> MazdaSpeed 3 - How-To's
 Old 08-24-2018, 02:30 PM   #1
Chocolie's Avatar
Posts: 3   (View Stats)
Chocolie has a little shameless behaviour in the past
Default COILOVER RECOMMENDATION
Hello I am new to this forum and I really want to get into my 2012 Mazdaspeed 3 I just got and I hear different feed back on BCR and Raceland
Chocolie is offline   Reply With Quote
 Old 08-24-2018, 02:43 PM   #2
Db09ms3's Avatar
Posts: 536   (View Stats)
Groans: 105
Chop them springs and save money!
Stockish
 Old 08-24-2018, 03:45 PM   #3
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Well......since you are new now is the time to go read up on in the suspension section. No one is going to tell you what coilovers to get as its been beaten to death. Lots and lots of info/reviews on here if you're willing to search and read it.
I will say however, don't waste money on Raceland Chinese shit. Save up and do it right the first time. You'll be much happier!
 Old 04-28-2019, 02:22 PM   #4
GregScuba's Avatar
Posts: 96   (View Stats)
GregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the world
Had great luck with Bilstein B2's personally. A little on the stiff side, but very well composed. If you are going to drop the money on it, do it right the first time, and don't cheap out. Suspension is so important, not something to cut corners on.
2010 Liquid Silver Mazdaspeed 3
Cobb AP v3, tuning by Stratified Automotive Controls, Autotech HPFP internals, one step colder NGK Iridium plugs, Cobb DP, Magnaflow 3" CBE, Corksport SRI/TIP, Corksport Race RMM 80A, Synapse Synchronic DV in push mode A+B, Treadstone TR6 FMIC, JBR FMIC piping kit, JBR Silicone recirc hose, JBR rear sway bar, Bilstein B14 coilovers, SPC adjustable rear camber arms, Stoptech SS brake lines and brake pads, 17x9" et+45mm Enkei Racing RPF1's, 245/40/17 Hankook RS3's, JBR 5mm hub/wheel spacers in front.
GregScuba is offline   Reply With Quote
 Old 02-06-2020, 08:30 PM   #5
Pat Attack96's Avatar
Pat Attack96 is an unknown quantity at this point
I have BC BR Type Coilovers that are re-valved for 14k Swift springs by Corner 3 Motorsports (great guys to work with who really know what they are talking about). I actually had these for an 08' Mazda 3 before I got my 09' Speed 3... but they still work well with the Speed 3 despite the weight differences for what I use the car for (autocross & occasional track days). They are great bang for the buck! Like mentioned already... don't cheap out on suspension because you'll end up having to spend more in the long run doing so.
Pat Attack96 is offline   Reply With Quote
 Old 02-06-2020, 09:37 PM   #6
55suarod's Avatar
Posts: 36   (View Stats)
55suarod is a jewel in the rough55suarod is a jewel in the rough55suarod is a jewel in the rough
I run the koni str.t + eibach pro lowering springs. Like the drop and it feels solid. Have over 20k on yhis setup now. Best bang for buck I found when I was looking.
55suarod is offline   Reply With Quote
 Old 02-07-2020, 01:30 PM   #7
Posts: 2,233   (View Stats)
I may get it wrong but if you look at raceland, handling isn't your first goal ? And in here drop and camber aren't very popular.
Strut/coilover recommendation 570msp MazdaSpeed 3/6 - Suspension & Brakes 0 06-06-2016 01:38 PM
Recommendation TheHitman Drag Racing 1 04-16-2011 12:13 AM
AP Map Recommendation Tomas MazdaSpeed 3/6 - ECU Computer Tuning 15 04-19-2009 07:09 AM
new mod recommendation! jlocurto Mazdaspeed3/6 General Discussion 29 09-23-2008 08:57 AM
Page generated in 0.28034 seconds with 26 queries
