 Old 12-30-2010, 09:12 PM   #1
NATOR DIRTBAG
redneckrecon's Avatar
Posts: 2,842   (View Stats)
redneckrecon is the leader of the worldredneckrecon is the leader of the worldredneckrecon is the leader of the worldredneckrecon is the leader of the worldredneckrecon is the leader of the worldredneckrecon is the leader of the worldredneckrecon is the leader of the worldredneckrecon is the leader of the worldredneckrecon is the leader of the worldredneckrecon is the leader of the worldredneckrecon is the leader of the world
Default TIRE PRESSURE SENSOR...
A FEW WEEKS AGO I HAD A BLOWOUT AND CRACKED MY TPS. ALL OF THE SUDDEN IM LOSING A LOT OF AIR PRESSURE FROM THAT WHEEL AND TIRE. JUST HAD THE TIRE CHECKED AND THERES NO LEAKS.. I WAS WONDERING IF THAT CRACK WOULD CAUSE ME TO LOSE THAT MUCH AIR.. ITS DROPPING AT A QUICK RATE..
SAN DIEGO CHAPTER
COBB SRI / COBB BPV / COBB AP / SLAMMED 2" / 6K HID DDM / CP-E RMM / DASHHAWK / XXR 518 / RALCO SS
SPONSORED BY: STREET UNIT
redneckrecon is offline   Reply With Quote
 Old 12-30-2010, 09:24 PM   #2
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
CAPS MUTHER FUCKING LOCK
FUCK YEAH
stefan (01-03-2011)
 Old 12-30-2010, 09:27 PM   #3
NATOR DIRTBAG
THIS COMPUTER IS A POS AND THE CAPS LOCK IS STUCK ON!
SAN DIEGO CHAPTER
 Old 12-30-2010, 09:40 PM   #4
phillyb's Avatar
Groans: 1,940
I JUST HOLD THE SHIFT BUTTON DOWN!
 Old 12-30-2010, 09:42 PM   #5
NATOR DIRTBAG
DO YOU KNOW WHAT'S UP WITH MY TIRE BRO?
SAN DIEGO CHAPTER
 Old 12-30-2010, 09:49 PM   #6
phillyb's Avatar
Groans: 1,940
The Following 3 Users Say Thank You to phillyb For This Useful Post:
Chupacabras (12-30-2010), mizboo102 (01-21-2011), sharky (12-30-2010)
 Old 12-30-2010, 09:59 PM   #7
Chupacabras's Avatar
Posts: 175   (View Stats)
Chupacabras is the leader of the worldChupacabras is the leader of the worldChupacabras is the leader of the worldChupacabras is the leader of the worldChupacabras is the leader of the worldChupacabras is the leader of the worldChupacabras is the leader of the worldChupacabras is the leader of the worldChupacabras is the leader of the worldChupacabras is the leader of the worldChupacabras is the leader of the world
I larfed, you funny fuckin' ginger.
Chupacabras is offline   Reply With Quote
The Following User Says Thank You to Chupacabras For This Useful Post:
phillyb (12-30-2010)
 Old 01-02-2011, 05:40 PM   #8
leo766's Avatar
Posts: 300   (View Stats)
leo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond repute
Groaned at 93 Times in 33 Posts
I HAVE A PATHOLGICAL FEAR OR REDDISH BEARDS!!! MOMMY!!
Fresh to High Rockies Colorado from VA DC area MS6 07 TiGray!
Cpe: FMIC, CAI, TIP, HPFP, bone engine mount
Cobb AP, Test pipe, turbosmart BPV, whitlenine swaybar
Turbine Tech: Extra front motor mount, both diff mounts +bushings
EGR Delete, mini 0803 Dash cam, Prosport Boost guage. Dash Hawk,
AWR: Trans mount with 88 duro bushings, End links front/rear(removed due to them being total garbage and got some moog stock ones for all around on rockauto.
17x7 Kosei K1 TS 15lb rims, goodyear 225/50r17 all season performance tires and RPM springs
Waiting to install: SPC Ball Joints, SS clutch line, lower engine mount bracket local car shop damaged during clutch install and thermal TB gasket and coolant inline plumbing line that can be turned on and off on demand
leo766 is offline   Reply With Quote
 Old 01-02-2011, 05:44 PM   #9
ScarMS3's Avatar
Posts: 2,088   (View Stats)
Groans: 97
I would imagine you would lose pressure pretty fast If you have a cracked tpms, you checked the tire for leaks how? Also did you check the wheel for a crack
 Old 01-02-2011, 09:06 PM   #10
NATOR DIRTBAG
Mazda soaped the tire and there was nothing bubbling... the rim doesnt appear to be cracked but i also havent inspected it that closely.. I will do that manana and let you know! thanks
SAN DIEGO CHAPTER
 Old 01-21-2011, 08:57 AM   #11
Wide tire man
dbrier's Avatar
Posts: 957   (View Stats)
dbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the world
I had an issue where my TPMS sensor collar wasn't tight enough. It would hold air just fine sitting in the garage, but lose air quickly when driving. Try tightening the collar a bit and see if it helps.
2012 Crystal White Pearl Mazdaspeed3
Cobb AccessPort, Autotech HPFP internals, Corksport Stage II intake with TIP and airbox, Corksport rear camber arms, Corksport catted test pipe, Denso ITV22 plugs, JBR rear sway bar and HD mounts, CP-e stage II rear motor mount, Mazda5 rear brake upgrade, Bilstein struts, Eibach pro springs.
Too many wheels & tires to list.
dbrier is offline   Reply With Quote
The Following User Says Thank You to dbrier For This Useful Post:
redneckrecon (01-21-2011)
 Old 01-02-2011, 09:16 PM   #12
overdrift's Avatar
Posts: 93   (View Stats)
overdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant future
Groaned at 6 Times in 4 Posts
STOCK OUT AND GO TO DEALER!
overdrift is offline   Reply With Quote
 Old 01-21-2011, 07:23 PM   #13
NATOR DIRTBAG
JUST BOUGHT NEW RIMS AND TIRES.... FUCK IT!!!!
SAN DIEGO CHAPTER
weird tire wear pattern. stock tires. stock rim. stock suspention. stock tire pressure what's up with this? labikesrcool MazdaSpeed 3/6 - Wheels & Tires 21 11-30-2015 03:32 PM
Fuel Rail High Pressure Sensor Upgrade JumpingJackson MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 234 10-25-2014 01:54 AM
How to scale the HPFP pressure sensor djuosnteisn MazdaSpeed 3/6 - ECU Computer Tuning 521 04-07-2010 08:39 AM
P0107 - Barometric pressure sensor low input vbt101 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 09-14-2009 01:31 PM
GMC Sonoma Stalls, Sugar in the Gas Tank, Correct Tire Pressure, Ford Escape Tire Shimmy: Mike Allen's Weekly Online Aut Haltech Automotive News 0 07-25-2008 02:30 PM
Page generated in 0.32066 seconds with 26 queries
