| MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection Have a CDFP fuel pump question? Do you want to add Nitrous or Water Injection to your Mazdaspeed 3/6 ? Please come on in! |
![]() Join Date: Feb 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
(Thread Starter) | Not Ranked : 0 score I'm working on a pre-turbo methanol injection setup for my little stock turbo that I should have done within the next couple of months. The general consensus about spraying pre-turbo is that it increases the efficiency of the turbo so that's it's good for additional boost and further reduced BATs. Most of the controversy seems to revolve around compressor wheel erosion, but stock turbos are so inexpensive, I'm not at all worried about the potential for having to replace one eventually. I've already got a spare ready to go. Also, if done properly, with the nozzle on axis with the shaft, and directly in front of the wheel, erosion is negligible to nearly non-existent. I'll be swapping my manifold-mounted D05 nozzle for a D03 and using an AquaMist .3mm nozzle, which is equivalent to an D02 nozzle, before the turbo. Total spray volume should be the same, just injection location will be different. If it works well enough, I may even ditch the stock intercooler entirely. I'm thinking that I may be able to daily drive with 22 to 24 psi on the stock turbo with this setup. SST turbo guys should be able to push even higher. The nozzle holder looks like this: ![]() Here's my favorite article on pre-turbo injection. Here's the place making my nozzle holder for me. Here are the dimensions of the stock turbo inlet. What do you guys think? |
| The Following 5 Users Say Thank You to KoukiS14 For This Useful Post: | aaronc7 (10-09-2009), bioevolve (10-09-2009), djuosnteisn (10-09-2009), gsrtype1 (10-09-2009), wakeboarddude (10-09-2009) |
![]() Join Date: Mar 2008 Location: Navarre, FL
Rep Power: 4956 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,585
Groans: 370
| Not Ranked : 0 score interested to see some pics and results. spraying pre turbo has always looked interesting to me, but scared to try it b/c i wasnt sure how fast it would ruin the turbo. |
| Alittle Faster ![]() ![]() Join Date: May 2008 Location: Cape Coral, FL
Rep Power: 6078 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,006
| Not Ranked : 0 score If no IC: About 17psi on the K04 turbo pumps out about 350* air temps. Meth/Water is good for about upto 100* temp drop only when it's spraying. WOT you will have 350* air going into the engine lol. With IC: I have the same fear of the turbo damage, but the idea is sound. AT WOT turbo air temps should be around 350* around 17psi. Spraying into the turbo should atleast be knocked down to about 250*. Then run thru the IC, drop of another 100*-150* (depends on type of IC). Second Meth/Water sprays another whatever to below ambient temps. But you will find out what the theory versus reality will truely be. I'm hoping the air temp out of the turbo will be more than 100* drop, 200*+ drop would be awsome and I would be following your foot steps lol. Last edited by bioevolve; 10-09-2009 at 09:25 AM. |
![]() Join Date: Mar 2008 Location: In a house
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 54
| Not Ranked : 0 score so your saying your not even gona have a ic?
__________________ 7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance |
![]() Join Date: Mar 2008 Location: south texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,310
Groans: 102
| Not Ranked : 0 score I heard you get a little additional boost spraying pre-turbo like when its colder out.
__________________ |
Groans: 370
| Not Ranked : 0 score do you think it would be better to have the nozzle a bit further away from the turbo? more time to atomize and mix with the air? or do you think that is fine? |
| Not Ranked : 0 score hmm ive always wondered about this but u have to remember theres a trade off here. when using a 50/50 mix, the closer you are to the valves the more of the octane boost your gona get but u will also suffer come cooling efficiency because the air doesent have time to cool down. if u spray where your gona spray i think u will have great cooling but octane might suffer a little. if u do ditch the IC r u gona go for a pipe straight from the turbo outlet to the TB?
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner Last edited by superskaterxes; 10-09-2009 at 09:15 AM. Reason: MSF Database - Automerged Doublepost | |
| Not Ranked : 0 score My bad, WOT is 350* lol. Gotta change that. I guess Meth won't be sprayed pre-turbo, 100% Meth has a flash point of 54*. 10% Meth and 90% water has a 130* flash point. So it would have to either 100% water or a seperate tank of water for pre-turbo.
I did dyno pulls (WOT) with a temp sensors in the hot side and cold side of the L/A IC to see how much it dropped the temps by. Hot side was 354* from turbo to the IC At 17psi. Cold side was 160* from IC to TB at 17psi. Shop AMB was 93* Next time I go, I will get idle and cruise temps of both sides. ![]() HEY superskaterxes are you using the PTP IM gasket?!?!?!?! Hence your 15* above ambient?!?!?!
Here's mines: Last edited by bioevolve; 10-09-2009 at 11:11 AM. Reason: MSF Database - Automerged Doublepost | ||
Groans: 370
| Not Ranked : 0 score i would still run a nozzle at the throttle body area. like a 3gph by TB, and 1gph pre turbo. you can buy a simple Y splitter type thing, the pumps are high enough pressure it should be fine |
| Not Ranked : 0 score Looks rad adam, haha radam. Lemme know how well it works. Also where/how do you plan to route the tubing into the TIP?
| Not Ranked : 0 score A double ended nipple, one outside and one inside to attach to the sprayer nozzle maybe? |
| Not Ranked : 0 score Would work i guess. It would be nice to have zero "free parts" that could come loose and lodge in the compressor. Like maybe running a single tube out through a compression fitting (to serve as an air lock). That way you don't have to tie wrap or hose clamp (free parts) the tube onto the inside nipple.
(Thread Starter) | Not Ranked : 0 score Maybe. A lot of people spraying pre-turbo have ditched their intercooler because it didn't contribute to charge air temperature reduction anymore. If that's true, pre-turbo spray must be awesome at dropping the temps down.
Yeah, if I ditch the intercooler, I'll probably do a 3" piece of stainless from turbo to TB.
Please do take a log of post turbo cruise BATs. That may help me decide whether I'll keep the intercooler or not. I may simply pierce the 90* silicone coupler on my custom TIP, and silicone it up. The AquaMist tubing is just over 1/8", so it's not a huge hole. It's either that or pierce the stainless tubing and silicone it up. Something simple and effective. I've thought about that too, but I want to keep flow obstructions to a minimum. | |||||
| Not Ranked : 0 score Hmmm, if indeed you do ditch the intercooler all together, it would be a prime oppertunity to try tuning for blow thru maf on that 3" cold pipe.
Either way, I'm still waiting on KSTech to get those 3" stainless MAF flanges back in stock so that I can build my 3" stainless CAI as part of this setup. You didn't happen to buy an extra one, did you? | |
| Not Ranked : 0 score Hahaha, i did, but i ruined in a fit of noob welding frustration. I know there was an aluminum one for sale around here at one point. Are you planning on 3.25" intake? Cause if 3" would suit, you could rig something up with the atp piece
| NEC ![]() Join Date: Mar 2008
Rep Power: 472 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 129
| Not Ranked : 0 score How do you attach the jet holder to the turbo, and run the line to the jet? I <3 my aquamist... its way good.
__________________ 2006 Lotus Elise: Toy car 1999 B4000: DD / Parts hauler / SC Project 2007 Mazdaspeed 3: *sold* 2005 Corolla XRS: *sold* |
![]() Join Date: Jul 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28
| Not Ranked : 0 score 22 to 24 psi on stock turbo??? I was running 21 psi for like 6 months...and after I blew my motor I checked the stock turbo and there is a good amount of shaft play. Its just a short matter of time before the turbo was gonna go. Im really thinking its from running that high of boost. Those VW articles on the K04 was sayin anything higher then 18 psi and youll start heating up the turbo to much and starts to deform the shaft. After seeing the shaft play in my turbo that was ran at 21 psi...I beleive it.
| Lurkers
Posts: n/a
| i wish i had shaft play |
| The Following 2 Users Say Thank You to For This Useful Post: | aaronc7 (10-11-2009), djuosnteisn (10-11-2009) |
The outside diameter of the 2-1/8" coupler is 2-1/2", so I'll use a 2-1/2" to 3" 90* coupler attached to a stainless 45* bend to complete my custom TIP. Of course, I'll have a 1-1/8" tube welded to the 3" bend for the BPV recirc. As far as the tubing, it's small, 4mm tubing, so I think I'll just pierce the 90* coupler, run the hose through, and silicone it up. It's simple and secure.
If I do a PG or PTP rebuild, I may get all the components cryo and WPC coated to aid longevity. At that point, I may be better off going to a Garrett turbo though. At this point, I'm just interested in seeing what the absolute power limit of a totally stock turbo is. | ||
__________________ 2006 Lotus Elise: Toy car 1999 B4000: DD / Parts hauler / SC Project 2007 Mazdaspeed 3: *sold* 2005 Corolla XRS: *sold* | |
Groans: 370
| Not Ranked : 0 score if this turns out well, you need to make some setups for the rest of us or make a little how to etc |
| The Following User Says Thank You to aaronc7 For This Useful Post: | djuosnteisn (10-12-2009) |
| Not Ranked : 0 score You guys are aware that instead of running pre and post turbo meth and junking stock turbos, you could just get a turbo thats made to run the boost that you want to run and then throw the whole meth system in the trash.
![]() | | #24 | ![]() |
![]() I'm not convinced that pre-turbo WI done right will scrap a turbo. You don't necessarily have to crank the boost up to 24 psi to see benefit. From what I understand, pre-turbo WI will alter the efficiency of the turbo, thus enabling it to move more air at the same pressure levels. So when you romp on it and start spraying meth, all of a sudden your 20psi feels like 24-psi without meth. How it will actually behave in the real world and how much benefit you'll see from it is anyones guess... but i'd like to see someone give it a shot.
![]() | | #25 | ![]() |
| Not Ranked : 0 score how bout we just dunk the intake filter into a bucket of meth.
| The Following User Says Thank You to AFcadet For This Useful Post: | aaronc7 (10-19-2009) |
![]() | | #26 | ![]() |
![]() Join Date: Aug 2008 Location: Red Deer, AB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,362
| Not Ranked : 0 score looks interesting and promising, but i think header wrap and a turbo blanket would be an excellent CYA decision if you ever had a hot side boost leak with 50/50 mix. flammable liquids tend to atomize into the perfect AF/R when they leak under pressure
![]() | | #27 | ![]() |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f303/pre-turbo-methanol-injection-39602/ | ||||
| ?????? ???????? | This thread | Refback | 10-02-2012 02:45 AM | |
| Windshield Washer Fluid List That Contains Methanol | Haltech | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 15 | 06-20-2017 07:20 AM |
| Methanol Mixing Calculator (EXCEL) | Haltech | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 17 | 08-02-2010 10:55 PM |
| -+- Progress of Methanol Injection in cleaning my motor -+- | socks | MazdaSpeed 3 - Engine, Transmission & Driveline | 26 | 01-06-2009 12:27 PM |
| No Surprise: Porsche 911 Turbo, GT2 and GT3 getting direct-injection | Haltech | Automotive News | 0 | 07-30-2008 12:30 PM |
