 Old 05-07-2010, 01:28 AM   #1
diepanthony's Avatar
Posts: 63   (View Stats)
diepanthony is a jewel in the roughdiepanthony is a jewel in the roughdiepanthony is a jewel in the roughdiepanthony is a jewel in the rough
Default 18x9.5 +48 fit
im looking at buying some 18x9.5 +48.. would these fit without rubbing the sturts. i know i will have to roll the fenders.. i use to have 18x8.5 +48 on cobb springs and i had no problems what so ever. my fenders are not even rolled yet.. so im wondering adding another 1 wouldent hurt..
diepanthony is offline   Reply With Quote
 Old 05-07-2010, 01:51 AM   #2
tigermack's Avatar
Posts: 650   (View Stats)
tigermack is the leader of the worldtigermack is the leader of the worldtigermack is the leader of the worldtigermack is the leader of the worldtigermack is the leader of the worldtigermack is the leader of the worldtigermack is the leader of the worldtigermack is the leader of the worldtigermack is the leader of the worldtigermack is the leader of the worldtigermack is the leader of the world
Groans: 78
What car do you have??
Fuck HPDE heroes. HPDE ain't road racing.
tigermack is offline   Reply With Quote
 Old 05-07-2010, 01:56 AM   #3
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
To fit the fronts, I'm assuming you will need AT LEAST 15mm of a spacer.
 Old 05-07-2010, 11:12 AM   #4
ms3 with cobb springs
 Old 05-07-2010, 03:35 PM   #5
kotez's Avatar
Posts: 56   (View Stats)
kotez is a jewel in the roughkotez is a jewel in the roughkotez is a jewel in the rough
Will not clear the front struts. I run 8.5'' wide at +46 and have a finger tips width clearance.
kotez is offline   Reply With Quote
 Old 05-07-2010, 04:24 PM   #6
VTEC_EATER's Avatar
Posts: 66   (View Stats)
VTEC_EATER has much to be proud ofVTEC_EATER has much to be proud ofVTEC_EATER has much to be proud ofVTEC_EATER has much to be proud ofVTEC_EATER has much to be proud ofVTEC_EATER has much to be proud ofVTEC_EATER has much to be proud ofVTEC_EATER has much to be proud of
Groaned at 8 Times in 4 Posts
On a Speed3, I don't think there will be enough room in the back either. Do you have over a half inch of clearance all around your wheel/tire in the back?
VTEC_EATER is offline   Reply With Quote
 Old 05-07-2010, 05:05 PM   #7
tigermack's Avatar
Groans: 78
There's room in the back. I am running 17x9.5 +42 with at least an inch from the shock.
 Old 05-08-2010, 12:01 AM   #8
madvillain's Avatar
Groans: 78
Yeah you will definitely be fine in the back.
Tiger- How much room do you have in the front? with the 9.5" +42's.
I'm eying a pair of 9.5" +50 and I'm trying to see how much spacer I'll need..
 Old 05-08-2010, 02:06 AM   #9
tigermack's Avatar
Groans: 78
With my setup, I have a 8mm spacers up front right now. It's about 2mm clearance from the strut, I am gonna space it out more since my pulled front fenders make my 9.5" look like I am riding on 8". -_-
The Following User Says Thank You to tigermack For This Useful Post:
KeysMS3 (05-23-2010)
 Old 05-08-2010, 06:57 AM   #10
ZoomByU's Avatar
Posts: 1,236   (View Stats)
ZoomByU is the leader of the worldZoomByU is the leader of the worldZoomByU is the leader of the worldZoomByU is the leader of the worldZoomByU is the leader of the worldZoomByU is the leader of the worldZoomByU is the leader of the worldZoomByU is the leader of the worldZoomByU is the leader of the worldZoomByU is the leader of the worldZoomByU is the leader of the world
Groaned at 9 Times in 9 Posts
i installed 18x9.5 37 offset and rubbed on the front struts with BCs. so i needed a 3mm spacer. all good now cept i rub in the rear. will be fixed with pics by sunday.
ZoomByU is offline   Reply With Quote
 Old 05-10-2010, 11:18 PM   #11
Shiraz's Avatar
Posts: 24   (View Stats)
Shiraz is an unknown quantity at this point
Why not just order a proper size so you wont need a spacer? Or do you love these wheels you found?
Shiraz is offline   Reply With Quote
 Old 05-23-2010, 06:51 AM   #12
speedyhans's Avatar
Posts: 335   (View Stats)
speedyhans has much to be proud ofspeedyhans has much to be proud ofspeedyhans has much to be proud ofspeedyhans has much to be proud ofspeedyhans has much to be proud ofspeedyhans has much to be proud ofspeedyhans has much to be proud ofspeedyhans has much to be proud ofspeedyhans has much to be proud ofspeedyhans has much to be proud of
Groaned at 56 Times in 56 Posts
do it let us know
speedyhans is offline   Reply With Quote
 Old 07-05-2010, 01:20 AM   #13
RepeaterDroid's Avatar
Posts: 25   (View Stats)
RepeaterDroid will become famous soon enough
you need spacers....and serious rolls
RepeaterDroid is offline   Reply With Quote
ordered 18x9 dpts martyxattack MazdaSpeed 3/6 - Wheels & Tires 61 11-05-2009 10:22 AM
To those with 17x9, 18x9 45 offset bnoon MazdaSpeed 3/6 - Wheels & Tires 39 02-23-2009 01:24 PM
18x9.5 too wide?? Buildabong MazdaSpeed 3/6 - Wheels & Tires 28 08-26-2008 08:52 AM
18x9 fitment chris08.5 MazdaSpeed 3/6 - Wheels & Tires 10 07-06-2008 05:24 PM
Page generated in 0.30707 seconds with 28 queries
