 Old 12-20-2010, 01:52 PM   #1
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
The 2030 psi # is probably speculation, dunno where it was chosen from. My guess is it'll read closer to 2100+. Someone could simply put 5 volts on the sensor line and see what # they get on a DH for fuel pressure, and call that the stock sensor limit.
Here's some data points i took a while back:
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
socks (12-22-2010)
 Old 12-20-2010, 02:02 PM   #2
708
Erich's Avatar
Posts: 4,274   (View Stats)
As mentioned, 2073.9 as logged on both the AP and DashDaq with two different stock sensors. 2030 is the max the AP will put on its display (and shows it as it top limit on display) but while displaying 2030 it will log values as high as 2073.9. I guess I could try logging to ATR to see if there is a difference. But is it possible the ECU isn't allowing the full range of the sensor as SB users seem to get higher readings?
In actual operation it would appear that the ECU is capable of reading 2073.9 off of the stock sensor. This is what I was able to log on my car using two different stock sensors (on both the dashsaq and the AP. The AP would only display 2030, but the logs would show 2073.9). I believe SSInstaller indicated that when logging through his SB, he can get readings much higher off the stock sensor (2100+ and he had seen others higher.)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f303/fuel-rail-high-pressure-sensor-upgrade-67643/
0265005303 - Virgilio Ricerca Web This thread Refback 10-18-2011 07:58 AM
High Pressure Relief Valve Option SilverDemon MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 161 04-29-2011 08:10 PM
Opinion On High RPM High Pressure Fuel Pump Spring ms3brendan MazdaSpeed 3 - Engine, Transmission & Driveline 1 07-13-2010 01:04 PM
Removing Fuel Rail...and where is the DI psi sensor located? AFcadet MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 3 11-18-2009 04:48 PM
Page generated in 0.35007 seconds with 23 queries
