| MazdaSpeed 3 - How-To's MazdaSpeed 3 - How-To's - Want help out fellow owners? Post How-To's to simplify future installations for others. |
![]() Join Date: Mar 2008 Location: Ft. Lauderdale
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score ***UTILIZING YOUR CAR'S MANUAL*** locate the fuse box layout. **fuse box is located behind your glove compartment** (physical fuse) 'CIGAR' - will be used for the red wire located at the back of your gauge. (physical fuse) 'IG SIG' - will be used for the white wire, used for white daytime illumination (physical fuse) 'Tail L' - will be used for the amber wire, used for amber/red nightime illumination. NOTES: Best ground source and the only one that should be used is located in the driver's and passenger side kick panels. In the add a circuit package, there is a fuse marked 'E'. This is a straight-thru fuse, use these on all your add a circuits in conjunction with the original fuse who's spot you plugging into. With a small wire spool from radio shack, physical labor shouldnt take you anymore than an hour flat if not less. if it does ![]() ENJOY! |
| The Following 8 Users Say Thank You to trufanatic For This Useful Post: | breakfasteatre (05-31-2012), FastAttack (05-31-2008), Haltech (05-08-2008), JBR (05-09-2010), kingpin748 (07-25-2008), oneurt (07-30-2011), retrobmx63 (09-20-2008), Shive (07-17-2011) |
| The Following User Says Thank You to For This Useful Post: | FastAttack (05-31-2008) |
| Miembro ![]() Join Date: Jun 2008 Location: Puerto Rico
Rep Power: 420 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,095
Groans: 27
| Not Ranked : 0 score I just installed my Prosport Electrical Boost Gauge and the Automatic headlight sensor stopped working and I dont know why..Its in auto and its at night and the headlights dont turn on. I used the Add a circuits and used Ig Sig for Orange and Red (did not use the white). Tomorrow Im going to check everything again and Im going to plug the Red in a Constant. Can anyone tell me what went wrong? |
Groans: 27
| Not Ranked : 0 score Fixed the problem...Stupid Fuse lol
__________________ 2008.5 MS3 Metro Gray...slow |
| NEC ![]() Join Date: Mar 2008
Rep Power: 473 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 129
| Not Ranked : 0 score So just an FYI for anyone else who follows this install: the CIGAR fuse is not a constant 12v... i.e. no power when battery unplugged, so if your gauges aren't keeping your peaks after you turn off the car, or are beeping at you everytime you turn the car off and on again, you need to switch to a constant 12V source. What I did was use the fuse for the double locking system... its the same size as the CIGAR fuse so all I had to do was swap my add a circuit into another location. If you look in your owners manual, on page 8-57 they have the fuse diagram, the one I used for constant 12v is #37 D/LOCK 2 If that doesn't work, try using the one for OBD.
__________________ 2006 Lotus Elise: Toy car 1999 B4000: DD / Parts hauler / SC Project 2007 Mazdaspeed 3: *sold* 2005 Corolla XRS: *sold* |
![]() Join Date: Jul 2008 Location: MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 174
| Not Ranked : 0 score I'm not great with electrical know-how. So here's a noob question. The add-a-circuits say they're only good for circuits that are 10 amps max. The Speed3 cigarette lighter fuse is rated at 15 amps. Can you explain why this is ok?
__________________ ---- Hey, do my fingers smell like your mother? |
| Not Ranked : 0 score The ones I used were from autozone and they didn't have anything that said they were rated for only a certain amount. I've been running these gauges setup like this for a while now and so far, no problems.
| Not Ranked : 0 score physical fuse) 'IG SIG" what fuse number is that i can find it in |
![]() Join Date: Mar 2008 Location: Nashville
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 381
| Not Ranked : 0 score has anyone installed a tach or shift light? I need to find the wires to tap into to get the signal. I know there is a genius in here somewhere that knows. Getting some new goodies this week in the mail and need guidance.
__________________ http://active.com/donate/1soldier Making the world a safer place one Taliban at a time. ![]() Arias 8.8:1 Pistons - Pauter rods - Balance Shaft Delete - ARP Head Studs - Street Unit Rear Motor Mount - TurboXS Hybrid BOV - TurboXS Downpipe - - TurboXS FMIC - CP-E CAI - Custom Built/ported and polished Turbo and Wastegate - CP-E Engine Management - Upgraded high pressure fuel pump - PG Turbo Exhaust manifold - PG Dash mount gauge pod - Cooling Mist Progressive Methanol Injection - Apexi TT - VEI gauges (oil pressure, boost ) - Dashhawk -LaminX Fog lights - H&R Sport Springs - Cobb Rear Sway Bar - Tenzo DC-s wrapped in Nitto InVo's - TWM short throw shifter and bushings |
| if you look at some of the posted PDFs in the specs area, you can tap the tach signal from the ecu harness or off one coil's negative side, than switch your shiftlight/tach to 1 cylinder mode.
| Not Ranked : 0 score Haltech for president!
| Not Ranked : 0 score Next quiz for ya: Where does the sender for an egt gauge need to be? I've searched for a "how to" for this as well with no luck. NOTE: the winner gets....hell, all I've got to offer is a thanks and maybe some rep.
| Not Ranked : 0 score Damn, I wish I had known about the "add a circuit's" before! Those look sweet!
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) |
![]() Join Date: Jul 2009 Location: Connecticut
| Not Ranked : 0 score sweet, now i need to pic up some add a circuits. |
![]() Join Date: Oct 2009 Location: Ft. Lauderdale, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
Groaned at 5 Times in 1 Post
![]() Join Date: Jul 2009 Location: Sardinia, Ohio
Rep Power: 4725 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,721
| Not Ranked : 0 score I have the ProSport Premium gauges as well. The 12v constant is just for the memory, peak and warning only. The switched ignition source is the one that will turn the gauges off and on.
__________________ I am my own After Market Company. A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. |
![]() Join Date: May 2009 Location: Honolulu, Hawaii
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 22
It really depends on if you're going to be using an aftermarket header (read: exhaust manifold) or the stock exhaust manifold. The EGT gauge probe should be drilled, tapped into your stock manifold. If you're buying an aftermarket header there should be one installed on it. If not you'll need to drill into the header and have a bung welded on the cylinder port you want to take your readings from. | |
![]() Join Date: Feb 2010 Location: Puerto Rico
Rep Power: 0 ![]() ![]() ![]() Thanks: 16
Groaned at 20 Times in 4 Posts
| Not Ranked : 0 score Would this work with auto meter cobalt gauges?? |
Rep Power: 371 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 558
| Not Ranked : 0 score should work with ANY 12vdc gauge ! The volts don't know or care about brand name. OP Thanks for posting this - awsome.
__________________ 2013 Mazdaspeed3 Gen2 Mods: Cobb SRI, Tip, Turbosmart BPV, Cobb AP, Cp-e DP, CPE HPFP, CPE RMM, PTP Kicker Mount |
| Not Ranked : 0 score Thanks for the quick answer btw why is the air/fuel ratio gauge reading kind of lazy?? it might need more power source or more ground? |
| pewpew ![]() ![]() Join Date: Apr 2008 Location: NoVA
Rep Power: 761 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,124
Groaned at 9 Times in 9 Posts
| Not Ranked : 0 score |
| Not Ranked : 0 score It takes a long time to read from red to green and when it is "hot" or working normally it takes a couple of seconds get the reading when I press the gas sometimes it would not read anything at all if like the car is off and suddenly it works again |
| Not Ranked : 0 score the sensor needs to warm up. |
![]() | | #24 | ![]() |
| Not Ranked : 0 score i understand but after warming up, it reads funny i don't know if is the gauge or is the mixture that is different, because i had a SE-R before and I had the gauge installed and it used to ready different, can it be because it is different in someway? I want to have the gauges on right and they are making me angry every time I work with them and I don't want to do nothing stupid |
![]() | | #25 | ![]() |
| Not Ranked : 0 score which wire did you tap into? |
![]() | | #26 | ![]() |
| Not Ranked : 0 score I ended up running the wire to the fuse box in the front n they are working 100% now |
![]() | | #27 | ![]() |
![]() Join Date: Oct 2008 Location: Greenbackville, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,927
| Not Ranked : 0 score haven't been to pep boys yet but napa and advance don't carry addafuse..autozone did but they had three different ones and i don't know the difference off the top of my head. anyways subbing to use this weekend for my boost, oil press., oil temp and egt gauges. |
![]() | | #28 | ![]() |
![]() Join Date: Apr 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 323
Groaned at 8 Times in 5 Posts
| Not Ranked : 0 score I'm having a problem with the wiring. I have all the wires connected to the fuse box with add a fuse and have them connected to where the OP says to connect them. This is a prosport boost gauge. When I have the key turned forward one click without starting the car the gauge will work like it should (white during day and amber with headlights turned on). Problem is when I start the car the gauge stays white whether the lights are on or not. Any ideas? |
![]() | | #29 | ![]() |
![]() Join Date: Jul 2010 Location: Brandon, FL
Rep Power: 0 ![]() Thanks: 4
| Not Ranked : 0 score I need an answer for this also. I have tried the door locks, as well as the horn, but my gauge stays on even without a key in the ignition. I didn't use the tap a circut things. Could that be the problem? |
![]() | | #30 | ![]() |
![]() Join Date: May 2009 Location: Scottsdale, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,450
| Not Ranked : 0 score Don't wire the power (red?) and illumination (orange or white?) to the same 12v source. The gauge has to have enough constant power to retain the peak/warning settings otherwise they'll beep every time you start the car. So do the red to the constant 12v and the illumination to Ignition so it lights up when you start it.
__________________ 2009 MS3 sport MGM |
![]() | | #31 | ![]() |
![]() Join Date: Jul 2010 Location: Chicago IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 135
Groaned at 7 Times in 3 Posts
| Not Ranked : 0 score Great write up! thanks! |
![]() | | #32 | ![]() |
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score d Great write up Last edited by Justin Johnson; 07-30-2010 at 07:42 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #33 | ![]() |
![]() Join Date: May 2008 Location: New orleans, la
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 294
| Not Ranked : 0 score Anyone have the layout of the fuse box for gen 1s? I lost my manual and need a reference. |
![]() | | #34 | ![]() |
![]() Join Date: Jul 2011
| Not Ranked : 0 score anyone live near castle shannon n would want to install my boost gauge i tired it once cant seem to get the vacuum line through the fire wall willing to pay or even have a brand new aem wide band not using please let me know 412 477 7590 sean |
![]() | | #35 | ![]() |
![]() Join Date: Dec 2010 Location: Springfield, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,536
Groans: 354
Groaned at 213 Times in 109 Posts
| Not Ranked : 0 score Keep on tryin or drill a hole. You really want to pay someone to poke a wire through a hole?
__________________ 2012 Shelby GT500 - Roush Axleback ~ JLT Oil Separator ~ JLT 123mm intake ~ Ngauge ~ Lund Tuned ~ smaller pulley ~ xpipe (loud as fuck now) 2007 Mazdaspeed6 (SOLD) - COBB SRI ~ Gutted Stock Midpipe ~ HKS BPV ~ JBR RMM ~ AWR PMM ~ AWR TMM ~ Juggernaught Rear Diff Mount ~ Dreadnaught Rear Diff Mount ~ ACT Stage 2 Clutch ~ ITV22s ~ AP(self fucking tuned in a week fuckers) ~ Autotech Internals ~ eBay Downpipe ~ Poke Sub thingy |
![]() | | #36 | ![]() |
![]() Join Date: Feb 2009 Location: Daly City,CA
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score If you can pay someone to install your gauge, you can certainly donate |
| The Following User Says Thank You to xchrislee For This Useful Post: | 15driley15 (04-23-2013) |
![]() | | #37 | ![]() |
![]() Join Date: Jun 2009 Location: Old Bridge, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,044
Groans: 125
| Not Ranked : 0 score probably not a good idea to drop your phone number.... and xchrislee dont fucking ask someone to donate when you only have 11 posts. hes asking for help no reason to beg for money |
| The Following User Says Thank You to TWOptSL0W For This Useful Post: | rfinkle2 (04-25-2013) |
![]() | | #38 | ![]() |
![]() Join Date: Feb 2011 Location: Gothenburg, Sweden
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 66
| Not Ranked : 0 score Big-time necropost, but I could really use some help here.. Got a Prosport Premium Peak-gauge and have it hooked up like this with add-a-circuits: 12v red wire - D/LOCK 2-fuse Amber wire - TAIL L-fuse White wire - Unhooked atm, planning on using amber at both day/night. Black wire at a good grounding spot in drivers kick panel. My main problem here is: Gauge wont hold memory once I turn of the car, just as it does NOT have a constant power source. We even tried plugging it directly to the battery but it still wont hold peak/memory. Am I missing something here or is it actually the gauge that is broken?
__________________ New one... Crystal White Pearl Mazda 3 MPS ´09: | Stock ATM | Old one... True Red Mazda 3 MPS ´07: HKS SRI | JBR SSP Stage II + Heavy knob | 3" Corksport TBE | US-spec Tails | US-spec Spoiler | Turbosmart Dual-Port BPV | JBR RMM | CP-e Gaugepod | ProSport Premium/Peak Boostgauge | RallyArmour Mudflaps | CP-e Towplate | Autotech FP-internals | JBR RSB | NGK Iridium IX-plugs Last edited by Squid; 04-04-2012 at 01:09 AM. |
![]() | | #39 | ![]() |
__________________ HKS SSBOV/ COBB Turbo Inlet/ Injen CAI/ Vibrant FMIC/ ATR DP type w/o cats/ stock CBE with deleted resonators/ TWM short shifter/ TWM solid bushings/ TWM shifter knob/ COBB AP Stage 2 93+ @18 psi +/- | |
| help needed - ECU wiring for WI install | subparpunk03 | MazdaSpeed 3/6 - ECU Computer Tuning | 0 | 05-07-2008 06:38 PM |
| Kahn and Cosworth to dominate aftermarket tuning together | Haltech | Automotive News | 0 | 04-18-2008 03:50 PM |
| One-lug aftermarket wheels for the masses | Haltech | Automotive News | 0 | 04-11-2008 05:11 PM |
| U.S. Attorney General: Piracy Funds Terror | Haltech | Computers & Technology News | 1 | 04-01-2008 01:35 AM |
