| MazdaSpeed 3 - How-To's MazdaSpeed 3 - How-To's - Want help out fellow owners? Post How-To's to simplify future installations for others. |
![]() Join Date: Aug 2018 Location: California
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score I am new to the whole tuning scene and need some help. I installed a cobb Sri intake and the check engine light for running too lean always pop up. I have check to make sure everything is all tie down. I have not gotten a turn yet and any help would come a long way. TY |
Groans: 111
| Not Ranked : 0 score A Cobb SRI intake should work with the stock tune and MAF calibration even though there's about 10% deviation which is manageable. So most probably you either forgot to connect one of the EBCS lines, did not tighten enough the clamp between the SRI and turbo inlet pipe, or upset the turbo inlet pipe especially if you're still using the stock one which is pretty flimsy. Other than that you check for common mistakes such as not tightening the MAF sensor properly, or damaging it's sealing o-ring, or fitting it backwards.
| AFR check engine light. | Ms3jerm | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 6 | 08-11-2015 09:04 AM |
| Check engine light came on after 7 months with light mods | SwizzleSpd | MazdaSpeed 3/6 - Turbo Induction | 10 | 01-03-2013 05:15 PM |
| engine idle and check engine light | msalva2 | MazdaSpeed 3 - Engine, Transmission & Driveline | 35 | 07-25-2012 04:48 PM |
| Check Engine Light | Stingray69 | Gen2 MS3 General Discussion | 5 | 11-18-2011 04:37 PM |
| Oh No Check Engine Light! | thabigo | MazdaSpeed 6 - Engine, Transmission & Driveline | 8 | 04-04-2009 01:57 PM |
