> MazdaSpeed 3 - How-To's
 Old 03-29-2008, 09:53 PM   #1
billyrohm's Avatar
Posts: 75   (View Stats)
billyrohm has a spectacular aura aboutbillyrohm has a spectacular aura aboutbillyrohm has a spectacular aura about
Default DIY Short Ram Intake
Ok so I'm one of the ones that bought the MS3 that probably shouldn't have financially but I did and I'm so glad I did. Either way, I wanted an intake but I didn't want to spend around $200 for one so I decided to make my own. I don't really have step by step but its pretty self explanatory.
I bought the following Spectre parts:
9405 - MAF adapter/tuning kit (its a 3" maf tube with different sensor adapters and different inserts to adjust the tube size (I used the 2.75" adapter) $28
9402- Filter Support bracket (Its a bracket that goes between the filter and coupler to mount to the car. There is a stud in front of the battery that I attached it to) $13
8132 - Filter (Normal oiled filter) $25
8771 - Silicone Coupler $8
Total of about $74
You can get all of this at autozone or pepboys. They might have to order it but most of the time Autozone Can have it the next day if you order by 2pm.
It works well, major difference. I think I'm hitting fuel cut/over boosting if I do a roll on in 5th or 6th gear. If I just pound through the gears its perfect.
This is my first performance mod.
Let me know what you think.
I've had it for two days, sounds great, looks okay and seems to work very well. Probably the best $74 I've ever spent.
If anybody knows anything about the overboost/surging let me know. For now I'll just down shift.
billyrohm is offline   Reply With Quote
 Old 03-30-2008, 09:37 PM   #2
Young Roids
Lurkers
Young Roids's Avatar
Posts: n/a
Nice work. I didn't know autozone carried that stuff. That only thing I would worry about is that the maf tube part was the exact size it needs to be so that you are not changing your A/F ratio.
 Old 03-30-2008, 10:34 PM   #3
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
hmm that maf solution might have helped the corksport oversized maf housing. all we would need to do is put that adapter into their housing.
 Old 03-31-2008, 07:04 AM   #4
billyrohm's Avatar
Dont know, got a CEL last night, gotta get it read.
I tried reading with my reader and it wouldnt link to the car, but I tried it on my other car and it worked
 Old 03-31-2008, 07:06 AM   #5
bova's Avatar
Groans: 45
you are probably running a bit lean because i think the stock maf housing is about 2.62"
 Old 03-31-2008, 07:22 AM   #6
billyrohm's Avatar
You have to order most of it, takes a day to get it.
 Old 03-31-2008, 07:24 AM   #7
billyrohm's Avatar
That sucks, the next smallest size is 2.5", that would make me run rich wouldn't it?
 Old 03-31-2008, 07:26 AM   #8
bova's Avatar
Groans: 45
yup. if the code you get pulled is p2177 or p2187 thats means your lean.
 Old 03-31-2008, 04:15 PM   #9
billyrohm's Avatar
Code P2187, lean on idle. Do I really need to be worried being lean on idle?
I read some other posts on the other forum and it could be due to a vacuum leak too. I'm going to get some gasket material and ensure that the adapter that screws to the aluminum for the maf is sealed up. If it keeps coming back I guess I'll just put the stock box back on.
 Old 03-31-2008, 04:17 PM   #10
You need to be worried about any code being displayed, whether you think its not a big deal or not. This just leads to problems down the road and can become a tuning nightmare.
danieldolina70 (04-22-2012)
 Old 03-31-2008, 05:56 PM   #11
billyrohm's Avatar
Yeah, I kinda figured that, I was just trying to convince myself otherwise.
I'm going to seal up around the adapter for the maf itself and see if that fixes it. If not, back to the stock box.
 Old 04-01-2008, 08:49 AM   #12
billyrohm's Avatar
I checked all of the clamps, they were all loose, I'm glad mazda decided to use such quality hose clamps mazda
After reading through the post about the corksport front mount set up I decided to put in the smaller maf adjustment tube (2.5") took it for a drive, no more boost cut or fuel cut whatever it was, turbo stays full tilt all of the time.
Since I did both things at the same time I dont really know which one fixed it.
Either way, the boost/fuel cut/surging or whatever it was is gone. I just hope I my intake is still adding power (due to the 2.5" pipe size, it should flow less now). I'm way tired, I guess I'll see on the drive tomorrow.
Anybody have any thoughts on the 2.62"(stock) versus 2.5"(what I have now) flow difference?
 Old 04-01-2008, 08:58 AM   #13
Well how did it go after tightening everything up?
You NEED to keep your MAF the exact diameter as it is STOCK, no EXCEPTIONS to this unless youre pegging it.. Therefore, the diameter will need to be increased, NEVER decreased.
 Old 04-01-2008, 08:59 AM   #14
bova's Avatar
Groans: 45
you could always dremel the 2.5 one out to 2.62 or whatever is close and make sure its nice and smooth.
 Old 04-01-2008, 09:08 AM   #15
billyrohm's Avatar
Well, hopefully this will work for now, car definately runs better with the 2.5" Versus the 2.75".
I can't dremel the insert out, its a piece of formed plastic.
Haltech,
I might be able to find some silicone hose to put into the tube, I think some 2.75" tube might fit and it should make the tube about 2.6-2.65" in diameter.
So do I need to go back to the stock box until I figure it out or will the 2.5" be cool for a little while? (Laloosh did this for a little while)
 Old 04-01-2008, 09:10 AM   #16
bova's Avatar
Groans: 45
nonsense, rev that dremel up and grind away.
The Following User Says Thank You to bova For This Useful Post:
SLOWHATCH (05-06-2012)
 Old 04-01-2008, 09:17 AM   #17
billyrohm's Avatar
You should read up on the Spectre 9405, the inserts are thin plastic, if I grind more than a little I'll put a hole it.
Thanks though, I think the silicone tube is going to be my best bet if I need 2.62" +/- a little.
 Old 04-01-2008, 09:51 AM   #18
bova's Avatar
Groans: 45
oh ok, i didn't realize they didn't fill the whole tube up with the transition to a smaller size. i understand now.
yeah i would go with a thin silicon tube to closely match the size.
 Old 04-01-2008, 07:46 PM   #19
Hypnotized's Avatar
Posts: 184   (View Stats)
Hypnotized is a splendid one to beholdHypnotized is a splendid one to beholdHypnotized is a splendid one to beholdHypnotized is a splendid one to beholdHypnotized is a splendid one to beholdHypnotized is a splendid one to behold
When I ran this setup last year it threw a CEL all the time. Had to take it off.
Hypnotized is offline   Reply With Quote
 Old 04-01-2008, 09:07 PM   #20
billyrohm's Avatar
Default Exact stock maf size
I found a place that sells aluminum tubing in nearly any size that you want ( Online Metal Store | Small Quantity Metal Orders | Metal Cutting, Sales & Shipping | Buy Steel, Aluminum, Copper, Brass, Stainless | Metal Product Guides at OnlineMetals.com )
They have 2.62 and 2.625 inner diameter. I need to know the EXACT inner diameter of the stock housing. I've seen 2.62 here, 2.6* or whatever on another forum. I dont have the tool(s) to measure the exact inner diameter of the tube. So somebody that does please do or can I have multiple confirms and the inner diameter is infact 2.62"
 Old 04-05-2008, 12:14 AM   #21
billyrohm's Avatar
I ordered some of the 2.62" tubing.
After I get it in hopefully it'll be okay, intake for $94, I can live with that.
FWIW I havent gotten any CEL's since I put in the 2.5" reducer. Hopefully It'll get stuff reset when I get the 2.62" tube in.
 Old 04-05-2008, 07:33 AM   #22
bova's Avatar
Groans: 45
do you have a dashhawk? you could check your fuel trims and it might be that you are in a safe zone. cel's are usually thrown if they are off by 15%.
 Old 04-06-2008, 03:20 PM   #23
billyrohm's Avatar
Waiting on the AP, The AP is 695 and the hawk is 300 so if
 Old 08-20-2008, 07:30 PM   #24
2008MS3's Avatar
Posts: 3   (View Stats)
2008MS3 is an unknown quantity at this point
Any updates after adding the aluminum tube?
2008MS3 is offline   Reply With Quote
 Old 08-20-2008, 09:36 PM   #25
billyrohm's Avatar
Went Cobb SRI, works great.
 Old 08-31-2008, 06:50 AM   #26
bani's Avatar
Posts: 335   (View Stats)
bani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond repute
Groans: 35
Groaned at 35 Times in 17 Posts
so basically the conclusion is, dont use this DIY. lol
bani is offline   Reply With Quote
The Following User Says Thank You to bani For This Useful Post:
gtlaw (05-15-2011)
 Old 08-31-2008, 07:22 AM   #27
Lymerock's Avatar
Posts: 1,436   (View Stats)
Lymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the world
haha, that shit made me spit milk
moral of the story, leave it to the pro's kids
Lymerock is offline   Reply With Quote
 Old 09-08-2008, 11:00 AM   #28
MTuning's Avatar
Posts: 362   (View Stats)
MTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond repute
Groaned at 16 Times in 8 Posts
why cause they're light years on backorder?
MTuning is offline   Reply With Quote
 Old 09-11-2008, 09:54 PM   #29
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
How did you just go Cobb?
Some people have had orders placed for over 4 months and still nothing.
 Old 09-11-2008, 10:32 PM   #30
billyrohm's Avatar
Ebay, a while ago saw one for $140 bin with $9.99 shipping so I got it.
 Old 09-12-2008, 11:01 AM   #31
bnoon's Avatar
Posts: 1,770   (View Stats)
I did the DIY Spectre MAF housing and have not had a CEL since I epoxied air straighteners into it (cut my own air straighteners from sheet metal and used plumber's epoxy). Only cost me 10 bux for the MAF housing too since it was a returned package at a local auto parts store. 35 bux including the cost of the filter, no CEL, no boost cut and HUGE SOTP gain in all gears. I'll get some pics this weekend for you if anyone wants me to.
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
 Old 09-12-2008, 03:55 PM   #32
bykeryder4life's Avatar
Posts: 1,032   (View Stats)
bykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the world
Groans: 38
you better hope that plumbers epoxy never gives or your air straightener will be in your turbo real quick. I noticed in the 1st post that he said he got a "regular OILED filter". What a joke.... oiled filters suck for cars with a MAF. why do people waste time and money trying to do this cheap shit just do it right or not at all if you cant afford it
bykeryder4life is offline   Reply With Quote
The Following User Says Thank You to bykeryder4life For This Useful Post:
gtlaw (05-15-2011)
The Following User Says NO Thank You to bykeryder4life For This Un-useful Post:
 Old 09-13-2008, 12:02 AM   #33
billyrohm's Avatar
The cobb also comes with an oiled filter, I think a few people might be using the cobb with its oiled filter with no trouble.
The Following User Says Thank You to billyrohm For This Useful Post:
bykeryder4life (09-13-2008)
 Old 09-13-2008, 06:58 PM   #34
Groans: 38
I was unaware of that, yes there are plenty of people with the cobb that dont have problems. However, last time I checked it was a better choice to run a dryflow filter with a MAF car because if you dont know what your doing and put a little too much oil on your filter you are fucked and will be buying a new MAF sensor or spending a lot of time cleaning it. Go ahead and disagree but anyone who knows cars would lean towards the dryflow before an oiled filter anyday.....
 Old 09-13-2008, 07:02 PM   #35
Groans: 38
lets not turn this into a cobb v.s. whoever thread now either. Cobb's oiled filter is great but just because they used an oiled filter it doesnt mean thats whats the best for the car and it shouldnt be argued.....
 Old 09-14-2008, 09:51 AM   #36
billyrohm's Avatar
Agreed, it just seemed as if he didn't know that the Cobb came with an oiled.
 Old 09-15-2008, 09:50 AM   #37
bnoon's Avatar
Some people are hard core do it yourselfers and could give a what other people are doing for hundreds more for something as simple as an intake. I can't believe people are willing to pay as much as they do for a filter and MAF adapter... It really does blow my mind.
As for the air straighteners, even if they are loose in the MAF, they will not travel into the turbo. I made them large enough that they will not travel through the rest of the intake (press fit).
... and oiled vs dry flow is silly on this vehicle. The MAF sensor wires are NOT in direct airflow AT ALL and the filter would have to simply be DRIPPING with oil to get oil on the MAF sensor wires. It's so simple to clean MAF wires anyway if you should happen to get them dirty (spray electrical cleaner, done).
2002 BMW M3 - Sold!
 Old 09-15-2008, 12:34 PM   #38
MTuning's Avatar
its ok, some ppl just dont have that part of the brain to understand the customization part of this game. what do you think tuners did back in the day before the aftermarket industry blew up?
 Old 09-15-2008, 04:07 PM   #39
Groans: 38
nice thanks for the info I was just saying that about the straighteners as a word of caution, just my .02. I dont know people and their experience levels so i was just offering some info... As for the whole oiled filter thing I had the wrong understanding thanks for clearing it all up.
 Old 09-15-2008, 04:10 PM   #40
Groans: 38
Ok thanks man I guess I am lacking a higher part of the brain that god blessed you with.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/diy-short-ram-intake-1267/
mazdaspeed6 so quiet you wouldn't know it had a turbo - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 06-20-2013 07:51 AM
Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 03-29-2008 11:49 PM
how NOT to install a TWM Short throw shifter CMESCOOT MazdaSpeed 3 - Engine, Transmission & Driveline 20 04-01-2008 09:06 AM
GM finds short-term solution to American Axle strike Haltech Automotive News 0 04-01-2008 08:10 AM
Ported intake manifold? driver311 Mazdaspeed3/6 General Discussion 17 03-26-2008 01:59 PM
Page generated in 0.54418 seconds with 31 queries
