Like Tree3Likes
  • 2 Post By Carskick
  • 1 Post By Carskick
 Old 05-12-2019, 11:28 AM   #1
luckycharms628's Avatar
Posts: 3   (View Stats)
luckycharms628 is an unknown quantity at this point
Default Fuel for stock mazdaspeed3
So I just bought a speed3 a week ago it’s a 2008 short ram intake(Cobb) and bilstien shocks, I have no clue if there is a tune or a HPFP on it. I’ve filled it with 93 cause it has a turbo and that’s what my 2011 GTI used. But I’ve been wondering if I don’t hit the gas can I use regular fuel rather than high octane stuff?
luckycharms628 is offline   Reply With Quote
 Old 05-12-2019, 09:40 PM   #2
Posts: 2,827   (View Stats)
In a word - no.
luckycharms628 (05-12-2019)
 Old 05-14-2019, 07:52 AM   #3
Carskick's Avatar
Posts: 315   (View Stats)
Carskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond repute
Only once was 87 in my car. When it was new, I loaned it to my dad and he filled it up for me. Shortly after getting it back, I could tell he did it. Ran like crap. If you stay out of the boost completely, it won't break anything, so in a crunch, sure.
Otherwise, don't do it.
Db09ms3 and luckycharms628 like this.
2009 Mazdaspeed 3 Sport (Original Owner) - 95k miles on original Motor & Turbo and counting
Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC w/JBR Red Tubes | SpeedDaddy TP | AT HPFP | Damond Triple Mounted | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | KWv2 Coilovers | Whiteline LCA Bushings, Anti-Lift, & Bump Steer | Whiteline Endlinks | JBR .125 FSB & RSB w/billet bushings/mounts | CS Lower Tie Bar | DM OCC w/VTA | JBR Shifter Bushings
Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold 6.5" Comps Front | Focal 6.5 Coax Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub
Other Mods: FIAMM 72112 Low Note Horn alongside stock
Mods Awaitting Install: Redline Leather Center Armrest & Handbrake Boot
Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB
Removed Mods: JBR 70A RMM | Koni STR.T Orange Shocks
Carskick is offline   Reply With Quote
 Old 05-14-2019, 10:10 AM   #4
Db09ms3's Avatar
Posts: 536   (View Stats)
Groans: 105
Yeesh, I think it tells you on the fuel door about only using premium. This car is finicky.
FWIW, I had a GT Cruiser prior to my speed and I could use 87 but the ECU adjusted. I only lost power/boost.
Stockish
 Old 05-14-2019, 10:16 AM   #5
Carskick's Avatar
You can tune the ECU to run lower quality fuel. Many modern turbo cars do, but look at their output. It's much lower than it would be if it were tuned for 91/93. Lower octane fuel means less boost/timing.
In many NA engines, tuning from 87 to 93 provides negligible gains, so why bother. In a boosted application, it's totally different.
Look at the new 2.5T from Mazda. It is designed to run on either, so I assume it has a sensor to check the fuel before it goes into the engine, similar to how a flex fuel vehicle can check the Ethanol content. The DISI 2.3 does not do this, it can only react to lower quality fuel by pulling timing or cutting boost. That's why it doesn't run well with lower octane fuel, it's tuned for 91 from the factory.
If you want to tune for 87 oct, contact a tuner and pay for a tune so you can save $.50/gallon and loose 20% of your power output. It's your car.
luckycharms628 likes this.
 Old 05-14-2019, 10:19 AM   #6
Db09ms3's Avatar
Groans: 105
Originally Posted by Carskick View Post
You can tune the ECU to run lower quality fuel. Many modern turbo cars do, but look out their ouput. It's much lower than it would be if it were tuned for 91/93. Lower octane fuel means less boost/timing.
In many NA engines, tuning from 87 to 93 provides negelegable gains, so why bother. In a boosted application, it's totally different.
Well, there's that option too OP. Tune that shit for 87!
Stockish
MS3 2010 stock, Cobb AP, stock fuel pump OK? MammaFreed3 2010 MS3 - ECU Computer Tuning 21 11-15-2011 02:31 PM
NEEDED - Stock CDFP & Stock OEM In Tank Fuel Pump Haltech Mazdaspeed3/6 General Discussion 4 10-02-2011 04:24 PM
Page generated in 0.27896 seconds with 23 queries
