MAZDASPEED Protegé
> MSP - ECU Computer Tuning
 Old 06-24-2010, 08:41 PM   #1
Focus's Avatar
Posts: 6   (View Stats)
Focus is an unknown quantity at this point
Default Fs-ZE Swap
I will edit this post to reflect more of the swap, but here is what I have done today:
So I finally got around to do the final touches on My FS-ZE swap.
Problem 1 was the trigger wheel for the crank sensor. JDM uses only 4 tooth while USDM uses 36 tooth. So I had to press out an original trigger wheel from a crank pulley, and modify it to fit a medieval pulley. Here are the results:
Next up was mating the USDM wiring harness to the JDM ECU that I just picked up. So I went out and got one of those AEM Adapter harnesses, I also found PCM test harnesses from Ford and cut those up also. I wired in the harnesse for the shift improver and for the J&S Safeguard and this is what came out of it all:
Focus is offline   Reply With Quote
 Old 09-11-2014, 08:31 AM   #2
Mazdaspeed8057's Avatar
Posts: 3   (View Stats)
Mazdaspeed8057 is an unknown quantity at this point
Do you still have the fsze ecu pinouts
I have a JDM 2001 Mazdaspeed Familia
Also have a 2003 Mazda Familia SP20
Last edited by Mazdaspeed8057; 09-11-2014 at 08:31 AM. Reason: MSF Database - Automerged Doublepost
Mazdaspeed8057 is offline   Reply With Quote
 Old 09-11-2014, 08:37 AM   #3
Having problems with the wire harness on the Mazdaspeed would you be able to send me the ecu pinouts for the fsze sp20 , my email address is gti_maniac@hotmail.com please let me know if you can help me or where I could get the ecu pinouts and wiring diagram like what you have posted in the pictures above
 Old 09-11-2014, 08:40 AM   #4
Police - Grammarhead
Vansquish's Avatar
A new record!
Considering the OP hasn't even been on the site since 06-05-2011 08:08 AM, I think it's fair to say that you're probably not going to get the info you're looking for.
Easter Bunny (09-11-2014), Vader (09-11-2014)
 Old 09-11-2014, 08:43 AM   #5
Thanks
CP-E TC3 ECU Swap for gen 2 Torque_steer 2010 MS3 - Turbo Induction 91 02-24-2017 07:35 AM
Motor Swap AFcadet MazdaSpeed 3 - Engine, Transmission & Driveline 8 07-13-2015 04:10 PM
HID swap TXspeed3 MazdaSpeed 3/6 - Appearance 19 06-28-2009 05:04 PM
Page generated in 0.25704 seconds with 22 queries
