 Old 02-20-2012, 12:54 PM   #1
Domino81's Avatar
Posts: 5,081   (View Stats)
Default Autotech internals, 390 - 400 psi idle fuel pressure
I know 390-400 psi is fine for idle, especially when it begins to slowly rise the longer I let it idle. But, it's down 30 to 40 psi. It was ALWAYS up around 420-430. And pressure is fine once I'm into boost or really anywhere else. It just makes me a little nervous that it's down with or without the compressor on. Am I being paranoid?
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
 Old 02-20-2012, 01:02 PM   #2
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Damn iirc pressure from the in tank pump is like 50psi and you are reading under that? Is your ap and map updated with the latest version?
TEAM LUXURY
 Old 02-20-2012, 01:03 PM   #3
CCC
CCC's Avatar
Posts: 830   (View Stats)
CCC is the leader of the worldCCC is the leader of the worldCCC is the leader of the worldCCC is the leader of the worldCCC is the leader of the worldCCC is the leader of the worldCCC is the leader of the worldCCC is the leader of the worldCCC is the leader of the worldCCC is the leader of the worldCCC is the leader of the world
Groans: 214
Groaned at 15 Times in 13 Posts
^^I think he meant its just reading that much under his normal 420-430 psi
2013 Evo X - Stock (for now)
2010 Speed 3 - Sold
CCC is offline   Reply With Quote
 Old 02-20-2012, 01:12 PM   #4
Domino81's Avatar
I monitor with my Dashhawk
 Old 02-20-2012, 01:27 PM   #5
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
How many miles on the internals?
 Old 02-20-2012, 01:28 PM   #6
Domino81's Avatar
Probably barely 75-100.
Just getting it broken in.
Last edited by Domino81; 02-20-2012 at 01:28 PM. Reason: MSF Database - Automerged Doublepost
 Old 02-20-2012, 01:31 PM   #7
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
hmm same thing is happening to me now. Always 420-430, saw 390 this morning and last night. Thoughts?
 Old 02-20-2012, 01:32 PM   #8
SRTie4k's Avatar
Posts: 1,715   (View Stats)
I would think a slightly lower idle psi would be fine so long as your AFR stays around stoic. If you see it deviating from 14.7, then I'd start getting worried.
 Old 02-20-2012, 01:46 PM   #9
COCKSTRONG
Groans: 890
yeah, still idle fine, but this literally just started happening yesterday. My internals have about 5k on them.
 Old 02-20-2012, 01:49 PM   #10
Sid3wayS's Avatar
Groans: 97
O I C now... Reading > me
Yeah mine is normaly in that 430 range never really noticed them fall under that unless I was costing in neutral. Might want to take a log at idle and like said up top make sure your afr is staying at stoich.
TEAM LUXURY
 Old 02-20-2012, 02:26 PM   #11
mw6886's Avatar
Posts: 29   (View Stats)
mw6886 is a splendid one to beholdmw6886 is a splendid one to beholdmw6886 is a splendid one to beholdmw6886 is a splendid one to beholdmw6886 is a splendid one to beholdmw6886 is a splendid one to beholdmw6886 is a splendid one to beholdmw6886 is a splendid one to behold
Since you are pushing more volume with the new internals, I would think it would be safe to say that you would need less pressure. Just makes sense to me.
<M>
mw6886 is offline   Reply With Quote
 Old 02-20-2012, 02:34 PM   #12
Was it really cold? HPFP pressure drops a bit when cold. How is the pressure when running WOT? If it's fine and rises quickly to ~1800 and stays there I wouldn't worry about it.
charlesfist (02-20-2012), daafisch (02-20-2012), EdgeAutosport.com (02-21-2012), Nliiitend1 (02-20-2012)
 Old 02-20-2012, 02:52 PM   #13
Domino81's Avatar
Rises extremely quick, I even see peaks of 1900+.
 Old 02-20-2012, 02:57 PM   #14
COCKSTRONG
Groans: 890
Yeah I hold pressure fine too, just found it weird that after 6 months of the exact same idle value it dropped 30-40psi suddenly
 Old 02-20-2012, 03:11 PM   #15
triplejumper18's Avatar
Posts: 2,569   (View Stats)
Groans: 196
Dropping when coasting in neutral is normal according to Braden from Cobb.
The Following User Says Thank You to triplejumper18 For This Useful Post:
Sid3wayS (02-20-2012)
 Old 02-20-2012, 03:15 PM   #16
COCKSTRONG
Groans: 890
this is sitting at stop lights.
 Old 02-20-2012, 03:25 PM   #17
DownSideFX's Avatar
Posts: 234   (View Stats)
DownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the world
Groaned at 25 Times in 9 Posts
I just installed the AT internals, I have been seeing ~450 psi at idle. However when I drive around for a while I notice in my low/high psi it going as low as ~260, I was trying to figure out when.. I think maybe when getting off the throttle in 3rd or 4th gear. Has happened once or twice.. I see 1800+ psi though whenever I'm on it and it holds there fine.
I don't think there is an issue, the car seems to be running fantastic. Just curious.
Garage: 2014 Evolution MR, 1983 Volvo 242 Turbo
Past: 2010 Mazdaspeed3
Do not donate to this fucking shithole. lol
DownSideFX is offline   Reply With Quote
 Old 02-20-2012, 03:29 PM   #18
bigriver's Avatar
Posts: 1,123   (View Stats)
Subbed.
I typically see 420+ at idle with AC off. Dropping 30-40 psi seems odd to me too. I have 8k on my autotechs and would get a bit worried to see a sudden drop like that.
Dropping under 300 when letting off throttle is normal.
bigriver is offline   Reply With Quote
The Following User Says Thank You to bigriver For This Useful Post:
DownSideFX (02-20-2012)
 Old 02-20-2012, 03:29 PM   #19
Meder's Avatar
Posts: 1,065   (View Stats)
Meder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the world
mine idle closer too 400 as well, pump working fine. 500+ miles on internals...
Meder is offline   Reply With Quote
 Old 02-20-2012, 03:32 PM   #20
COCKSTRONG
Groans: 890
Originally Posted by bigriver View Post
Subbed.
All of this. What would make it suddenly idle lower?
 Old 02-20-2012, 03:47 PM   #21
Domino81's Avatar
I'll see 387 and slowly begin to rise. It's 33 here today.
 Old 02-20-2012, 09:40 PM   #22
HPFPUPGRADE's Avatar
Posts: 403   (View Stats)
HPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the world
Groaned at 22 Times in 17 Posts
Very common after break in, just watch the upper RPM and make sure they hold pressure in the upper RPM band when under boost.
The AFR's will stay at stoic if the fuel pressure is set to 100 psi. The ECU is very smart and will do everything it can to achieve that number at idle.
Watch this close, if after 6 months this shows up it could be showing signs of wear.
Last edited by HPFPUPGRADE; 02-20-2012 at 09:40 PM. Reason: MSF Database - Automerged Doublepost
HPFPUPGRADE is offline   Reply With Quote
 Old 02-20-2012, 11:19 PM   #23
backward_0's Avatar
Posts: 773   (View Stats)
backward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the world
Mine do the same thing they are all over the place at idle between 390-430 but hold pressure great up top. I got about 2 months on mine.
Sent from my SGH-T959 using Tapatalk
2013 WRX Stock as Fuck.
1997 Eclipse GSX
The Red Rocket, 2011 MS3 Some other bastards problem now.
backward_0 is offline   Reply With Quote
 Old 02-21-2012, 11:09 AM   #24
Domino81's Avatar
Every time I've driven it since I'm looking at 410-430.
 Old 03-13-2012, 05:31 AM   #25
G26
G26's Avatar
Posts: 2,988   (View Stats)
G26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the world
Groans: 39
I think you guys are having the same thing as a couple of us in the thread a little higher than this Low idle fp @ idle cpe pump.
Heres the situation, I don't know what causes it either.
After you get on it a little, or do a wot pull, and pull up at a light, NOT while coasting, while completely stopped, my idle fp will be 350-400 (depends on how long I got on it), and will gradually rise back to 410-430.
2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold
2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs
G26 is offline   Reply With Quote
Low Fuel pressure @ Idle w/Cp-e HPFP 801MS3 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 32 04-17-2012 07:00 AM
Low fuel pressure with autotech internals and stock nofear72784 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 38 01-03-2012 07:39 PM
60psi fuel pressure at idle! CCC MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 31 10-04-2011 06:28 AM
Fluctuating Fuel Pressure at Idle Campo MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 13 02-09-2010 07:03 PM
Page generated in 0.42463 seconds with 34 queries
