MAZDASPEED Protegé
> MSP - ECU Computer Tuning
  • 1 Post By Brian MP5T
 Old 01-11-2013, 08:30 PM   #1
Brian MP5T's Avatar
Posts: 1,101   (View Stats)
Brian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the world
Default Haltech and AEM Coil On Plug
Here is some information in regards to how to configure the Haltech PS1000 ECU and The AEM Twinfire Ignition system..
"Coils On Plug" BABY!
Tabasco69 likes this.
Brian MP5T is offline   Reply With Quote
The Following 2 Users Say Thank You to Brian MP5T For This Useful Post:
breakfstincluded (01-11-2013), Tabasco69 (01-11-2013)
 Old 01-11-2013, 08:45 PM   #2
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
What a wonderful engine bay. So much space.
sleepyspeed6 (01-11-2013)
 Old 01-11-2013, 08:53 PM   #3
Brian MP5T's Avatar
^^Thanks, I use it to run people through the border undetected...
Ok, The Install instructions say "CUT"
You do not cut, The 4 Ignition wires from the haltech are yellow.. They get patched directly to the White Green Yellow Violet wires on the AEM.
Wire 1 to Wire 1
Wire 2 to Wire 2
etc...
I suggest using a heat shrink, Double walled.
The Following User Says Thank You to Brian MP5T For This Useful Post:
 Old 01-11-2013, 09:07 PM   #4
Tabasco69's Avatar
Posts: 554   (View Stats)
Tabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the world
Going with the exact same set-up, thanks for the quick write up.
425whp/395ftlbs - GTX3071R .82a/r- 20psi- 92 octane pump fuel
Tabasco69 is offline   Reply With Quote
The Following User Says Thank You to Tabasco69 For This Useful Post:
Brian MP5T (01-14-2013)
 Old 01-11-2013, 09:15 PM   #5
Brian MP5T's Avatar
Just a point.
Have fun setting the timing, there are no wires so there is no way to hook a Timing Light to the ignition system.
You need to make a short wire from an old lead that can plug into the coil (and simulate a spark plug, and fit all the way down into the well and connect to the plug.
You then get a loop of wire to put the pickup ring on for the timing gun.
 Old 01-11-2013, 09:54 PM   #6
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
you are my hero
 Old 01-11-2013, 10:07 PM   #7
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
I have seen the car in the metal (flesh did not sound right) Well it is a sano engine bay! Loved the electric H2O pump, but as I was told many years went into it! Awesome ride!
Nator is what it does.
 Old 01-11-2013, 10:21 PM   #8
Bob Ross Fanclub
Tomas's Avatar
What's the thinking behind 12v water pump being better than a mechanical / belt driven one?
 Old 01-11-2013, 10:32 PM   #9
amoosenamedhank's Avatar
Posts: 1,368   (View Stats)
Groans: 53
Anything belt driven takes additional power to run.
You saw it cuz I tapped it
You know.... Moose stuff
 Old 01-11-2013, 10:43 PM   #10
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
Less drain + no thermostat. You should check out his thread.
 Old 01-11-2013, 10:49 PM   #11
Bob Ross Fanclub
Tomas's Avatar
So you are spending something like $500+ countless hours of labor for something that will get you 10 hp or so and add about 8 lbs more of weight?
I'd like a more thorough analysis on this if possible.
The Following User Says NO Thank You to Tomas For This Un-useful Post:
Mizzle (01-12-2013)
 Old 01-11-2013, 11:13 PM   #12
Tabasco69's Avatar
Originally Posted by Brian MP5T View Post
Just a point.
Does this also apply to a newer generation Mazda (MZR based) that came from the factory with hall effect cam and crank position sensors and coil on plug? Mechanical timing is set& static, isn't electronic spark timing derived from the input of the camshaft sensor after everything is synced?
Brian all I needed was proof this would work the rest is up to the people I hired to do the work for me...it up to them make it work....I 'm too busy working to pay for all of this- lol.
Parasitic loss, I think he also has a reverse flow cooling system, heck what is $500? for a water pump, Brian easily has several 10's of thousands of dollars invested in his build, pretty sure it is not about the bling or impressing people, it becomes a obsession of sorts I would assume based on experience to build/make something unique.
 Old 01-12-2013, 03:54 AM   #13
Brian MP5T's Avatar
It is about CONTROL
PS, The pump is 3 Lbs, and that weight sits in front of the front tire center line so it is "Good Weight". Not like adding weight to the back...
Mizzle (01-12-2013)
Coil on Plug Inner springs? mrmonk7663 2010 MS3 - Engine, Transmission & Driveline 16 06-18-2012 01:56 PM
Coil over Options? 79BlueSC 2010 MS3 - Suspension & Brakes 17 04-02-2011 06:52 AM
VW unveils plug-in electric Golf headed for U.S., plug-in Jetta to follow Haltech Automotive News 0 05-03-2010 10:10 PM
Page generated in 0.35541 seconds with 26 queries
