 Old 07-18-2013, 10:18 PM   #1
nayilsi's Avatar
Posts: 52   (View Stats)
nayilsi is a name known to allnayilsi is a name known to allnayilsi is a name known to allnayilsi is a name known to allnayilsi is a name known to allnayilsi is a name known to all
Default 2 New Tires Installed. Now vibration when they were rotated to the front
The dealership installed 2 new tires and put them on the rear. The fronts already had 5k miles on them.
After 3000 miles I went for an oil change and the dealership brought the 2 new ones to the front. The steering wheel vibrates on and off at speeds greater then 70 mph. Sometimes there's no vibration and then all of a sudden the wheel vibrate like crazy.
Is it a tread related issue? No alignment was done when the new tires were installed.
Any suggestions?
nayilsi is offline   Reply With Quote
 Old 07-18-2013, 10:40 PM   #2
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Any suggestions?
Hopefully it is something as simple as loose lugnuts or tires that need balancing.
I did have a shitty tire once that had a bubble firm on the sidewall and caused mad vibrations.
Pickles Tune in progress
nayilsi (07-18-2013)
 Old 07-18-2013, 10:41 PM   #3
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
No alignment is required when you install new tires, but ideally when you install them or even rotate them you should re balance them.
It's weird that the vibration is not permanent. Normally when the tires are not balanced correctly or there's something stuck in one of the tires (a nail, a big stone, and so on) they vibrates continuously.
Do you apply the brakes when you get that vibration?
Go to a tire shop and have them check your tires, balance them, make sure the nuts were torqued properly (at the right torque and in the right order) and so on. If it's not the tires/wheels then you will have to start looking at the brake disks, maybe there's some debris stuck in one of them or they happened to wrap when you visited the dealer.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 07-18-2013, 10:48 PM   #4
nayilsi's Avatar
Thanks for the help guys.
No brakes applied when I get the vibration. Just randomly it comes and goes at highway speeds.
 Old 07-18-2013, 10:51 PM   #5
Playaj's Avatar
Posts: 1,232   (View Stats)
Playaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the world
Groaned at 9 Times in 7 Posts
Bad roads
2009 Black Speed3 - AP, JBR Powerpath stage II Sri, JBR 70 duro tmm, JBR Ssb, JBR Short shift kit, JBR RSB, JBR 5mm spacers, ETS Tmic, TWM big type-R shift knob, RX-8 wheels, CPE Stage 2 rmm, H&R Springs, Bilstein B8's
to be installed :
3 Port EBCS
HTP 3" intake/ MAF/ TIH
Autotech internals
Corksport Pmm
Test pipe
SBC Rear Camber Arms
Playaj is offline   Reply With Quote
Drag DR-34s w/ 235-40-18 Neo Gen Tires Installed GreyGhost 2010 MS3 - Wheels & Tires 5 05-14-2013 07:38 PM
Vibration/shaking at highways speeds, after wheels tires balanced twice....... PureDrive MazdaSpeed 3/6 - Wheels & Tires 19 09-02-2011 05:19 PM
rotated my tires, now they're rubbing? BobbleHead MazdaSpeed 3/6 - Wheels & Tires 7 07-04-2011 12:14 AM
MS6.. back tires 30% tread, front tires 90% tread.. will this cause an issue with driveline damage? squale MazdaSpeed 3/6 - Wheels & Tires 7 04-27-2010 09:54 AM
Rotated tires, now car pulls HARD left on acceleration...WTF? bast525 MazdaSpeed 3/6 - Wheels & Tires 8 04-14-2010 11:49 AM
Page generated in 0.26721 seconds with 23 queries
