| MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection Have a CDFP fuel pump question? Do you want to add Nitrous or Water Injection to your Mazdaspeed 3/6 ? Please come on in! |
![]() Join Date: Jun 2017
Rep Power: 0 ![]() Thanks: 2
(Thread Starter) | Not Ranked : 0 score The title pretty much says it all , occasionally if I listen very closely I hear a quiet whine from my fuel tank. I am thinking it's the ITFP however I'm not having problems with power cutting under WOT. Should I worry ? Should I go through the hassle of replacing or is my pump fine. Thank you in advance ! Sent from my iPhone using Tapatalk |
![]() Join Date: Sep 2016 Location: Ringgold, Georgia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 411
| Not Ranked : 0 score Pump is fine. If you ever get the point of tearing out all your interior, you'll hear it all the time. Pumps make noise, you're just listening too closely for it.
__________________ ETS TMIC, Cobb TBE, Intake, TIP, AT Internals, JBR trilogy mounts, EBCS, EGR Delete/blockoff, Bosch 3.5 MAP Bar sensor, Stripped interior #racecar |
![]() Join Date: Sep 2012 Location: Bryn Mawr, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 158
| Not Ranked : 0 score Truth. I stripped mine and can hear it fire up every time I turn the key to on. It was surprising how loud that pump is with the seats out.
__________________ Corksport: SRI & TIP, Strut Tower Brace, Coilovers CP-e: RMM JBR: Rear Sway Bar (with Moog End Links) TWM: Full Replacement Shifter Cobb: AP AutoTech: HPFP Internals Ebay: Test Pipe |
| Occasional Pulsy feel with DSC/TC MIL lights | meicalnissyen | MazdaSpeed 6 - Engine, Transmission & Driveline | 2 | 03-21-2017 12:57 PM |
| Occasional knock | slowspd | MazdaSpeed 3/6 - ECU Computer Tuning | 6 | 08-03-2012 09:37 AM |
| Occasional Loss of RPM and Stall | mirage | 2010 MS3 - Troubleshoot/Diagnostics | 2 | 07-19-2012 10:39 AM |
| occasional KR | Axel907 | MazdaSpeed 3/6 - ECU Computer Tuning | 42 | 07-15-2012 06:36 PM |
| occasional CEL p2187 | jax ms3gt | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 30 | 02-17-2011 09:39 AM |
