> MazdaSpeed 3 - How-To's
Like Tree20Likes
Closed Thread
 Old 07-30-2010, 02:06 PM   #41
RichB's Avatar
Posts: 510   (View Stats)
RichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the world
So you bypassed yours in a previous mod? Thanks for the clarification!
2007 Cosmic Blue Mazdaspeed 3 GT
RichB is offline
 Old 07-30-2010, 02:12 PM   #42
Yup. I am in FL. No need for it. Lowers temp at the throttle body. I got eleventy bajillion hp gains from it.
Raider is offline
 Old 07-30-2010, 02:26 PM   #43
RichB's Avatar
ha ha....sounds like alot!
RichB is offline
 Old 07-30-2010, 02:27 PM   #44
Yeah, I can time travel now.
edmsmallcash likes this.
Raider is offline
breakfstincluded (08-09-2012), SLOWHATCH (07-22-2013)
 Old 07-30-2010, 02:59 PM   #45
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
You could just move the throttle body out of the way with the coolant lines still attached to avoid the mess.
socks is offline
The Following 3 Users Say Thank You to socks For This Useful Post:
AZSPEED3 (10-14-2011), Raider (08-02-2010), RichB (08-02-2010)
 Old 08-01-2010, 03:06 PM   #46
G Sp33dy's Avatar
Posts: 337   (View Stats)
G Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the world
Groaned at 7 Times in 3 Posts
excellent write up. reminds me of the EGR in the ford escort days. PITA lol. I've only got 12k on my 08 but I think a seafoaming is in the near future
G Sp33dy is offline
 Old 08-02-2010, 07:30 AM   #47
RichB's Avatar
Thanks for the tip!
RichB is offline
 Old 08-02-2010, 07:34 AM   #48
Yeah, did not pay enough attention to it to tell that can be done.
Raider is offline
 Old 11-12-2010, 06:34 AM   #49
Well, just an update for you. After 11,000 miles, I got a CEL the other day. It was slow to start earlier this week when temps dropped in the low 40's. As soon as temps rose, started fine. Got the code read yesterday. P0401. I gave it an Italian Tune-Up on my way home last night, and this morning, started with no CEL on at all. My next step is to do some direct-seafoam. I am going to get some vinyl tubing, and use one of the syringes we used to give me kid Tylenol with, and just try squirting Seafoam directly into the EGR valve by way of taking off the EGR pipe. I think if I can get it in there, it can clean off whatever mung is possibly causing it to stick when cold. Fun.
Raider is offline
 Old 11-22-2010, 01:00 PM   #50
wankular's Avatar
Posts: 4,343   (View Stats)
Dumb question maybe - does coolant flow through the EGR hard pipe? Would I still need to drain it if I was only doing the EGR delete?
2009 MS3 sport MGM
wankular is offline
 Old 11-22-2010, 01:01 PM   #51
If you are taking the valve itself off, yes. Coolant goes through the valve only.
Raider is offline
wankular (11-22-2010)
 Old 11-22-2010, 01:57 PM   #52
wankular's Avatar
Thanks. I bought a used block off kit and the bung came with teflon tape on it, that's why I was wondering.
2009 MS3 sport MGM
wankular is offline
 Old 12-03-2010, 12:00 PM   #53
lazn's Avatar
Posts: 138   (View Stats)
lazn has a reputation beyond reputelazn has a reputation beyond reputelazn has a reputation beyond reputelazn has a reputation beyond reputelazn has a reputation beyond reputelazn has a reputation beyond reputelazn has a reputation beyond reputelazn has a reputation beyond reputelazn has a reputation beyond reputelazn has a reputation beyond reputelazn has a reputation beyond repute
Groaned at 11 Times in 1 Post
I was getting all ready to do this on Saturday since my car threw a P0401 on Tuesday.. That was after 3/4 of a tank of ARCO gas. But yesterday I filled up with Chevron and added some Techron Concentrate and within 10 miles (and 3 short trips) the engine light was off.. I didn't expect it to work but figured it couldn't hurt. We shall see if it stays off or not, but 5 more trips and still good so far.
lazn is offline
 Old 12-03-2010, 12:09 PM   #54
Yeah, my CEL did ome back a month or so ago, when it first got cold. It went away after 4 trips out, but comes back once in a while. If I jump on it, the CEL comes on quick, but goes away 4 trips later. It is just gummed up, and I need to either take the pipe off, removing the buildup, and then feeding Seafoam or brake parts cleaner into the EGR and soaking it to get rid of the crap. Otherwise, I will just clean it again, but more in depth.
Raider is offline
 Old 12-20-2010, 08:40 PM   #55
ms686's Avatar
Posts: 11   (View Stats)
ms686 will become famous soon enough
are you guys having rough idles with dips and bounces, kinda like when unmetered air is present (leak)? I threw a P0300 and have these symptoms
ms686 is offline
 Old 12-28-2010, 12:37 PM   #56
RichB's Avatar
A clogged EGR causes slow cold start issues and a rough idle. Since you have a P0300, I'd check the spark plugs. One or more might be fouled.
RichB is offline
 Old 01-09-2011, 08:35 AM   #57
obijack's Avatar
Posts: 1,830   (View Stats)
StreetUnit EGR Block Off Plate: MAZDASPEED 6, MAZDASPEED 3, CX-7
What would be the consequences of putting this in the EGR system?
2014 Honda Grom-Red
2014 Yamaha Grizzly 350- Blue
obijack is offline
 Old 01-09-2011, 08:42 AM   #58
Cel constantly on. This thread is for how to clean the egr system. I would do some searching for the egr blockoff plate or post a new thread to better serve your question, rather than take this thread off topic.
Raider is offline
The Following User Says NO Thank You to Raider For This Un-useful Post:
FreeFlyFreak (01-09-2011)
 Old 01-23-2011, 08:38 PM   #59
kilik2's Avatar
Posts: 1,254   (View Stats)
kilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the world
Groans: 127
Groaned at 40 Times in 31 Posts
got the P0401 cel a couple weeks ago, this how to was very useful to me this weekend.
My egr valve was mighty clogged and the pipe was even worse I went through a whole can and a half of brake cleaner. I also used a hanger wrapped in gauze to clean out the pipe. I also used some brake cleaner on the throttle body since I had some buildup on there also, not sure if that was a good idea but it seemed so at the time, lol.
Immediate impression after buttoning everything back up was the car seemed much more peppy and I wasnt getting the weird stutters at part throttle anymore.
I also had to clean my engine bay because my dumb ass spilled half a quart of coolant when I undid the egr and tb...
kilik2 is offline
 Old 01-23-2011, 08:50 PM   #60
Glad it worked. I have gotten it recently in sub-freezing temps. Goes away comes back. Might reclean it soon. Even if I have 2 hours of work every 6-9 months, it beats the $450 anal raping for a new one.
Raider is offline
 Old 01-24-2011, 02:43 PM   #61
Nikolai's Avatar
Posts: 21   (View Stats)
Nikolai is a jewel in the roughNikolai is a jewel in the roughNikolai is a jewel in the rough
I noticed the Mazda manual does not say to remove battery/tray/IC to get the EGR out... Anybody try doing it this way? I might make a stab at this over the weekend, thx for the write-up.
Nikolai is offline
 Old 01-24-2011, 03:20 PM   #62
Yeah, go for it. You will probably need micro hands and arms. I way I was gonna fit. Takes 10 minutes to take all that crap off.
Raider is offline
kilik2 (01-24-2011)
 Old 02-10-2011, 09:46 PM   #63
Night Wolf's Avatar
Posts: 894   (View Stats)
Night Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the world
Groans: 38
Just got the P0401 code. I guess I know what to do this weekend. Too bad that I have two papers due on Monday and I didn't want to waste any time this weekend. =((( What can be the consequences of driving like this for one more week (in my case around 500 miles)???
2008 Mazdaspeed 3GT
Wiseco pistons || K1 rods || GT3076 at 21 PSI (for now) || Built by Pablo and tuned by Dustin || Steedspeed exhaust mani || TIAL 38mm EWG || Custom dump tube || Grimmspeed EBCS
CP-e safe seals || CP-e 4" TIP || CP-e big maf || CP-e catless DP || CP-e HPFP || CP-e gauge pod with Prosport gauges || COBB FMIC || COBB XLE BPV || COBB STS || COBB AP
Matt Damond OCC || CNT exhaust || BSD || EGR del || DENSO ITV22 || TRZ RMM || TRZ TMM || JBR PMM || JBR shift knob || Stoptech slotted rotors || KONI FSD || ROTA GRID 18 x 8.5
NATOR NJ FTW
Night Wolf is offline
 Old 02-11-2011, 03:45 AM   #64
You will be fine.
Raider is offline
maroner (11-27-2012), Night Wolf (02-11-2011)
 Old 02-11-2011, 09:08 AM   #65
lazn's Avatar
none at all. well perhaps a slightly cleaner intake because the crud is stuck in the pipe and not going into the engine.
FYI: I cleared my CEL by just switching to Chevron gas.
lazn is offline
 Old 02-11-2011, 09:11 AM   #66
Oh. it will come back. Trust me.
Raider is offline
 Old 02-11-2011, 10:40 AM   #67
lazn's Avatar
Been off longer post switch than pre.. (that is, I hadn't owned the car long when I got the CEL) I have stuck with good gas since then. I would not be surprised if it does come back, but I am avoiding ARCO for all but emergencies now. (my last car didn't care it'd drink anything)
lazn is offline
 Old 02-11-2011, 02:31 PM   #68
akias's Avatar
Posts: 13   (View Stats)
akias has a spectacular aura aboutakias has a spectacular aura about
Just got the CEL on today. Took it to the local dealer. What a fucking mistake, and I knew better too. Anyway the local Mazda store quoted me $704.97 to replace the EGR. I started laughing at the service writer. So I immediately called Mazda Cust Serv to vent my frustration, they told me to eat a dick and that I should go fuck myself and if I'm not mistaken before I hung up the guy at Mazda CS whispered something about me shoving the EGR up my own ass. So long story short guess I'll have to clean it myself and lose an hour or so of my wonderful life. Thanks for the instructions.
mkey66, leka and MrAnderson like this.
2007 MS6 Black Mica
akias is offline
 Old 02-11-2011, 06:29 PM   #69
soccerballz's Avatar
Posts: 596   (View Stats)
soccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the world
Anyone try to use the egr block-off plate yet?
08' Black Mica MS3
Mods: Vibrant 3" SRI, CP-E 3" TIP, GT3071 IWG, Manley H-beam rods, Wiseco Pistons, BSD, PG Exhaust Mani V3, CP-E Catted Downpipe, Borla CBE, CP-E FMIC, Cobb AP, CP-E HPFP, Turbosmart DP BOV, Cobb SS + Bushings, Cobb Shifter Weight.
Sponsored by NATOR VA
soccerballz is offline
 Old 02-11-2011, 06:38 PM   #70
Yup. Lots of threads. Not in this one as it is a how-to on cleaning it, not modding it.
Raider is offline
tddvrrn (03-17-2012)
 Old 02-11-2011, 06:47 PM   #71
thanks ill have a look
08' Black Mica MS3
 Old 03-21-2011, 10:55 AM   #72
telopyros's Avatar
Posts: 73   (View Stats)
telopyros is a splendid one to beholdtelopyros is a splendid one to beholdtelopyros is a splendid one to beholdtelopyros is a splendid one to beholdtelopyros is a splendid one to beholdtelopyros is a splendid one to beholdtelopyros is a splendid one to behold
Just did this yesterday, took the egr and pipe off. Since it was carbon build-up, I used "easy off" oven cleaner to get it all out, looked perfect and took it down to bare metal with nor carbon remaining. i would suggest this method, easy and that stuff only cost 4$ versus trying to scrape it all out. Alos 75+ miles since then and no CEL.
06 MS6 Liquid Silver/CP-E SRI/ CP-E RMM/ JBarone SSP/ MSD dash hawk
telopyros is offline
 Old 03-21-2011, 11:15 AM   #73
Thanks for the tip. I have been slacking on redoing mine again more thoroughly. Question though for those who did the cleaning. What do you think would happen if I just removed the 4 screws from the top with it installed, and pulled the top off? I am thinking of a "Lazy Guy EGR Cleaning, and it might take less time to clean the valve. Mine is just sticking, the piping is fine.
Raider is offline
 Old 03-21-2011, 12:07 PM   #74
lazn's Avatar
For what it's worth, I have gone over 6000 miles since switching to good gas and the CEL as not come back. Nothing else done but stop burning cheap gas.
lazn is offline
 Old 03-21-2011, 12:09 PM   #75
93 octane Shell/Chevron only. 66,000 miles total though. Lots of short driving, too.
Raider is offline
 Old 03-21-2011, 01:35 PM   #76
wankular's Avatar
Where did you find good gas in phoenix?
2009 MS3 sport MGM
wankular is offline
 Old 03-21-2011, 01:50 PM   #77
Arco...lol
Raider is offline
 Old 03-21-2011, 01:56 PM   #78
lazn's Avatar
Lol, good is relative I guess. I only use Chevron or QT now.
lazn is offline
 Old 03-22-2011, 06:44 PM   #79
Langy's Avatar
Posts: 32   (View Stats)
Langy will become famous soon enoughLangy will become famous soon enough
wow, amazing write up.
Langy is offline
 Old 04-13-2011, 03:14 AM   #80
WhoKnowsWho's Avatar
Posts: 12   (View Stats)
WhoKnowsWho is an unknown quantity at this point
Did all the disassembly this past weekend but the CEL came back after 2 tanks of gas. And the sad thing is, all I have been using is QT for gas for years now so I don't think I can improve the gas I am using. I didn't do a scrub down cleaning though, I sprayed everything with brake cleaner, actuated the valve, and blew compressed air through the pipe. Could the actual mechanical actuator be bad? Or was my cleaning too lazy? Oh yeah, it's an '07 with 86K miles, mostly highway. Maybe I'll have to try the easy off oven cleaner.
WhoKnowsWho is offline
Closed Thread
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/how-clean-your-1st-gen-mazdaspeed-3-a-50596/
After refueling, Passat is slow to start and temporarily running roughly : MechanicAdvice This thread Refback 07-28-2015 08:18 AM
Help Needed Please Cold Start issues ? Mazda MPS Owners Club This thread Refback 06-01-2015 01:22 PM
To throw or not to throw CEL - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 04-05-2015 02:37 AM
I broke the testpipe/downpipe bolts on my 2010 Mazdaspeed 3 last night. Need some advice. : cars This thread Refback 10-25-2014 07:32 PM
Help Needed Please Cold Start issues This thread Refback 06-16-2014 05:44 PM
Óêðàèíñêèé Ìàçäà Êëóá :: MazdaClub.UA > Ìàçäà 3 1.6ÀÒ_Ïðè ðàçãîíå îùóùàåòñÿ ïîòåðÿ ìîùíîñòè This thread Refback 08-22-2013 04:05 AM
Ìàçäà 3 1.6ÀÒ_Ïðè ðàçãîíå îùóùàåòñÿ ïîòåðÿ ìîùíîñòè - Óêðàèíñêèé Ìàçäà Êëóá :: MazdaClub.UA This thread Refback 08-19-2013 06:00 AM
bastion72 comments on And this, gentlemen, is why EGR valves are literally Hitler. This thread Refback 06-28-2013 06:53 PM
And this, gentlemen, is why EGR valves are literally Hitler. : Justrolledintotheshop This thread Refback 06-27-2013 07:30 AM
EGR valve - 07 MS6 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 05-22-2013 11:14 AM
Advice requested regarding a smoking 2008 CX7 : mazda This thread Refback 01-29-2013 03:15 PM
Check engine light code P0401 (EGR) - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 01-10-2013 02:58 PM
Mazda3 - Éteint au arrêt. - Mazda 3 Quebec This thread Refback 12-18-2012 02:42 PM
Sprawd? silnika ?wiat?a kod P0401 (EGR) - Mazda3 forum: # 1 Mazda 3 Forum This thread Refback 12-16-2012 09:24 AM
Probleme mazdaspeed3 - Mazda 3 Quebec This thread Refback 12-06-2012 05:27 AM
Cold Start problems on a stock MPS6 This thread Pingback 10-30-2012 11:36 PM
Check engine light code P0401 (EGR) - Mazda3Forums.com This thread Refback 09-03-2012 03:57 PM
EGR valve needs cleaning! - DFW Mazdas This thread Refback 06-14-2012 01:15 PM
AnandTech Forums for Mobile Devices - I want to know more about EGR valve CEL This thread Refback 03-28-2012 09:51 AM
What Did You Do To Your MAZDASPEED3 Today - Page 24 - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Pingback 03-20-2012 12:25 PM
????? ?????????. ??????? ? ???? ??????. This thread Refback 02-13-2012 12:56 PM
I want to know more about EGR valve CEL - AnandTech Forums This thread Refback 12-07-2011 03:31 PM
Mazda MPS Owners Club • View topic - Help Needed Please Cold Start issues This thread Refback 10-18-2011 05:53 PM
Rough Idle possible EGR? This thread Refback 09-16-2011 08:27 PM
2 issues with my Mazdaspeed 6 - DFW Mazdas This thread Refback 08-21-2011 12:17 PM
MZR talk here **NO SUBARUS ALLOWED** - The Something Awful Forums This thread Refback 08-08-2011 10:37 AM
I want to know more about EGR valve CEL - AnandTech Forums This thread Refback 06-07-2011 02:42 PM
EGR Valve.... - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum This thread Pingback 04-14-2011 05:02 PM
check engine light on and off...code p0401 - DFW Mazdas This thread Refback 04-01-2011 08:42 PM
hi - AZMC - Arizona Mazda Club This thread Refback 03-18-2011 03:29 PM
mazdaspeed3 egr valve - Zuula Search This thread Refback 04-08-2010 07:05 PM
Mazdaspeed CAI filter- how to clean? red07 MazdaSpeed 3 - Engine, Transmission & Driveline 13 08-15-2012 02:24 PM
how to: clean up oil from your driveway phillyb MazdaSpeed 3 - How-To's 26 11-04-2009 02:06 PM
Page generated in 0.61402 seconds with 36 queries
