> MazdaSpeed 3 - How-To's
 Old 07-25-2018, 05:07 PM   #1
MSpeedRon's Avatar
Posts: 5   (View Stats)
MSpeedRon is an unknown quantity at this point
Default Drivers Axle C-Clip Opening Up or Down? 2006 Mazda3 2.3 Manual Trans
Hi everyone I have a 2006 Mazda 3 2.3 with manual transmission. We just bought a new driver's CV axle which has the C-clip. Mazda3 owners manuals, repair and service manuals for "Drive Shaft Removal/Installation" (not sure what years it covers) says "clip opening facing upward". Haynes Manual 2004 thru 2011 says "Position the spring clip with the opening facing down. This will ease insertion of the driveaxle and prevent damage to the clip". Anyone know which is correct?
MSpeedRon is offline   Reply With Quote
 Old 07-25-2018, 07:13 PM   #2
Solarsurge's Avatar
Posts: 577   (View Stats)
Get it in the hole. That’s all that matters. If it feels like you’re fighting it, you probably are damaging it. If it’s properly aligned, you should be able to slide the axle in fairly freely and “bump” it to get it to “click” in place.
 Old 07-25-2018, 07:40 PM   #3
Bingo's Avatar
Posts: 740   (View Stats)
Groaned at 9 Times in 7 Posts
Sounds a lot like my first time too...
The Following User Says Thank You to Bingo For This Useful Post:
Solarsurge (07-25-2018)
 Old 07-25-2018, 07:50 PM   #4
Solarsurge's Avatar
Also, use a wire brush and a lint free cloth to clean off the splines, then lube them up with a little transmission fluid to make insertion easier. DO NOT use grease.
 Old 07-26-2018, 02:49 AM   #5
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
I didn't align mine in any specific way. Just like the other poster said jam it in there till it clicks. It is very important to have the axle level when inserting it since the c clip can very easily nick the axle seal in there and cause the tranny goop to leak out
MECP
2012 BM
Rfinkle tune in progress
 Old 07-29-2018, 11:17 AM   #6
MSpeedRon's Avatar
Thanks everyone, the axle is installed and went in with a couple tries without undue force. I went with "opening up" thinking that if anything the open ends would be less likely to be sticking out - but I agree it seems likely not to matter too much. It was a new axle so the clip was new/tight/not distorted. But I did follow the directions of the axle manufacturer to "center the clip with grease" to help it stay centered. But I agree that unfortunately the grease will likely just end up as goop in the transmission fluid.
Thanks Jason! Great clip of our axle-back exhaust AustinK CorkSport 11 08-10-2013 12:45 PM
Corksport axle-back sound clip boatis 2010 MS3 - Engine, Transmission & Driveline 8 07-03-2013 06:14 AM
Video: Exclusive clip from SENNA, opening next week in U.S. Haltech Automotive News 0 08-03-2011 05:30 PM
Page generated in 0.27435 seconds with 23 queries
