  • 1 Post By Lex
 Old 05-23-2013, 01:14 PM   #1
bigmike's Avatar
Posts: 278   (View Stats)
bigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond repute
Default methanol injection MAF failsafe
So I'm looking into methanol injection and I like the idea of snow performance's MAF based injection system. I'm wanting to tune for it so it's almost necessary for me to get a fail safe. Now whether I go with the aem or snow performance one, I'm not sure it'll even work... help me understand this here: if my methanol injection will be based off of air flow, if my meth flow stops and my failsafe cuts my boost (Wastegate or guardian angle, etc), will that even help at all? Won't my car still run lean? The maf won't be unaffected so the same amount of meth well still be called to be injected but none will come out. Or is it ok to run a little lean as long as not under boost? Also, is there really a big difference for cutting boost at wastegate vs bpv?
2/1 91 octane gasoline/E85, Stratified tuned, ~340 hp/360 ft·lb
AEM Water/methanol injection kit 550 ml/min nozzle ~5 psi/10 psi triggers 1/1 methanol/water Filter Autotech HPFP internals BrakeBest Brake pads Front Clarion XC1410 car amplifier COBB Tuning Downpipe Catback exhaust Front mount intercooler v2.0 XLE bypass valve Hybrid mode Short ram intake Turbo inlet hose Airbox Sport springs Short throw shifter Shift knob Shifter weight AccessPORT V3 Corksport Mid chassis brace Oil catch can Rear sway bar Radiator shrouds LED light kit cp-e SAFEseal injector seals Excalibur Wheel Accessories Black acorn bulge lug nuts 3/4" Echlin Ignition Parts Tire pressure monitoring system Left, right tire Firehawk Wide Oval Indy 500 tires 225/40R18 XL Ground Control Frim strut bump stops Front Interstate Mega-Tron battery James Barone Racing Rear motor mount 88 durometer Transmission side motor mount 80 durometer Passenger side motor mount 80 durometer EGR block off kit Thermal insulating intake gasket kit Thermal insulating throttle body gasket Coolant bypass kit Solid shifter bushings Bypass valve hose Kicker 40CSS684 component speaker system Front KS68 speakers Rear 11PT10CA powered subwoofer enclosure Koni Sport yellow shock absorbers Front 540 degrees LLumar ATR 35 film Mazda 2004-2008 RX-8 rims 18" x 8" FL22 engine coolant Monroe Sensa-Trac shock absorbers Rear Motorcraft XT-M5-QS transmission fluid NGK Iridium IX 6510 LTR7IX-11 spark plugs ~0.28" gap Shell Rotella T6 5W-40 motor oil SSP Primary EGR delete kit Stratified Tuning Guardian Angel ~21.5 psi trigger Visual Garage Shark fin antenna
bigmike is offline   Reply With Quote
 Old 05-23-2013, 01:17 PM   #2
With a D07 nozzle and below and 50/50 you don't need to pull any fueling from your tune in the first place. So fueling is not the problem, however timing advance is. With WMI you will be able to run a lot more timing so if it shuts off you will get knock.
To reduce knock if it happens during a run, reducing boost is effective. You can reduce it by cutting the WG signal, or using GA and opening the BPV and it depends from setup to setup which will get you lower boost.
BLURSPORTS likes this.
bigmike (05-23-2013), Roddiy (05-23-2013)
 Old 05-23-2013, 01:19 PM   #3
Roddiy's Avatar
Posts: 5,388   (View Stats)
Groans: 279
Shit, you can run that much meth without altering fueling tables? I'm guessing it'll at least make your AFRs ~.2 richer, or is it really 0 change needed?
2010 LSM Speed3
#BakeryTuned
 Old 05-23-2013, 01:55 PM   #4
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
Our cars have WOT fuel trims that should correct for the slightly rich mixture.
Roddiy (05-23-2013)
 Old 05-23-2013, 01:28 PM   #5
bigmike's Avatar
Thanks!! That was exactly what I was looking for. It's funny cause I'm actually coming to you for a tune when I get this and a couple other things down. While I'm at it, could you explain how the GA solves the rich VTA problem? I understand it stops leaking, but isn't 'leaking' what you want when it's commanded to vent? Cause isn't that how the air is released? And the air is still 'lost'. So how does the ga do it's magic and stop the rich fuel mixture at shifts?
The Following User Says Thank You to bigmike For This Useful Post:
Lex (05-23-2013)
 Old 05-23-2013, 01:47 PM   #6
The GA controls how the BPV is opened and when so that it allows the air to vent but less than it would without it. The idea here is that it's not whether or not air vents, it's how much air vents and the GA addresses that improving driveability while VTA.
 Old 05-23-2013, 02:13 PM   #7
bigmike's Avatar
So does that mean this feature could improve a standard recirculating BPV as well?
 Old 05-23-2013, 02:19 PM   #8
It will make it react faster so in a sense yes.
 Old 05-24-2013, 12:07 PM   #9
Meth kits do not meter injection in a fine way - they are mostly either on or off. You can save your money and get a simple pressure switch (stage 1) and set it to 8-10psi instead of a progressive controller unless you run very large nozzles. With a D07 nozzle you won't have an issue.
The only system that meters injection is Aquamist that I know of.
I like pressure based simply because you don't splice into your MAF/OEM wiring. Failure of that sensor or wiring will cause a lot of headaches.
 Old 05-24-2013, 04:14 PM   #10
bigmike's Avatar
Great information! Expect to see me soon
 Old 07-25-2015, 09:13 AM   #11
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Groaned at 7 Times in 4 Posts
Hey I know this is an old thread, but I can't seem to find what I'm looking for so I'll just ask the pro. I just bought a stage 1 snow performance kit from Stratified and am waiting for it to arrive. Although its a fixed spray system, I may decide to tune for it using a 50/50 mix. Is there a way to incorporate a fail safe system into a stage 1 kit?
I was thinking of using the guardian angel to open the bpv if the system fails, but I don't know what would trigger it, any help would be sweet.
 Old 07-25-2015, 11:00 AM   #12
Turbo_Steve's Avatar
Posts: 944   (View Stats)
Water Methanol, Low Flow Safety Switch
Guardian angel
Soon to come.
WHO KNOWS? A.D.D. FTW!
Methanol Direct Injection phate MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 290 10-01-2014 09:34 PM
Pre-turbo methanol injection KoukiS14 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 26 10-19-2009 04:20 PM
Page generated in 0.34745 seconds with 25 queries
