MAZDASPEED Protegé
> MSP - ECU Computer Tuning
 Old 10-07-2014, 09:01 AM   #1
Brandont26's Avatar
Posts: 4   (View Stats)
Brandont26 will become famous soon enough
Default Ms protege 2003.5 tuning
Ok so I bought a 2003.5 protege, just bolt ons added to it (front mount intercooler intake and exhaust). I bought the car and at the end of every gear it would sputter and bog out, I figured Tps sensor so I replaced it and that fixed that problem. Also replaced fuel pressure regulator and map sensor. Now basically at the end of every gear past 1st gear the car hesitates. It will get to about 4k smoothly then jump up and down then go to about 6k. I figure It has to be because of the stock tune with the bigger piping but I'm not sure so does anyone think they have an idea of what the problem could be?
Brandont26 is offline   Reply With Quote
 Old 10-29-2014, 03:13 PM   #2
Gang's Avatar
Posts: 1   (View Stats)
Gang is an unknown quantity at this point
I have the same prob i ran a computer to it got codes back for a 02 sensor an fuel regulator. Changed the 02.
Still have the same problem, pretty sure i need to be flashed an need nice tunes but i have no idea where to get Tunes from, in CT or what garage is good around here in my area.
Gang is offline   Reply With Quote
 Old 11-03-2014, 02:18 PM   #3
HFDSpace-Junk's Avatar
Posts: 266   (View Stats)
HFDSpace-Junk is the leader of the worldHFDSpace-Junk is the leader of the worldHFDSpace-Junk is the leader of the worldHFDSpace-Junk is the leader of the worldHFDSpace-Junk is the leader of the worldHFDSpace-Junk is the leader of the worldHFDSpace-Junk is the leader of the worldHFDSpace-Junk is the leader of the worldHFDSpace-Junk is the leader of the worldHFDSpace-Junk is the leader of the worldHFDSpace-Junk is the leader of the world
Sounds like the factory tune "stutter". Take the car to the dealership and see if the ecu has been upgraded to the newest version. If they haven't flashed it yet, then get it done. While it won't cure the issue completely, it'll make it less noticable.
tappa...
2003.5 BLAZING YELLOW Mazdaspeed Protege
FMIC|Potenza S-04 Pole Positions|P5 Transmission W/LSD Delete (Blew 2rd/3rd/4th in MSP trans)
[COLOR="yellow"[/COLOR]
AWR MM Tetralogy (70 Duro)|Havoc bumper plates|New pads + Slotted Rotors|Iridium Plugs
Awaiting install:New pads + Slotted Rotors
2008 Black Mica MS3 Sport
I don't get mad, I fuck shit up.
I also fuck grandmothers
HFDSpace-Junk is offline   Reply With Quote
my 2003.5 mazdaspeed protege wallsworld378 Members Rides Gallery 18 12-09-2013 08:42 AM
2003 Mazdaspeed Protege vacuum hose routing....HELP!!! NYspeedguy MSP - Engine, Transmission & Driveline 29 04-12-2013 08:27 PM
Product Release! Mazdaspeed Protege / Mazda Protege Front Motor Mount CorkSport CorkSport 0 02-22-2013 10:10 AM
Product Release! CorkSport 1999-2003 Mazda/Mazdaspeed Protégé Skid Tray CorkSport CorkSport 0 10-10-2011 10:50 AM
NEED SOME HELP WITH BUYING A 2003 PROTEGE SPEED matt911 Mazdaspeed3/6 General Discussion 3 02-11-2010 01:26 PM
Page generated in 0.23583 seconds with 22 queries
