey (08-17-2012), dan7225 (08-17-2012), djuosnteisn (08-17-2012), Downmented (10-15-2012), Nliiitend1 (02-24-2013), skeurton (08-17-2012), uncorked11 (08-17-2012)
 Old 08-17-2012, 03:49 PM   #2
uncorked11's Avatar
Posts: 1,238   (View Stats)
Groans: 165
I am looking at this kit for early sept.
New....Camaro SS/RS
Stocked out selling parts.
2011 Black MS3
2006 Jeep Wrangler
-20 grand of Shit
 Old 08-17-2012, 04:11 PM   #3
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
While it's a beautiful kit and the failsafes are a real nice add-
You could have done the same thing for $500 less.
To each his own..still probably the best kit for our or most any street platform
*edit*
Then again a new motor due to meth fail is a lot more expensive.
The Following 3 Users Say Thank You to helmetface For This Useful Post:
Captain KR (08-17-2012), Downmented (10-15-2012), YokiMazoku (08-17-2012)
 Old 08-17-2012, 04:33 PM   #4
YokiMazoku's Avatar
helmetfail...... my thoughts exactly.
The Following User Says Thank You to YokiMazoku For This Useful Post:
helmetface (08-17-2012)
 Old 08-17-2012, 05:10 PM   #5
BobtailedSnail's Avatar
Posts: 1,375   (View Stats)
I have been eyeballing this kit and I think Ima get it as well
Skreets be calling...
 Old 08-17-2012, 05:44 PM   #6
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Hands down the best meth kit out there. The fuel metering is in a league of it's own, and Aquamist has done a ton of homework to make it work seamlessly with our DI.
Grats on the purchase OP. Can't wait to see some results.
JumpingJackson is running the same kit iirc. So if you have any questions, he'd probably be a good person to PM.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
uncorked11 (08-17-2012), YokiMazoku (08-17-2012)
 Old 08-17-2012, 06:10 PM   #7
skeurton's Avatar
Posts: 745   (View Stats)
skeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the world
I bought this kit months ago and it's still sitting on the shelf. DOH! You'll probably install yours before I get the chance to, so I'm definitely subbed for results.
2011 MAZDASPEED 3
BNR: 352 hp / 342 ft-lbs
K04: 296 hp / 343 ft-lbs
BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges
skeurton is offline   Reply With Quote
The Following User Says Thank You to skeurton For This Useful Post:
 Old 08-17-2012, 07:36 PM   #8
Dust's Avatar
Posts: 192   (View Stats)
Dust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the world
Care to explain?
Dust is offline   Reply With Quote
 Old 08-17-2012, 07:47 PM   #9
helmetface's Avatar
Groans: 219
Originally Posted by Dust View Post
Care to explain?
Aquamist ~$8-900iirc
DO $300
 Old 08-17-2012, 07:52 PM   #10
Boost Addict's Avatar
Posts: 1,327   (View Stats)
Boost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the world
Ugh I envy you
2008.5 BM MS3 // Cobb AP V3// JBR 3.5" WP Full Intake // CXRacing Piping/Godspeed Core // CNT 3" Catted Downpipe // Custom 3" CBE // KMD v2.1 Fuel Pump Internals // Turbosmart Dual Port BOV // Airlift Suspension // Corksport Skid Plate // JBR 88Duro Dogbone RMM // JBR SSP // SURE AGS Knob // Denso ITV22 // STACK Boost Gauge // DDM 6k Low HID's // CP-e Towplate // 15% Tint // 18x10 Blitz Type 03
FREEKTUNE
Boost Addict is offline   Reply With Quote
 Old 08-17-2012, 08:08 PM   #11
ArcticSpeed3's Avatar
Posts: 543   (View Stats)
ArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the world
I've been eyeing this kit as well. I'll be getting it at the end of this month.
2006 MS6 BCM
"Fully Bolted, DSS Rear Axles, Soon GTX3076R, SB Stg 3 Drag Clutch, 6th Port" (DRAG CAR)
2009 Chevy TBSS AWD 3SS
"Full Exhaust, Intake, Tune" (MAN VAN)
1997 Lexus SC300 Black/Black
"2JZGTE, BW S366 @15psi" (SOLD)
2011 MS3 CBM
"Fully Bolted" (Parted Out and Sold)
ArcticSpeed3 is offline   Reply With Quote
The Following User Says Thank You to ArcticSpeed3 For This Useful Post:
BobtailedSnail (08-18-2012)
 Old 08-17-2012, 08:22 PM   #12
Dust's Avatar
DO $300
If you got in on the group buy, $700.
DO is 300, plus $250 for the AEM flow monitor, and $20 for the AEM filter. But you still have a pulsed pump instead of a pulsed solenoid, and a controller that is taking up most threads in your forum.
Or go used with a HFS-3v2 which can be found for a little less, or used starting at $450
 Old 08-17-2012, 08:25 PM   #13
helmetface's Avatar
Groans: 219
I wouldn't purchase the flow monitor if I were to go with the DO kit.
That's the point.
Obviously, if you're looking for the best of the best, this kit is where it is at. I am just saying, several have gotten by just fine without all the bells and whistles.
 Old 08-17-2012, 09:21 PM   #14
YokiMazoku's Avatar
Well its good to see this kit grow some interest. I didnt realize there are a few people who already have it. I will be sending jumpingjackson some messages in the future lol. I still havent decided if i want to run from full IDC or mix of boost and IDC. Only time will tell i guess.
There are other kits out that maybe perfectly fine and helmet is right many have gotten away with a cheaper setup. But this is by far the best option out there for safety and tuning at least i think so. Also i really like the IDC option for our car
 Old 08-18-2012, 08:23 AM   #15
paveltol's Avatar
Posts: 520   (View Stats)
Congrats to OP! I also have this kit sitting on the shelf for half a year. Quality of the parts is really nice!
BTW is there anyone having this kit installed on MS6?
paveltol is offline   Reply With Quote
 Old 08-18-2012, 08:54 AM   #16
Great kit that I would trust a lot more if I was using Meth as a fuel on a big turbo. If on a k04 and using it just for cooling it is a little overkill.
Sent from Stratified Mobile Headquarters
jack_hammer (01-09-2013)
 Old 08-18-2012, 08:13 PM   #17
Dust's Avatar
That's the point.
No worries, I was just trying to keep the pricing apples to apples for those who may not know.
 Old 08-18-2012, 08:17 PM   #18
helmetface's Avatar
Groans: 219
For sure.
 Old 08-27-2012, 10:01 PM   #19
YokiMazoku's Avatar
One other thing i want to mention about this kit. It is very well organized I've been looking it over a lot now that i have all the parts and there are details on the bags telling me about
the piece and where it goes. That's just awesome makes it very easy to put together.
 Old 08-27-2012, 10:20 PM   #20
Dust's Avatar
The only thing that would make it easier would be an OBD-2 port for power grounds and everything else.
 Old 10-15-2012, 04:43 AM   #21
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
I was very interested in this kit as of recently, had some hesitation as to whether or not anyone had actually used it with our platform. Now that i see there are people who have used it with success i think i will also be going this route, possibly only with the HFS-3 kit, it is hard to justify that extra $$ between the HFS 3- and HFS 4.
Please someone chime in with their exp with these kits.
700HP CLUB
11.479@124mph
#DIX
 Old 11-16-2012, 07:29 PM   #22
YokiMazoku's Avatar
I should probably update this. This kit is installed on the car not fully functional yet as i havent had time to finish the last bit of wiring. But i spent more time on the truck and mounting the tank. I almost returned the kit as i couldn't think of a good way to hid the huge tank.
After weeks of thinking about what i wanted to do i finally found a good way to do it. Here are some pics of the hidden tank.
InFeXIoN (11-19-2012)
 Old 11-16-2012, 07:32 PM   #23
Dust's Avatar
Nice install, but you know people will want to know how you got it in there.
 Old 11-19-2012, 06:40 PM   #24
Voltwings's Avatar
Posts: 3,713   (View Stats)
^^ i sure as hell do, my trunk mounted tank wouldn't work there because of the Knub that sticks up in the middle of the spare tire well for the bolt holding it on to go through. Did you basically just shave that "bolt-hold-knub-thing?"
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 11-21-2012, 01:48 AM   #25
YokiMazoku's Avatar
Basically I got rid of the spare. Well here are some pics.
percevil and Tabasco69 like this.
The Following 3 Users Say Thank You to YokiMazoku For This Useful Post:
skeurton (01-08-2013), Tabasco69 (11-21-2012), Voltwings (11-23-2012)
 Old 11-21-2012, 01:52 AM   #26
Dust's Avatar
Can't wait to get my HFS-4, and might have found an extra one even. As an aside, a member posted that the metal area around the lid? rusted on them. DO said that it was the first time they had heard of it happening, but just wanted to stick that out there.
 Old 11-21-2012, 01:55 AM   #27
YokiMazoku's Avatar
Also lifted the plastic and foam with some tabs to make it fit. Also thanks to James a good friend did the custom cover to replace the stock one. That way I can go stock if I need to.
 Old 11-21-2012, 05:14 AM   #28
Downmented's Avatar
Groans: 493
Where is the center picture?
700HP CLUB
11.479@124mph
#DIX
 Old 11-21-2012, 09:58 AM   #29
YokiMazoku's Avatar
Are you talking about the piece that goes over the tank? If so its a few post above.
 Old 11-21-2012, 11:20 AM   #30
Downmented's Avatar
Groans: 493
No, the part where the wire harness is, where is that
Sent from my HTC One X using Tapatalk 2
700HP CLUB
11.479@124mph
#DIX
 Old 11-21-2012, 11:51 AM   #31
Tabasco69's Avatar
Posts: 554   (View Stats)
Tabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the world
Very good job my friend!
if you have insurance and a cell phone you will usuaully have road side assistance, at the very least have a jack, a package a rubber plugs and cement, and a can of compressed air, you do not need to carry a spare tire.
I plan to buy the same system, bar none it is the best.
Salem Oregon?! you should come out to the Portland's Cars and Coffee on saturday mornings, pretty diverse group of people, good way to scope out ideas
425whp/395ftlbs - GTX3071R .82a/r- 20psi- 92 octane pump fuel
Tabasco69 is offline   Reply With Quote
 Old 11-21-2012, 05:02 PM   #32
YokiMazoku's Avatar
LMAO omg downmented you have no idea how long i had to think about your question. Im so burt out with school work and family. Wow ok it is in the glove box lol
Downmented (11-21-2012)
 Old 11-21-2012, 05:35 PM   #33
Downmented's Avatar
Groans: 493
hahahahahahaha, I have MS6 so thats why it was difficult for me to locate that little compartment. lol
700HP CLUB
11.479@124mph
#DIX
The Following User Says Thank You to Downmented For This Useful Post:
rfinkle2 (01-08-2013)
 Old 01-07-2013, 02:12 PM   #34
YokiMazoku's Avatar
Added some info for those doing the install maybe useful.
BobtailedSnail (01-07-2013), rfinkle2 (01-08-2013), skeurton (01-08-2013)
 Old 01-08-2013, 09:36 AM   #35
skeurton's Avatar
Very impressive install!!! Few questions for you, if you don't mind...
1) What size nozzle did you go with?
2) What W-to-M mix are you using?
3) Any pics of the connections at the ECU?
2011 MAZDASPEED 3
 Old 01-08-2013, 09:42 AM   #36
Talked to a few folks here and kinda came to the conclusion PI wasn't gonna give me the fuel/octane I need, due to me not having access to E85. So I'm opting for direct port meth with this system since it cost the same as 6thport and prolly cheaper than PI.
The Following User Says Thank You to BobtailedSnail For This Useful Post:
 Old 01-08-2013, 01:02 PM   #37
YokiMazoku's Avatar
Nozzle size is the .8mm right now.
mixture will be 50/50.
I could take some pics but it wouldnt show much its all taped up.
BobtailedSnail i had the same problem e85 too far away. After reading about the FAV on the HFS4 and the IDC setup i couldnt resist.
The Following 2 Users Say Thank You to YokiMazoku For This Useful Post:
rfinkle2 (01-08-2013), skeurton (01-09-2013)
 Old 01-08-2013, 02:15 PM   #38
Exactly why I like this HFS4 I wonder if the pump will handle direct port .6mm nozzles and a 1.0 pre throttle body. Might need another pump and I need to calulate exactly what I need as far as nozzles go.
 Old 01-08-2013, 08:59 PM   #39
Tabasco69's Avatar
I'm going to be running the hsf3 w/100% methanol, using 2 .9 jets pre tb, I have a few e85 stations near by but I rather also go this route aswell.
How do you fellas use the jet sizing calculations with your direct injection, what I mean is port fuel injection is pretty simple to figure out dependent upon injector capacity at static 43.5psi versus boost psi- 165psi pump rating?
 Old 01-09-2013, 07:21 AM   #40
skeurton's Avatar
When I first tried to calculate the jet size, I was at a loss. Since our DI injectors are rated at 1700 cc/min max, the required flow rate was off the charts, even at 85% IDC. Then it occurred to me that the guidelines were for PI, like you said.
So I PM'd back and forth with Richard, and he said a good estimate to use is 500 cc/min of fuel for every 100 hp your car makes. I told him I'd like to get it to 350 hp. Adding in system losses and headroom, he recommended this to me:
- 1mm nozzle for 50:50
- 0.8mm + 0.9mm for 100% meth
In trying to verify this, I came across this thread....
GDI Injector Flow Testing/Cleaning
....which had this tidbit of info:
although he didn't want to put himself out there, David thinks that the power levels being hit right now on the OEM injectors indicate a 600-650cc flow if they were conventional injectors
Based on that, I re-did the calculations and Richard's recommendation was pretty much right on. But I may be able to run the 0.9mm for 50:50, and the 1.0mm for 100% meth.
For my calculations, I used 650 cc/min for the injectors, 85% IDC, and 22psi boost. I've attached the spreadsheet if anyone wants to mess with it.
2011 MAZDASPEED 3
Code Monkey (06-25-2014)
Welcome Aquamist to MSF Haltech Mazdaspeed3/6 General Discussion 28 03-24-2010 05:05 PM
Quick Review: Raptor - Born in Baja is Rocky for pickup trucks Haltech Automotive News 0 06-26-2009 04:20 PM
Review: Pontiac Solstice GXP Coupe goes quick, just don't look back Haltech Automotive News 0 06-24-2009 10:20 AM
Quick Kumho Ecsta SPT review killyoutoo MazdaSpeed 3/6 - Wheels & Tires 14 03-21-2009 03:48 PM
Page generated in 0.57403 seconds with 34 queries
