> MazdaSpeed 3 - How-To's
Like Tree8Likes
 Old 11-30-2008, 10:20 AM   #41
Lymerock's Avatar
Posts: 1,436   (View Stats)
Lymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the world
Originally Posted by CraigHJr View Post
Anything is possible. It is a simple swap once you break that nut loose.
no doubt, my will is strong when the hangover headache is gone. as long as its not something stupid like 100ftlbs I shouldnt have much issue (once I get off the couch)
Originally Posted by Jarods7920 View Post
here ya go man...i picked this little gem up a few weeks ago
Harbor Freight Tools - Quality Tools at the Lowest Prices
Im looking for something with more depth in between the jaws. seems all the ones at HF were low profile style.
I apreciate the link however.
07 CB Speed3
COBB AP S2+, MS CAI (shorty w/ straightener), RPMC inlet, ETS 3.25", Devils Own S2 Alchy Injection, PG Manifold V2, TXS DP (with Cobb highflow cat soon), TXS mid, MS CBE, HKS Plugs (1 step colder), Fidanza Flywheel, KMD CDFP internals, COBB Sways, Koni Dual Adjustable Shocks, AWR 88 trans mount, Hawk HP+ pads (F+R), Motul RBF 600 brake fluid, 18x8 +50 weds sa70's 245/40 falken rt-615's, V1 hardwired, Autometer ES Gauges (boost/vac, water, oil pres), Dashhawk, stock turbo with modified boost control system
Lymerock is offline   Reply With Quote
 Old 11-30-2008, 12:39 PM   #42
Jarods7920's Avatar
Posts: 1,415   (View Stats)
that would explain the higher price then lol....If you are good at bulding those jaws are removabla and you coudl build your own clamp that could extend them higher.
 Old 11-30-2008, 01:14 PM   #43
Lymerock's Avatar
Just got done installing the internals, fuel pressure at idle is 100psi higher
the pump does make more noise than the stock internals, no doubt there, but i only noticed when i started the car and had the hood up, inside the cabin I couldnt tell a difference.
as far as using a vice and all that, I whipped out my cordless impact and had it apart in about 2 seconds and used it oh so gently to put the pump back together as well.
hardest part of the install was getting the bottom hard line connected again, not difficult, but i did swear a few times when the nut fell down the pipe, screw dem zipties!
07 CB Speed3
 Old 11-30-2008, 01:21 PM   #44
Deadman's Avatar
Posts: 868   (View Stats)
Deadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the world
Groaned at 31 Times in 16 Posts
what did you hold it with when using the impact?? I have a vice at work so i will prolly do it that way unless you have an easier way lol
Deadman is offline   Reply With Quote
 Old 11-30-2008, 01:34 PM   #45
Lymerock's Avatar
I held it with my hand, didnt even hold it tight, it was off within the first 2-3 beats
the nut probably has less than 75lbs of torque on it because it was easier than using my impact to remove my tire lugs and those are on at 86ftlbs
at first I tried to use a clamp against a work bench while using a big breaker bar and that didnt seem too safe for the pump as it was really wanting to twist its way out of the clamp
07 CB Speed3
 Old 11-30-2008, 01:37 PM   #46
CraigHJr's Avatar
Posts: 676   (View Stats)
CraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the world
The cheap ass in me LOVES Harbor Freight, but the mechanic in me says no no no its not Snap-on.
Eighty8 likes this.
If anyone needs install help in my area (Bergen County NJ) let me know. I have all the tools and work for cheap.
CraigHJr is offline   Reply With Quote
 Old 11-30-2008, 03:58 PM   #47
Jarods7920's Avatar
Ya i love snap on too....but i am not going to pay triple for a vice i just wont. Now ratchets and things...my matco and snap on ones are fucking amazing.
 Old 01-28-2009, 06:53 PM   #48
Stan-O's Avatar
Posts: 182   (View Stats)
Stan-O is just really niceStan-O is just really niceStan-O is just really niceStan-O is just really niceStan-O is just really nice
Groaned at 5 Times in 1 Post
Can someone explain in better detail how to let the car build up pressure by disabling the coil packs?? Do you turn the car over a few times??
Just need some clarification
Thanks
Stan-O
Speed-less
Stan-O is offline   Reply With Quote
 Old 01-28-2009, 07:42 PM   #49
CraigHJr's Avatar
Thanks
Stan-O
Yes thats is just to prime the low pressure fuel side. I honestly didn't do it on mine. Just turn the key on and off 3 times and fire away. Whats the worst that could happen the parts are doomed to make noise anyway.
 Old 02-01-2009, 12:24 AM   #50
watdog's Avatar
Posts: 138   (View Stats)
watdog has much to be proud ofwatdog has much to be proud ofwatdog has much to be proud ofwatdog has much to be proud ofwatdog has much to be proud ofwatdog has much to be proud ofwatdog has much to be proud ofwatdog has much to be proud of
So what is the torque spec when re-installing that 18mm nut?
watdog is offline   Reply With Quote
 Old 02-02-2009, 06:11 PM   #51
CraigHJr's Avatar
Tight...Sorry thats the best I can come up with.
 Old 02-03-2009, 07:24 AM   #52
watdog's Avatar
Looks like there is an o-ring that needs to seal with that nut. If you over tighten it then it smashes that o-ring and will leak. To little and it doesn't seal also. Hmm... Someone should know.
 Old 02-09-2009, 03:14 PM   #53
vbt101's Avatar
Posts: 733   (View Stats)
vbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the world
Yep, sweet write-up. This is gonna be useful when the upgraded internals come out!
vbt101 is offline   Reply With Quote
 Old 02-16-2009, 09:30 AM   #54
tagkat's Avatar
Posts: 269   (View Stats)
tagkat is a splendid one to beholdtagkat is a splendid one to beholdtagkat is a splendid one to beholdtagkat is a splendid one to beholdtagkat is a splendid one to beholdtagkat is a splendid one to beholdtagkat is a splendid one to behold
Another good write up however watermarks are obnoxious!
Krystm’s Garage - Mazda 3 Mods and More! Cam Driven Fuel Pump (CDFP) Internals Install
tagkat is offline   Reply With Quote
 Old 02-16-2009, 09:49 AM   #55
Krystm's Avatar
Posts: 13   (View Stats)
Krystm has a reputation beyond reputeKrystm has a reputation beyond reputeKrystm has a reputation beyond reputeKrystm has a reputation beyond reputeKrystm has a reputation beyond reputeKrystm has a reputation beyond reputeKrystm has a reputation beyond reputeKrystm has a reputation beyond reputeKrystm has a reputation beyond reputeKrystm has a reputation beyond reputeKrystm has a reputation beyond repute
Lowered the visibility of the watermarks should be good to go now.
Krystm is offline   Reply With Quote
The Following 2 Users Say Thank You to Krystm For This Useful Post:
lvmazdaspeed3 (06-14-2009), tagkat (02-16-2009)
 Old 03-07-2009, 09:18 AM   #56
AFcadet's Avatar
Posts: 937   (View Stats)
AFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the world
Is there a thread where I can order these internals?
AFcadet is offline   Reply With Quote
 Old 03-07-2009, 10:27 AM   #57
CraigHJr's Avatar
Protege Garage is a big sponcer of all of the forums. I couldn't imagine why you would need a thread to buy the parts when they are readily avalible from a website?
 Old 03-13-2009, 03:32 AM   #58
evidence's Avatar
Posts: 1,033   (View Stats)
Threw my pg 'v2' internals in today, needing the vice and breaker bar is no joke.. that shit was on there. I did get P0091 (fuel pressure regulator control circuit low) when i started it back up, but thats prob from runnin it dry with the relay out.
Just a note if you dont have a deep 18mm handy you can pull the spring and retainer off and use a standard one to tighten it back on. In my case i was only able to put the wratchet 1/2 way in but I was able to torque it plenty tight. Popped the spring and retainer on without much issue after that.
Some things.
 Old 03-16-2009, 09:49 PM   #59
Strizzo's Avatar
Posts: 148   (View Stats)
Strizzo is a glorious beacon of lightStrizzo is a glorious beacon of lightStrizzo is a glorious beacon of lightStrizzo is a glorious beacon of lightStrizzo is a glorious beacon of lightStrizzo is a glorious beacon of light
just an FYI, you don't need to disable the coils to prime the pump after you finish. if you hold the gas pedal to the floor while pushing in the clutch and turning the key, it won't fire the injectors so that you don't blow something up. pump primed and ready.
also, if your open end wrench set is like mine and stops at 17mm, check and see if you have a 3/4 inch open end, its almost the same size and will work just fine.
Strizzo is offline   Reply With Quote
 Old 04-25-2009, 08:59 AM   #60
EvilSpeed3's Avatar
Posts: 33   (View Stats)
EvilSpeed3 is just really niceEvilSpeed3 is just really niceEvilSpeed3 is just really niceEvilSpeed3 is just really nice
Thanks for the great info, write up, and pics.
Mazdaspeed Cold-Air Intake. Mazdaspeed Cat-Back Exhaust. Cobb ARBs. RKM Chassis Braces. Custom Heated Seats.
EvilSpeed3 is offline   Reply With Quote
 Old 06-09-2009, 11:39 AM   #61
Oakes Salancy's Avatar
Posts: 17   (View Stats)
Oakes Salancy will become famous soon enoughOakes Salancy will become famous soon enough
Great write up. Itll save me money for sure.
2008 BLACK MICA MS3
CP-e Catless DP+HKS BOV and R-Suction Intake+SU REM+FI CF Vented Hood
DG Rear Diffuser+Konig Hotswap CF 18"+Seche Media Front/Back Stripes
Alpine(500W 12")/Infinity Kappa Audio(6X8*)+Low/Fog 10000K HID
ORDERED/IN MAIL:
COBB FMIC+CF Dash Kit+Raptor Angel Eyes+New AC Condenser-Dam Critter
Oakes Salancy is offline   Reply With Quote
 Old 08-05-2009, 01:35 PM   #62
flyrevs2's Avatar
Posts: 1,235   (View Stats)
flyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the world
good one, except you need to finish up with lubeing it all up in fresh clean OIL, the gasoline is not a lubricant and is suspect in causing the unit to fail !
2013 Mazdaspeed3 Gen2
Mods: Cobb SRI, Tip, Turbosmart BPV, Cobb AP, Cp-e DP, CPE HPFP, CPE RMM, PTP Kicker Mount
flyrevs2 is offline   Reply With Quote
 Old 08-05-2009, 01:41 PM   #63
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
clean with brake cleaner
 Old 08-05-2009, 01:47 PM   #64
CraigHJr's Avatar
Are you saying that the gas that is pressurized in the pump never touches the piston that you change from the kit?
 Old 12-26-2009, 05:33 PM   #65
shpankey's Avatar
Posts: 496   (View Stats)
did mine the other night. I used brake cleaner, not gas, to soak and clean it with, then dabbed some oil on the spring side.
just turn the key on and off about 6 times without starting to prime the pump. then hold the pedal to the floor and try to start (it won't) for a couple rotations. THEN start it normal. this avoids having to pull any fuses or whatever.
also, some people say to break the pump in right, you should let it idle for 20 minutes (seems excessive to me) and then drive carefully for 100 miles, never going over 4k rpm's in any gear. this supposedly breaks the pump in right.
p.s. I had a problem with my 18mm deep well socket. mine wasn't thin walled all the way back, instead only the part with at the end was. this won't let the socket go over the spring and back on to the nut. i bought another, and it was only thin walled half way back... i had to push the socket in HARD (thereby depressing the spring) and this allowed it back to the nut. a major PITA!
shpankey is offline   Reply With Quote
 Old 12-26-2009, 07:00 PM   #66
Spoolme's Avatar
Posts: 1,041   (View Stats)
Spoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the world
Groans: 54
Nice write up. Isn't there a video of this somewhere???
Spoolme is offline   Reply With Quote
 Old 12-26-2009, 07:46 PM   #67
bf360's Avatar
Posts: 2,069   (View Stats)
DO NOT USE GAS PEOPLE USE OIL FOR LUBRICATION
Originally Posted by DCLXVI View Post
your car is possessed by satan, so i dunno whats goin on with that LOL vta's shootin fire some crazy ass extra fluid lines. secret boost control settings haha ninja, or your demon spawn gas pedal not taking no for an answer lololol but your shit rips it.
bf360 is offline   Reply With Quote
 Old 12-26-2009, 07:49 PM   #68
evidence's Avatar
Actually I thought you put it in gas in the early instructions to clean any contaminants, I don't think lubrication is needed. The lube is in the coating. That's why some people are using brake cleaner now, no residue left over and ensures the parts are clean. I do put a drop of oil on the o-rings though to make sure everything slides in nice and tight.
Some things.
 Old 01-01-2010, 05:08 PM   #69
boyer's Avatar
Posts: 37   (View Stats)
boyer is just really niceboyer is just really niceboyer is just really niceboyer is just really nice
Help!!!! -- with the PTP internals, how do you get the spring retainer off the shaft to reuse it?????
I didn't want to risk forcing it and fuggin everything up...
duh, just slid off with a little angled force... what an idiot....
Last edited by boyer; 01-01-2010 at 05:27 PM. Reason: MSF Database - Automerged Doublepost
boyer is offline   Reply With Quote
 Old 01-13-2010, 12:38 PM   #70
DaleNixon's Avatar
Posts: 2,079   (View Stats)
DaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the worldDaleNixon is the leader of the world
Groans: 91
Can someone link me to the exact torx bit I need? I bought some reverse torx bits but they go up to T40 not E8. The guy at Autozone looked at me like I was speaking a foreign language when I said I needed an E8 inverted torx bit.
Gay car #1: 2001 Miata (Gay White)
Gay car #2: 2011 Mazda 2 (Gay Blue)
DaleNixon is offline   Reply With Quote
 Old 01-13-2010, 01:12 PM   #71
CraigHJr's Avatar
whats your email i will send you a picture of one i have in my hand right now.
The Following User Says Thank You to CraigHJr For This Useful Post:
DaleNixon (01-13-2010)
 Old 01-13-2010, 01:55 PM   #72
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
dale, advance had them behind the counter w/ the other sockets. i first tried sears but they didn't have any. go to the craftsman website and search 'torx'. you'll see an e8 inverted torx 1/4" socket.
imagine a socket that goes over a regular torx bit and that's what it looks like. also, the cdfp bolts are visible between your ecu and engine.
The Following User Says Thank You to karl-hungus For This Useful Post:
 Old 01-13-2010, 02:32 PM   #73
DaleNixon's Avatar
Groans: 91
This guy:
http://www.craftsman.com/shc/s/p_101...+torx&sLevel=0
The Following User Says Thank You to DaleNixon For This Useful Post:
FreeFlyFreak (01-19-2010)
 Old 01-13-2010, 02:57 PM   #74
evidence's Avatar
That's it. The Autozone and Checkers by me both carried em. Sounds like the tool was the one standing behind the counter that time
Some things.
The Following User Says Thank You to evidence For This Useful Post:
 Old 01-19-2010, 10:12 AM   #75
Sniper2606's Avatar
Posts: 569   (View Stats)
Sniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the world
Groans: 33
Groaned at 32 Times in 15 Posts
this might sounds stupid lol but is there a thread that tell you how to remove the pump from the car :p
Silly Lebron, rings are for Kobe
2011 WRX STI pro tune Invidia Downpipe and Exhaust,Cobb Intake Cobb AP 91
The nigga bought aluminum tubes! Do I need to tell you what the fuck you can do with an aluminum tube!?! ALUMINUM!!
Dave Chappelle
Sniper2606 is offline   Reply With Quote
 Old 01-19-2010, 10:42 AM   #76
evidence's Avatar
The OP of this thread?
Some things.
 Old 01-20-2010, 12:49 PM   #77
AFcadet's Avatar
This thread needs to be deleted or heavily modified.
The steps where you dip the parts in gasoline is wrong...and caused many failures last spring/summer when protege garage and pale rider were selling the new internals.
Myself and other testers found the key to the install is NOT dipping the parts in gasoline, and instead coating the piston and sleeve in clean motor oil to LUBRICATE the part like it is supposed to be.
Gasoline is not a lubricant. It will dry the part out...and cause more friction. Which is exactly what you dont want when you have brand new fuel pump internals pumping at thousands pumps per minute. The gasoline step caused many pump internals to seize and or create gashes and making it fail.
 Old 01-20-2010, 01:21 PM   #78
evidence's Avatar
Yea.. you can use brake cleaner to clean the part off if you need before giving it a very light coating of oil.
Some things.
 Old 01-20-2010, 01:29 PM   #79
CraigHJr's Avatar
I will mod the original write up from my cell internet. I only followed the crap write up that came with the internals which were not ment for consumers. Back in the day the manufactors tried to fuck us and charge us 5to700 bucks for a pump upgrade that was a 1hr diy swap. I fully agree that oil is needed to lube the internals but my car has been gone long over a year now so I don't follow the forums for updates.
 Old 01-20-2010, 03:19 PM   #80
AFcadet's Avatar
Thats fine bro...just if you could update it by taking out the dunk in gasoline, and lubricate with oil, that would be perfect.
A lot of people use this as a how-to, so obviously it should be the correct way.
Not trying to bash you or anything...you were a pioneer in a way since you were one of the first to have a how to. But a few people did get lucky and have the piston and sleeve "set" correctly instead of tearing itself apart with now lubrication lol
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/camshaft-driven-fuel-pump-internals-upgrade-11215/
The MZR Thread: Mazdas that aren't Miatas or rotaries - The Something Awful Forums This thread Refback 07-21-2014 02:17 AM
HPFP install guide (one I prepared a little earlier) This thread Refback 09-01-2013 10:09 PM
Very pleased with myself.... ? Mazda MPS Owners Club This thread Refback 08-08-2013 09:04 AM
CDFP internals upgrade - Mazdaspeed Forums This thread Refback 02-22-2013 12:28 AM
Parts needed for HIGH PRESSURE FUEL PUMP upgrade. - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 01-25-2013 01:41 PM
Autotech Install Help? This thread Refback 01-04-2013 05:14 PM
T25 safety Torx, where to buy? - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Refback 10-14-2012 06:15 PM
Fuel pump advice • Mazda MPS Owners Club This thread Refback 10-11-2012 12:16 PM
GT3071R TWIN SCROLL - Page 2 This thread Refback 09-06-2012 08:21 AM
Mazda MPS Owners Club • View topic - GroupBuy 2nd Chance! AutoTech HPFP Internals - $375 - Round2 This thread Refback 08-15-2012 02:36 AM
Mazda MPS Owners Club • View topic - Fuel pump advice This thread Refback 06-23-2012 02:38 PM
dyno sheet - Page 3 This thread Refback 03-28-2012 10:35 AM
KMD Internals HPFP Install issue - help plz - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 12-27-2011 03:10 PM
MZR talk here **NO SUBARUS ALLOWED** - The Something Awful Forums This thread Refback 08-08-2011 01:19 AM
KMD internals (with TiCN-MP coating) installed - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 08-07-2011 07:56 PM
Fuel Pump problem This thread Refback 06-17-2011 03:57 PM
KMD internals (with TiCN-MP coating) installed - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 06-11-2011 04:36 PM
Forum Mazda Performance Series - Zobacz temat - PTP fuel pump internals This thread Refback 05-27-2011 08:39 AM
hpfp ? - Page 2 - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum This thread Refback 03-26-2011 04:34 AM
Fuel Pump problem This thread Refback 11-22-2010 01:56 PM
Mazda MPS Owners Club • View topic - Very pleased with myself.... This thread Refback 11-21-2010 09:41 AM
CDFP install This thread Refback 05-28-2010 09:31 PM
Fuel Pump problem - Mazda CX-7 Forums This thread Refback 03-25-2010 03:01 PM
Why you should run our HPFP.... - MazdasNW This thread Refback 01-20-2010 09:53 PM
MattJackson86's Bookmarks on Delicious This thread Refback 06-06-2009 06:34 PM
Walbro 255 Fuel Pump - TorontoMazda3 This thread Refback 02-07-2009 03:06 PM
Walbro 255 Fule Pump - TorontoMazda3 This thread Refback 02-07-2009 07:48 AM
High Flow Fuel Pump Internals Kit kingpin748 Mazdaspeed3/6 General Discussion 36 09-02-2008 09:50 AM
Fuel pump internals cgburton12 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 43 08-11-2008 01:29 PM
Pump internals in stock? Erich Mazdaspeed3/6 General Discussion 13 08-11-2008 12:32 PM
So now they offer the internals for pumps! Death-From-A-Mile MazdaSpeed 3 - Engine, Transmission & Driveline 25 07-11-2008 08:31 AM
Page generated in 0.58673 seconds with 43 queries
