  • 1 Post By 5doorsoffury
 Old 04-01-2019, 01:05 PM   #1
arvint123's Avatar
Posts: 10   (View Stats)
arvint123 has a little shameless behaviour in the past
Default Sparco Assetto Gara fitment
Hey guys, Going to be picking up a set of Sparco Assetto Gara's (18x8, 45mm offset), just want to make sure, if i stick to 215 45 18 there wouldnt be any rub correct? (Using 100% stock suspension). Never changed wheels before but just want to make sure. Otherwise if there is a better different size tire i should run that would appreciated too! Just want to make sure there's no rub!
EDIT: on a gen 1, stock suspension!
Thanks!
arvint123 is offline   Reply With Quote
 Old 04-01-2019, 03:44 PM   #2
Bertospeed3's Avatar
Posts: 149   (View Stats)
Bertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant future
Theres a thread here all about fitment for wheels and tires. I dont have the link handy tho. I don't know what car this is all happening on but I would assume and say you will not rub. That wheel width and offset doesnt stray that far from stock.
For an official answer, search for the thread.
2010 MS3 - Tuned By Nishan
Autotech Fuel Pump Internals
OBX R Custom Exhaust
Cobb SF Intake & TIH w. Blitz Filter
CP-e TMIC
Corksport Dual VTA BPV
JBR 88 Duro RMM
Bertospeed3 is offline   Reply With Quote
 Old 04-01-2019, 07:02 PM   #3
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
215 on a 8 inch rim with a 45 aspect ratio? Any reason why the odd combo? Hope that question isnt much of a strechhhh.
Db09ms3 likes this.
MECP
2012 BM
Rfinkle tune in progress
 Old 04-01-2019, 08:28 PM   #4
arvint123's Avatar
Haha i get what you mean, pretty knew to tires and wheels did some searching and it sounds like 225/45/18 would be a safer choice haha. Just want to make sure there's no rub since i think the stock is 18x7.5 and this is a 18x8 and going from a 215 oem tire size to 225.
 Old 04-01-2019, 10:57 PM   #5
arvint123's Avatar
Well went on to order them and they are out of stock and graphite grey is discontinued too so switching wheels, I did some reading and checking and want to triple check,
https://www.americastire.com/buy-whe...unlite/p/13735
Would these fit on just fine? (using 225/45/18)...The only thing that bothers me is:
Hub Bore Size :73
I know on the sticky it said ours is 67.1mm bore...would it still be ok? Assuming i can just buy hub centric rings if im really paranoid right? (Sorry, really new to wheels and fitment) been reading the sticky a bit and got a good amount out of it.
 Old 04-02-2019, 05:44 PM   #6
Groans: 74
Listen man put down the credit card and spend a long time reading this.
The Ultimate "Will They Fit" Thread - Everything you need to know about wheels, spacers and tires for your MS
If you want to go full faggot mode look here.
OFFICIAL AGGRESSIVE OFFSET THREAD
MECP
2012 BM
New 18x8 Sparco Assetto Gara rims swampthigger Wheels & Tires - METRO GREY 29 11-13-2017 09:03 AM
Awesome or retarded: Sparco Assetto ORANGE eliminator Wheels & Tires - COSMIC BLUE 45 03-09-2013 01:01 PM
Sparco Assetto Gara Gold 18x8 +45 BlckMs3 Wheels & Tires - BLACK 21 03-01-2013 06:53 PM
Green sparco assetto...will they fit? DRITISDASHT Wheels & Tires - BLACK 10 02-16-2013 12:02 PM
Paris 2008: Fiat 500 Abarth Assetto Corse Haltech Automotive News 0 10-05-2008 02:40 PM
Page generated in 0.26924 seconds with 22 queries
