 Old 08-11-2017, 02:30 PM   #1
evanreynolds1116's Avatar
Posts: 54   (View Stats)
evanreynolds1116 is just really niceevanreynolds1116 is just really niceevanreynolds1116 is just really niceevanreynolds1116 is just really nice
Default 235/40 Help
My 07 stock tires are well past the end of their life. Looking at getting 235/40's and putting 18x8 Konig Runlite's on them (+45 offset). I've been looking through the forums but I can't get a good answer on if I will rub or not with those tires. I've never bought tires that weren't stock size so this is all new to me. My suspension is stock right now but I am looking at getting some Eibach springs and wondering if that'll still be fine with those tires.
Currently looking at Pirelli P Zero a/s Plus... let me know if you have any other suggestions around that price range ($152.10/ea)
Also anyone have any previous experience with those Konig wheels?
2007 MazdaSpeed 3
Cobb AP v3 | Corksport HPFP | Cobb TIP | Corksport CBE | Corksport DP w/ High Flow Cat | cp-e Stage 2 RMM | MAZDASPEED CAI |
evanreynolds1116 is offline   Reply With Quote
 Old 08-11-2017, 02:55 PM   #2
Shwaykid's Avatar
Posts: 646   (View Stats)
I run 235/45/17 +45 which are the same overall diameter that you're looking to get. I needed to roll the rear fenders after I got lowering springs.
Pretty sure you'll be fine if you stick to stock suspension. Might rub a bit if you load the back end up with stuff/passengers.
2008 Mazdaspeed3 GT
Jet Black Wax (06/24/2017)
Shwaykid is offline   Reply With Quote
 Old 08-12-2017, 08:34 PM   #3
cyber-ms3's Avatar
Posts: 197   (View Stats)
cyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond repute
Groaned at 6 Times in 2 Posts
not all 235 40 tires are the same width. I had 235/40/18 Super sports on Evo X wheels which were pretty wide and they rubbed slightly even with a roll and slight pull on stock springs. Now I'm on HTR ZIII's and there is less rubbing. Section width and tread width need to be compared also.
cyber-ms3 is offline   Reply With Quote
Page generated in 0.24806 seconds with 21 queries
